Question about Car Audio & Video
Polaris CAA02 sound/voice on NAV stopped need help to reset i guess
Hi I have a Peugeot with clarion sat nav but it's stopped talking to me as the voice sound has gone.
You can try to reset or restar. Check whether the machine itself has a problem. or maybe it will upgrade. Car Diagnostic Tool
Aug 26, 2016 | Peugeot Cars & Trucks
Have paired the sat nav with phone and they are seeing one another, but when I click the answer call on sat nav no sound is coming from sat nav have turned volume fully up can u help regardss
Search Results
    Troubleshooting voice navigation issues, including vehicle ...
    productforums.google.com/d/topic/maps/NR6xxNE5vQw
    Google
    Aug 21, 2014 - 100+ posts - ‎100+ authors
    Basically to work like a satnav does. .... Have been using Google maps and voice navigation with no prles since May. ..... The audio does come out from the phonespeaker even when my Bluetooth is paired to the phone.
Oct 24, 2015 | GPS
Installed Meos mc701b with navme 120gps nav system. All fine except that the sound on nav instructions is very low and see no means of resetting it. Any solutions? Seems a common problem
This is simple - go to the NAVI screen itself via the menu - turn the volume up using the volume up key.
Return to the radio and now hold down the menu key - you will go back to the sat nav screen with the radio playing in the background - when you now get voice prompts they will be louder than before!
Nov 10, 2010 | Car Audio & Video
Cannot get any sound on sat nav can I push the reset buuton at bnottom or would I lose maps etc. Thanks
there are 3 possible causes for this,
1: tap the bottom left of the screen and move the slide bar to the right to increase volume
2: go into set up menu and see if you have switched off the speaker. If you have, it will show a picture of a speaker with a big red cross through it.
3:You will only get spoken directions if you have selected the "computer voice" option. All other voices will disable this function.
I hope this is of some help
Sep 30, 2010 | Tomtom ONE GPS Receiver
My panasonic sat nav will not start past yhe first
try the reset button, first on it's own, then while powering on
Apr 02, 2010 | Panasonic Strada CN-NVD905U GPS Receiver
Volume to low for nav, i know there is a way to adjust the nav. only volume but i dont remember how
It is possible to turn up the voice level...but you have to be willing to hack the voice file a wee bit with a hex editor.
Just Open the .vpm file you want to modify in the hex editor, and search for "<voice_volume>96</voice_volume>" without the quotation marks...and change the numerical value - I have Australian Karen cranked up to 96. This makes the sound level of the voice prompts comparable to the MP3 level when I hook my Nuvi350 into my vehicle's sound system via the added line input that takes the place of the non-existent CD changer. Before I did this, when I played MP3s at a comfotable listening level, the voice prompts were too quiet. Now, they're comparable.
Hope this is what you were looking for
Aug 16, 2009 | GPS
Voice
Try activating the voice agian or the voice file might be corrputed or deleted.
Aug 27, 2008 | Tomtom ONE GPS Receiver
No audio directions
try doing a hard reset underneath the sat nav is a small slide reset remove sd card first, reinsert and switch on, good luck
May 23, 2008 | Evesham Nav-Cam 7700 GPS Receiver
Nav-cam 7000 Can't start
After you click on each of the corners, you have to tap the center twice. I believe you get a message that tell you that. You just need to read it :-) Once you tap it twice it "accepts" the adjustments and boots up.
Jan 06, 2008 | Evesham Nav-Cam 7700 GPS Receiver
Lucca sat nav
This is a common problem as the GPS's bake in the sun and bounce around. The cone on your speaker is likely displaced and will need to be brought in for reconnection. It is also a problem on radar detectors along with garbled voice along with NO voice... Hope this helps!!!
Jul 20, 2007 | Blaupunkt TravelPilot DX-N GPS Receiver
Car Audio & Video Logo
22 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
