How do you wire a airxcel 8330*733 to a duo therm thermostat
I need to wire a 6 wire duo therm thermostat to an airxcel 8330*733* 4 wirrxcee system
BearWeb
  • 357 Answers
SOURCE: Duo Therm Thermostat
Hi there
I think this is a setting on your air conditioner, the air conditioner will turn off when the room is at the correct temperature and when the room starts to warm up, the air conditioner will turn back on. (You need to find the settings and change them from auto-adjust to manual-adjust)
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Posted on Jun 27, 2008
SOURCE: duo therm air conditioner
my duo therm air works beautifuly all day but at night when we go to bed it seams to turn on and shut off rapidly. what could be wrong?
Posted on Jul 19, 2008
SOURCE: thermostat wiring for second ac unit
I replaced one unite with another and the wires are differance colors the old unites wires are red,purple,yellow,bleck and white the new one have orange,brown,cream,darkpurple,and white
Posted on Aug 02, 2008
motor1258
  • 6674 Answers
SOURCE: duo therm air conditionning/furnace thermostat in RV
Checked all breakers & fuses in panel ?
Posted on Aug 14, 2008
  • 415 Answers
SOURCE: looking for wiring diagram for a duo therm by
There are several models out there. Here are a couple of manuals with wiring diagrams that I believe will help you regardless of the model number. However, if they are unable to help you, let me know the exact model number and we'll search for the wiring diagram. :-)
Link #1
Link #2
Posted on May 19, 2010
Need a wiring diagram for duo therm thermostat in a 1994 Kountry Star motorhome
didnt specify model number of stat --can notify domestic they make the duo therm products
dometic com
Aug 31, 2016 | Heating & Cooling
How do you bypass a duo therm thermostat, which two wires would you touch together
That would depend on what you want to run, and wire colours coming from ceiling control box to thermostat. Need more info.
Nov 11, 2013 | Dometic Rooftop RV Air Conditioner
What replace Duo Therm Thermostat 3105356.001
Can you attach a picture? Does it look like this one?
Jan 14, 2013 | Dometic Rooftop RV Air Conditioner
Have a duo therm ac and the low ac and low fan not work -
Thermostat on wall, or manual controls at AC? Did it work for you on low before now? Reason I ask, is that normally they are only a 2 speed fan ( low and high) so if it's a wall thermostat and has been changed from original, perhaps it the way the thermostat is wired.
Jul 05, 2010 | Dometic Rooftop RV Air Conditioner
I have an old mobile home that has and old duo therm thermostat that is acting up. keeps cycling off for quite awhile and on for not so long. I purchased a honeywell ct-31-a. It only has places for 4...
If you want just heat, connect the red wire to the R terminal, the White wire to the W terminal and the green wire to the G terminal. Confirm that these same wires go to the same terminals on the control in your furnace. If you want both heat and air conditioning, connect a jumper from R to R2. Keep the wires the same as I described and put the yellow wire on the Y terminal.
Feb 01, 2010 | Honeywell Heating & Cooling
Duo Therm AC won't cut off with thermostat
Hi, sounds to me like the thermostat is at fault.You have done nothing wrong to it but cover it up. The t-stat is what controls it, turns it on and off. The only other thing that would keep it on all the time would be that the thermostat wiring could be touching together from the stat up to the unit. You might check that before replacing stat. I have seen this many times.You can start the unit and go up top and disconnect the stat wire and it should stop the unit.Then its either the wire or stat.Let me know what you find,
Sincerely,Shastalaker7
Nov 04, 2009 | Heating & Cooling
We have a duo therm rv analog thermostat. When we opened it up none of the 7 wires were attached. Do you know the wiring code?
red wire to the r section of the thermostat white (heat) to the w marked on thermostat Green (fan) to the g marked on thermostat yellow (a/c compressor) to the y marked on thermostat. Blue to the c marked on thermostat. Orange to the orange marked on thermostat.
Oct 30, 2009 | Dometic Rooftop RV Air Conditioner
A duo therm thermostat (p/n 3105058) was removed because it would not operate the air conditioner/heater in a firan fireside camper. it was knocked loose from the wall damaging it.the thermostat is for use...
a. Remove the cover of the thermostat.
b. Connect the RED wire from the air conditioner
to the “RC” terminal on the thermostat.
c. Connect the “YELLOW” wire from the air conditioner
to the “Y” terminal on the thermostat.
d. Connect the “BLUE” wire from the air conditioner
to the “H” terminal on the thermostat.
e. Connect the “ORANGE” wire from the air conditioner
to the “G” terminal on the thermostat.
f. Push the thermostat wires into hole in wall and
fill excess hole with insulation.
g. Mount thermostat base to the wall with screws
provided.
h. Check all thermostat wires on base to ensure
they are completely clear of the bimetal coil of
the thermostat. Adjust if necessary.
i. Replace thermostat cover.
If nothing operates on the air conditioner, remove the
return air grille assembly and verify the red, orange, yellow
and blue wires are properly connected (red-to-red,
orange-to-orange, etc.).
Next, disconnect the red wires and check for 12 volt
DC between the red wire from roof section and the orange
or blue wire from roof section. If no voltage received,
refer to Section F2. If voltage is received, the
problem lies with the thermostat or thermostat wires.
Next, disconnect all 4 wires (red, orange, yellow and
blue) from the thermostat. With the thermostat set on
COOL mode, FAN mode set on AUTO and HIGH, and
temperature selector set lower than the room temperature. Check for continuity between terminal RC (red wire)
and terminal G (orange wire); and RC (red wire) and
terminal H (blue wire). If continuity is achieved on each,
proceed with the next step.
Set fan switch to LOW. Continuity should NOT be present
between terminal RC and Terminal H, but present between
the other terminals (Y & G) and terminal RC.
If all of the previous checks are good, the thermostat is
good, do not replace it. If any one of the previous checks
are not correct, replace the thermostat.
Jun 15, 2009 | Dometic Rooftop RV Air Conditioner
Thermostat wiring for second ac unit
Aug 01, 2008 | Dometic Rooftop RV Air Conditioner
Duo-Therm by Dometic Thermostat
red and white are positive and neg 12v
green is low fan
grey is high fan
yellow is cooling
blue is neg 12v(marked B-)
May 17, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
