Question about Dryers
Replacement Replace belt and baring
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • 102,366 Answers
What make and model dryer?
Posted on Jul 23, 2013
MY HUSQVARNA YTH24K48 MOWER WILL BARELY MOVE FORWARD OR REVERSE. I CHECKED THE FREEWHEELING MECHANISM AND IT WAS WORKING PROPERLY. LOOKING UNDER THE MOWER AS WELL AS I COULD, IT SEEMED FINE.
sounds like the drive belt or belts are worn out. replace both in order for it to work properly .replacing one wont work. replace them as a pair.
Nov 05, 2016 | Husqvarna Garden
Stopped in Belt had been slipping smelled hot but motor was barely warm. Was 30 minutes into workout and machine stopped. Electric panel works but motor won't run.tilt works
time to lube the DECK belt, use WD-40 or grease. do it by each weeks. Try to loose the deck belt. in the way that you lift the belt by 2" with your finger. Otherwise, you must replace the belt+deck. See if the belt drive is to tight. And take time for maintenance the motor, replace the carbon brush+and lube the bearing.
Feb 08, 2015 | Nordic Track Nordictrack C1900 Treadmill...
My swisher25hp-60 in.cut barely moves going forward
Was it working correctly earlier or is this your initial operation?
According to the product manual for "loss of drive":
1. Bypass linkages in the bypass position
2. Hydro belt worn, damaged, or broken
3. Idler spring loose or broken
1. Make sure that the bypass linkages are in
the drive or engaged position. Located at
the rear of the machine. Refer to decal on
the rear of the unit.
2. Replace Hydro belt.
3. Replace Idler spring
Apr 16, 2014 | Swisher Zt2560 Zero Turn Radius 60" Riding...
Oreck airhgq motor not working
Dear Sir:
1) See if some objets is inscruted in the belt.
2) Blocked hose, cleane
3) Clogged bag, clean.
4) Motor need lube, or change brush, test it for oveheating winding may be need replace.
5) Before to do that replace or retight a little the belt or replace.
God bless you
May 26, 2012 | Vacuums
How do i fix a dry belt? drive belt tensioner thats bad? and bad barings?
replace the belt ,replace the tensioner assy its one bolt in the center of the tensioner
Feb 18, 2011 | Lincoln LS Cars & Trucks
Changing an engine belt, but motor mounts in the way. how do i take the old belt out
Get a floor jack.Position the jack with a block of wood on top right under oil pan.Jack the jack untill it barely touches the bottom of pan.Remove mount and timing chain cover to replace timing belt.Make sure you allign timing marks before you remove belt.Make sure timing chain tensioner is working properly.Reverse procedre to replace.Good luck.
Jun 11, 2010 | 1993 Oldsmobile Cutlass Ciera
Brushes don't spin
Hello :
try this please : switch the carpet/bare floor dial back & forth 5 times, ending on carpet. Tilt the handle back as if to vacuum upright & lay the vacuum on its side so it is resting on the side opposite the carpet/bare floor dial. Turn the vacuum on.
or try this also if the above suggestion didn't work :
Maybe the belt is broke. You will have to replace the belt before the roller can spin. You must have run over something in the carpeting like string or whatever to have it break. Happens all the time. Get several replacement belts to keep as spares while you're at it as nothing is worse then having to vacuum and no spare belts.
please rate !
May 07, 2010 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
How do you replace the belt
Not sure about your particular vehicle. Best is to get a book from autozone. But there should be a tensioner pulley somewhere on there. You put a ratchet or wrench on it and turn counter clockwise to release the tension on the belt to remove/replace it. It is usually black and roughly 2 to 3 inches in diameter. No teeth or grooves. It's a smooth surface pulley.
Mar 29, 2010 | 2000 Daewoo Lanos
The brush does not spin in carpet mode or bare mode
Your drive belt is probably stretched, worn or broken. You need to replace it. You can get replacement belts here:
Replacement Vacuum Belts
Nov 30, 2009 | Vacuums
My dyson DC17 has a noise in it when in the carpet mode and not when in the bare floor mode. HELP
Did you clean out the roller brush and replace the belt? If you haven't done that I would give it a try. Here is a link to the replacement belt you need:
Dyson DC17 Belts
Nov 24, 2009 | Vacuums
Dryers Logo
14 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
