Question about Sunlite Cloud 9 Gel Foam Cruiser Saddle Bicycle Seat
I need to know how to install Cloud 9 bicycle seat to my Schwinn airdyne com. What parts do I need-seat post clamp, plate? The plate and clamp on there now don't match the Coud 9.
Need manual for schwinn Airdyne Upright Cardio Exercise Bike, Older, i have a picture if needed
You need to do some simple research rather than ask others to do so with inadequate info. Google manual schwinn Airdyne Upright Cardio Exercise Bike.
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Dec 14, 2016 | Schwinn Cycling
Tip
Identifying Your Schwinn Airdyne
How To Identify the Model of a Schwinn Airdyne Exercise Bike
  • We'd like to share some characteristics of the Schwinn Airdyne bikes that can be used to help you identify the model of your Airdyne bike.
What size/type fan does it have? Is it a spoke fan like a bicycle wheel or short wide blade fan?
Does your Airdyne bike have two chains or a chain and a belt?
  • AD3, AD4 bikes have two chains.
  • AD Pro/Comp and AD Evolution Pro/Comp bikes have a chain and a belt.
How do the crank arms attach to the Airdyne, by wedge pin or bolt?
  • AD3, AD4 and certain AD Pro/Comp crank arms attach by wedge pin.
  • Certain AD Pro/Comp bikes have crank arms that attach by bolt.
  • AD Evolution Pro/Comp bikes have crank arms that attach by bolt.
How To Identify the Model of Schwinn Airdyne Bike
on Mar 11, 2015 | Schwinn Original Airdyne
How to install seat
Bicycle seats just slip over the vertical pipe into the pinch clamp. Tighten the clamp after installed. If the clamp is to narrow to allow it to slide over the pipe then loosen the bolt or remove it and spread the clamp apart a little then put it back together.
Apr 02, 2014 | Schwinn AD6 Airdyne Upright Exercise Bike
I need assembly picture or diagram for original airdyne.
Here is the diagram for the original Schwinn Airdyne. Only the computer is different.
Aug 25, 2010 | Schwinn Original Airdyne
Looking for a Manual for an OLDER Schwinn Airdyne, cannot find any numbers. "Computer" has only 5 buttons plus 2 "select" buttons on Work/Speed, Time/Total. Buttons labelled left to right: Time/Reset,...
Send me your email address & I will send you a copy of the airdyne manual I scanned. It is a pdf copy which has description and instructions for your Airdyne computer. It has automatic (scans all features) and manual (stays on the 2 items you select in the display windows)and tells you how to change from manual to automatic and how to operate the computer. (terpcafe@yahoo.com)
Aug 11, 2010 | Schwinn Original Airdyne
Need users manual for old Schwinn Airdyne - analog model
Sheldon Brown's Bicycle glossery is a good place to start, you can google him and he may be slow on replys but he can usally steer you in the right direction.
Aug 21, 2009 | Cycling
I need to get more cushie for my tooshie. how can I get a softer seat or add cush. to this one?
You can do either but I sugguest a new seat. The gel pads for existing seat feel strange and cost just slightly less than a new seat. It looks like you ride a cruiser so I would suggest the Sunlite Cloud 9 gel padded seat. It is extremely comfortable and is not overly expensive.
Hope this helps!
Jul 10, 2009 | Schwinn Stingray Chopper Youth Bicycle...
Sunlite Cloud 9 Gel Foam Cruiser Saddle Bicycle Seat Logo
113 people viewed this question
Top Sunlite Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Sunlite Cycling Expert? Answer questions, earn points and help others
