Question about Jensen VM9510 Car DVD Player
Brake bypass i need help figure out the brake bypass
  • 1 more comment
  • Falcon513 Dec 10, 2007
    Hi, I have the same problem, I tried to do so, the pink cable is connected to ground, and no way to get the video signal what can I do? It´s necessary a Relay?
  • caraudio Jan 03, 2008
    i need to bypass my e-brake for a dvd player in a dodge dekoda.
  • nicolenell Feb 20, 2009
    how can you work it with out hooking it to the e brake
  • 24 Answers
Just run a toggle switch from the pink wire on one side and a ground on the other and ground it to your ground wire on radio put dvd in wait till you hear the sound and flip switch off and on movie will show even while driving this is for all e brake problems i know this is how i ran mine and everyone else
Posted on Mar 11, 2008
Is there a bypass code for a vr3 and does any one know what it is and how to put it in?
Posted on Sep 21, 2008
I used to work at a car audio and video shop installing well car audio and video. on the older model jensen headunits we used to install a toggle switch that connected the pink brake wire to ground and you would have to have the switch turned off before you put a dvd in. once you put the dvd in you would have to flip the switch on for three seconds then back off for three seconds and then again flip it on and leave it on. this should bypass the brake wire. it takes a little bit of practice to do it but once you get then hang of it, its easy. now on the newer jensen and phase linear headunits you would have to acces the settings menu, then you on the remote you would have to input the following code. 5, 4, 3, 2, 1, 0. once this is done a secondary settings menu will pop up. on this menu you will have the option to turn the brake override feature on or off. hope this solve most of your problems.
Posted on Apr 23, 2008
What you have to do is trick out the dash. Turn on your indash, put a movie and play it. It should say that your brake has to be on to play. When that screen pops up you have to ground the pink wire in a particular way.. first you have to touch the brake wire to the ground for a second or two, take it off for like 5 seconds and then touch it again to the ground for about another 2.. repeat that for a couple of times, it should work rite away though. i heard that alpine are more complicated but works on other cheaper brands
Posted on Dec 07, 2007
    Problem Solver:
  • 9 Answers
No, actually, you need a prewired toggle switch. connect the pink wire to this and the other end to the e-brake. now you also need another piece of wire to connect to the e-brake connection (plate that makes contact with the e-brake) or just to ground.
when this is all done, with the toggle switch on, turn the car on. it should still give the warning message. wait about 5 seconds and switch to the off position. wait another 5 seconds and turn back on.
note: you will have to do this every time you start your car.
Posted on Oct 29, 2007
Just attatch the pink wire to ground (the black one). Your DVD will play any time (may be illegal in your country/state/province.
Posted on Sep 14, 2007
SOURCE:
Bypass neutral switch
nope... you need to figure this out yourself...
Sep 08, 2014 | Garden
Need code to bypass e brake pioneer p1400 dvd
There is no code for bypassing the e brake.
Apr 10, 2012 | Pioneer Car Audio & Video
Brake pedal slowly creeps to floor noleeks in system that ican find has been likefor a year vehicle stops on adime brake light cametoday cant figure out why
the seal in the master is going bad and the fluid is bypassing it on light pressure. the only cure is replacement
Jun 18, 2011 | 1994 Jeep Grand Cherokee
By pass parkbrake on soundstream vir-7011NBT
you'll need a schematics for that.or you can bring to a car-audio tech for more details.
May 29, 2009 | Virtual Reality VRCD500-SDU CD Player
Need help with brake bypass
you have to connect the wire that supose to go in the brake switch on the grounded side of that switch, now what color the wire is? it depends what brand and model of stereo you have
Apr 15, 2009 | Audiovox VM9512 Car DVD Player
Jensen vm9512hd e-brake bypass
the pink wire on the unit is for the E-brake.... ground it out somewhere and that will bypass the brake and fix the problem.
Nov 13, 2008 | Jensen VM9510 Car DVD Player
How do i bypass the parking brake switch in order for my video to play
yea it will work if u leave the car running but once u shut off the car and turn it back on it doesnt work there has to be another way
Mar 01, 2008 | XO Vision XO9013 Car DVD Player
I got a ?
Normally, the emergency/parking brake has to be activated/engaged for the video player to operate.
By bypassing, you are simulating this condition even if in reality, the emergency/parking brake is not activated/engaged.
Solution > ground the video player's brake sensor wire rather than connect it to its intended connection point.
In some brands/model/versions of the video player, this would be light green (Pioneer, Clarion, JVC), green (Kenwood),
In some other rands/model/versions of the video player, there would be a bypass switch underneath a sticker, others would need a special adapter, still others have bypass option/feature in the menu/setup and some would require a toggle switch that would connect the dvd brake wire from positive to ground.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information. A reminder pls, in some regions bypassing is not allowed.
Good luck and kind regards.
Jan 05, 2008 | Dual AM/FM/CD/DVD/WMA 2.5 MONITOR Car...
Dual xdvd700 want to permanently bypass e-brake
1. Ground the E-Brake wire.
2. Insert a DVD
Let it play until you hear sound
Press STOP twice on remote
Enter 26604
Press ENTER
Oct 27, 2007 | Jensen VM9510 Car DVD Player
Jensen VM9510 Car DVD Player Logo
293 people viewed this question
Top Jensen Car Audio & Video Experts
Larry Tezekjian
Larry Tezekjian
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
