Apc battery backup makes squealing noise, then the power light comes on, why
    Scholar:
    New Friend:
  • 129 Answers
When there is no power coming into the UPS it will indicate so by 'squealing', during this time - the UPS is on battery. When power returns to it, it turns back to building power and the power light comes back on.
If you need UPS, Surge, or Power Related help contact Daniel @ Power & Systems Innovations 800.260.2259 or go to our website: http://psihq.com/
Posted on Nov 05, 2013
  • 37 Answers
SOURCE: I have a apc 650 model bk650mus battery backup.
how long the lifespam is the battery you had are using it? if you check the voltage that is 13.5dcv but it could be the Ah is already running low.. try to change with a new batts and power up the ups ifi it not workin that mean it the hardware issue..
Posted on Mar 24, 2009
  • 6 Answers
SOURCE: squealing noise
Depending on the unit, thats either telling you the battery is dead, the power is out, its overloaded (too much or too large equipment) or there's another problem with the unit. If you have the cable that should have come with the unit, you can connect it to a computer and install the software for a diagnosis.
If you unplug or turn off everything connected to it and it still squeals, the battery is probably dead, but it may be that something is wrong with the UPS itself, and you should send it back under warranty, or get a replacement.
Posted on Apr 29, 2009
SOURCE: APC ES350 strange noise
My solution was to unplug everything, hit the reset button, and then power the unit back up. The problem I found to be that I had my laser printer connected to the "surge + battery" side, and for some reason no laser printer can be connected to it.
Posted on May 28, 2009
JaxPlanet
  • 922 Answers
SOURCE: APC back-ups XS 800 battery backup : warning
Turn it off and unplug it from the wall.
Open it up and make sure that the red and black wires are connected.
If they are the battery needs to be replaced. They are only good for 2-3 years. If you are not comfortable with my instructions, call APC for free support. (800) 555-2725
Vote for this solution if it helps.
Posted on Aug 18, 2009
SOURCE: My APC bx900r is making a squealing noise with the
It has a fan. Your fan has died. This is causing it to overheat (which is interpreted as being in overload). Replace the fan or replace the unit. When this happened to me, I purchased a new fan for less than $10. You will need a 40mm fan and the ability to use a phillips screwdriver.
Posted on Sep 25, 2010
Apc beeping twice every 2 seconds
The battery inside the APC is "weak", and the "beep" is telling you to replace the battery inside the APC, or, maybe cheaper, to buy a new APC.
Feb 03, 2014 | APC BACKUPS ES BE550G 8Outlet 550VA 330W...
Battery b/u squeals after unplugging everything from it and have also uplugged the unit from the wall
Hi Robert,
The UPS will beep/squeal if the power isn't turned off to it before it is unplugged from the wall. But the other thing that may be causing the noise is a bad battery. Replacement battery price is $26.00.
Reply or call if you need more help with this -- 407.380.9200
Sep 20, 2013 | APC (BE500U-WEB) (BE500UWEB) UPS System
APC power supply. My backup power supply "online"
How old is the unit? They only last so long before the battery can charge no more.
Dec 30, 2010 | APC Back-UPS CS 500VA UPS System
When the power button is turned on my apc350 makes a high squeal sound, what is this? I have to have it turned on to use anything that is plugged into the battery backup outlets.
Double check the connections on the internal battery. If you have had the unit for a year or longer it may be telling you your back up battery isnt any good. I suggest replacing the battery, go here http://www.apc.com/tools/upgrade_selector/index.cfm
Mar 15, 2010 | APC Back-UPS ES 350 - UPS ( external ) -...
APC will not stop making noise even after I
Disconnect the battery(s) from inside. The backup batteries are still working...
Mar 12, 2010 | APC Back-UPS Office 500VA (BF500) UPS...
My APC bx900r is making a squealing noise with the red light flashing after a few minutes after being turned on. The brochure says this means it is overloaded, but nothing is plugged in to it. the...
My suggestion would be to replace the battery to make sure the battery is not shorting out the UPS. If you can't do that, take out the battery and then replug the UPS back in.
If you still get the same results then that means the main board inside of the ups system is bad and you would need to get a new UPS system.
Nov 26, 2009 | APC (BE500U-WEB) (BE500UWEB) UPS System
Beep and yellow green light problem
It sounds like you may need a new battery. The batteries are continuously tested by the UPS and it could be that the voltage is passing one test, and failing the next which is resulting in the light flashing. You can test the battery with a voltmeter. It should read over 11.5 volts, if not you need a new battery set. You can get batteries from http://www.batteryinternational.com/ups-batteries-apc-batteries.html
Jun 20, 2009 | APC VS 500VA (VS500VA) UPS System
Squealing noise
Apr 12, 2009 | APC (BE500U-WEB) (BE500UWEB) UPS System
Sep 28, 2008 | APC Back-UPS ES 350 - UPS ( external ) -...
Computers & Internet Logo
191 people viewed this question
David Payne
David Payne
