Question about JVC Audio Players & Recorders
Jvc rx-r75 circuit board - JVC Audio Players & Recorders
2 Suggested Answers
SOURCE: JVC RX-6042S shuts down after 5 seconds
It will be one of the transistors that regulate the lower volatges (5V, 12V...)
I ffixed mine. the heatsinking on those transistors is pathetic, and its no wonder they dont last.
Mine was the 5V circuit, which also supplies the DSP board. so if you are getting a DSP NG, that could be that as well.
Check Q1434 and Q1404. if one is faulty, it drags the other one down with it.
Good luck.
Posted on Oct 29, 2011
Where can buy jvc Rx-r75 remote control and if there any other model that would fix
http://www.jvc.newremotecontrol.com/catalog_item.php?catnum=RM-SR75U&refnum=RX-R75
May 16, 2017 | JVC Audio Players & Recorders
I need help with the schematic diagram of a JVC RX-5THPBK power amplifier
Have you checked into SAM'S FOTOFAX or other searchers, or do you have schematic and need interp. of it?
Aug 03, 2016 | JVC Audio Players & Recorders
Can a ten band equalizer be used on a JVC rx-8030v 6.1?
Yes.
Use the Tape/MD or the one next to it (lower)
Aug 12, 2012 | JVC RX-8030V Receiver
Good luck.
Dec 27, 2009 | JVC RX-6042 Receiver
Rx-dp15b reciever turns on, then immediately goes into standby
Just worked on a Sony with a similiar problem. I replaced the Power Amp Drivers. They were labeled as IC's on the circuit board. They were relatively inexprensive, around $33 total. This fixed required knowledge in using a Soldering Iron and Desoldering Wick. Also I had a schematic of the circuit board which can be purchased on the internet. Hope this works for you. It might be best to just have a tech look at it, if you have no electronics knowledge.
Jan 10, 2009 | JVC RX-DP15 6.1 Channels Receiver
Frigidaire electrolux gallery series
stoveboy,
I know you probably have the problem fixed by now, but I had the same problem with my frigidaire range just the other day. Loud popping sound, range/clock controls do not work. Stovetop still works great.
I took the back off the stove and got to the circuit board. Unplug the connector and the five spade connector wires. Once you do that, remove the 4 screws holding the entire assembly in place. The circuit board(s) are held in the housing with retaining clips on the housing. Use a small screwdriver or similar to pull back on each clip to pry each side of the board out. Once the board(s) are free, look in between the two circuit boards and you will see the problem. The larger, 20 amp relay is the culprit. It blew traces off of both boards making it almost impossible to repair. Without having a schematic to go by, I went ahead and decided to just replace w/ new boards as opposed to trying to solder the traces. I have not checked on prices, but brief web searches didn't return any results. The board part # is SF5301-S7509-N
Apr 14, 2008 | Maytag MGR5875QD CleanDesign Gas Kitchen...
Jvc rx 318 receiver
The problem you describe is common to JVC amps. This control has a motor mounted on the back of the circuit card that drives the volume control up or down using the remote control for this system. The looseness of the volume control cannot be repaired. The shaft has separated from the potentiometer. I don't know if JVC has this part any longer but it has to be replaced as a unit (volume control card).
Nov 07, 2007 | JVC RX-318 Receiver
61 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
