Question about Whirlpool Washing Machines
Whirpool washing machine model WTW5790VQ1
The washing machine is not filling with water
    Top Expert:
  • Whirlpool Master
  • 12,223 Answers
Test this steps and fix it. God bless you
  1. Water Inlet ValveReplace if found defective.
Posted on Jul 23, 2013
SOURCE: whirpool Ultimate care II
I have played with the machine at length today... In the hope that if this was merely a blockage, I could move it...
If I go to a spin cycle, the machine begins to work normally, bringing in some water and then spinning slowly... It seems then, that the pump does not engage, thus leaving the water in the drum and not allowing the machine to speed up to a full speed spin.
If I enpty the machine using gravity to drain the water, the spin runs normally.
Obviously draining manually is not viable during a wash cycle. Is it possible that there is a switch for the pump, which is in need of replacement, or is this a requirement to replace the pump.
Posted on Jan 27, 2008
  • 1462 Answers
SOURCE: Hotpoint Washing Machine Model # VBXR1060T4WB Filling Problem
problem could be the pressure stat which is a switch which detects water level or the pipe leading up to this switch or the air chamber the pipe goes to.
take top off. locate the pressure switch - has a small diameter pipe going to it. remove pipe and fit a similiar one. put on fill and pressurise this pipe by mouth and water fill should stop. if it doesn't, then switch is faulty.
if this is ok, examine carefully the small diameter pipe for splits and blockage. also check the air chamber for build up of gunge
Posted on Nov 16, 2008
tbirdfan1
  • 3051 Answers
SOURCE: ge washer wbse3120b2ww does not fill water and go to the final sp
hELLO THERE
well it is looking like you have a water controle solinoid valve that is malfunctioning and needs to be replaces i would contact your nearest dealer to see what the part is going to cost and have it replaced and if you have a warranty with the machine see if you can use it .
best of luckmike
Posted on Jul 31, 2009
  • 5 Answers
SOURCE: Washing machine does NOT stop filling w/ water!
If the m/c keeps filling, where is the water going ??? if the m/c doesnt reach the required water level it will not start, check the drain hose at the back, make sure its at least 24" above floor level, if it lower then it will just empty as quick as you fill it on gravity.
Posted on Nov 19, 2009
  • 24 Answers
SOURCE: brand new roper washing machine model # RTW4440VQ2...
This model of washer has something called an Automatic Temperature Control. This means the washer puts water into the tub at specific tempreatures instead of just 100% cold, or 100% hot. Be sure and check that the hot and cold fill hoses are connected to the proper places on the back of the washer. It's possible that the ATC (mentioned above) is causing the washer to fill slowly on the cold setting.
Posted on May 26, 2010
Duet whirpool front loader is filling with water on its own
The washer fill valve is defective and will need to be replaced. The fill valve is right under the main top at the back the fill hoses attach to the valve.
Oct 07, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool awe 7728/1
It's Sensors may have stopped working. Call Customer Service Engineer.
Mar 29, 2014 | Whirlpool Washing Machines
Whirpool washing machine water not coming into the machine when lid is up and no response from any adjustment to the knobs, it work fine that last time it was use and this morning not responding to...
there's a lid switch on the right side when you open the lid,it might kill the power when the lid opens while filling,you can stick a screw driver in there to check it,you have to send the model number and tell me what it's doing,is it filling and then not doing anything or what's happening with it,does it fill with the lid down?
May 14, 2011 | Washing Machines
I have a whirpool model LSQ9200LQ3, serial CRO8155...
This is usually caused by the lid switch. These are inexpensive and easy to replace. There are videos at www.appliancehelponline.com/servicemanual.html that will walk you thru testing and replacing this part. It may be a different model but the testing will be the same. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
May 18, 2010 | Washing Machines
WHIRPOOL washer model LSR8010PQ0, WHEN LOADED WIT...
If large items in the machine create an imbalanced load the machine is designed to switch off...Towels are notorious for doing this because they hold so much water. Jeans don't soak up much water. Wash towels with towels alone and the problem should be reduced....Good luck....Nomess
May 16, 2010 | Washing Machines
Whirlpool type 111 model LSQ9200LQ3 washer not
I have a whirpool model:lsq9200lq3, and recently it has stopped working. when ever you turn it on, its fine and the water fills up normally and right before it gets to the spinning cycle the machine makes a grinding noise like if something is stopping the motor from spinning, and it dosent spin inside the washer. if anybody has any suggestion It would be great thank you.
Jan 30, 2010 | Whirlpool Washing Machines
Whirpool washer wont work
The lid switch, get something to hold it down to make machine work. Turn machine on and push down on lid.
Jul 26, 2009 | Whirlpool CAM2752KQ Top Load Washer
Filled with water but wouldn't agitate.
If this is a whirpool its the direct drive motor cuopling a 20.00 part and a 20 min repair. Average repair service cost 150 to 200.00
Mar 11, 2009 | Washing Machines
Washing Machines Logo
26 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
