Question about Black & Decker TRO200 Toast-R-Oven Toaster Oven with Convection Cooking
Door spring spring broke but can't see it. did it drop into the unit and can it be retreived? oven doesn't work because of safety.
  • a connor Jul 23, 2013
    posting is incorrect. The unit is not the one with convection coooking
  • a connor Jul 24, 2013
    To clarify. I have a B&D under cabinet toaster oven TRO200. The door spring broke and because of the safety mechanism the unit will not operate. I cannot see the spring or hear it loose inside the unit. I also cannot see how a lay person can open the unit the try to fix it. Any ideas?
The door spring came off of hamilton beach 31100
The door of the Hamilton Beach Model 03008 or similar toaster oven does not stay closed when the door return spring or the hook it connects to breaks. The repair is very simple and takes just a few minutes!
The door spring is about 1 inch long and connects to a small clip on the inside of the left side panel of the unit. To see the small clip and the door spring, you simply remove the left side panel of the toaster oven which is done by removing just one screw.
The mounting clip on the side panel for the door return spring is located about half way up the side panel near its front edge.
The other end of the spring (its bottom end) connects to a metal hook. If the spring is not connected on its bottom end then the wire hook is broken. This is a simple repair that only requires a few inches of metal wire.
The other end of the metal hook (its bottom end) is connected to the bottom of the door hinge where it inserts into a small hole in the left side mounting hinge of the door.
When the steel hook breaks on either end then the spring cannot function, so the door does not stay closed.
To fix this problem, you simply get a piece of steel wire that is about 1/16 inch thick and a few inches long.
Bend the wire to make a hook at one end that the spring will connect to.
Then insert the other end of the wire into the small hole on the left side mounting hinge of the door. Then bend the wire on the inside of the hole to make a U or hook so the wire stays mounted in the hole of the door hinge.
Then adjust the position of the bend on the other end of the metal wire so the spring will have good tension when it is attached to the hook and to the clip on the side panel.
To do this you make the U shaped bend on this end of the wire to be about 1/2 inch from the end of the open end of the spring when the top end of the spring is attached to the mounting clip on the side panel.
To attach the spring to the wire hook, first remove the spring from the mounting clip. Then hook the spring onto the hook (bend) you made at the top end of the wire, then just stretch the spring to connect it to the mounting clip. The door will now stay closed.
Nov 10, 2013 | Hamilton Beach 31197 120 Watts Toaster...
How do we change the heating element. It was hit and broke but not in half so we need to remove it and add a new one.
I ordered bulbs online at http://www.smallappliance.com/ They come in a set of 6, you can't order less than that, I looked all over the place. Here is the part number: Krups SS-185303 Heating Element. You might want to find them on Amazon.com because by the time you order them from the above website, with shipping, it will come to more than you will pay total on Amazon and it's coming from the same place. Just in case Amazon doesn't have them in stock (you never know) I wanted to give you the source for the bulbs.
  1. Unplug unit and remove all trays and racks and crumb tray. (I took this time to do some much needed deep cleaning too.)
  2. First you have to remove the old bulb. I tried it the hard way by trying to pull it out - it's connected with screws on the left and right to the connector wires.
  3. I placed the oven on a big light colored towel and had a cup ready to place all my screws in. I also took pictures of it before I started taking it apart so I had something to reference when putting back together. I used a small sharp phillips head screw driver, DW40, household oil, a set of leather household gloves and patience.
  4. I first removed the cover of the whole oven by starting with the bottom legs (there's a screw under the rubber foot), the bottom, back and then removed screws on the face/door. Becareful of the door hinge. You might want to use some household oil or DW40 before you start to attempt this. My oven is 6 years old and we've used it everyday. There was some accumulated stuff around the screws.
  5. Carefully remove cover of oven and door/face. There's going to be a thick wire that will connect the interface circuit board to the internal boards so again, becareful when removing the face of the oven. The glass door may pop out of the hinge so, again, becareful.
  6. Make sure and observe how the door hinge and spring are placed and take a picture as you're going to have to put it back together.
  7. When I got to the connector of the bulbs I had to use, very carefully, some more household oil on the screw.l I held the ceramic socket with my leather utility gloves on and gently applied pressure to get the screw loose on both sides.
  8. Carefully place new bulb in hole/holders and gently screw the wires back on, start with the right side (facing the oven).
  9. Reassemble the door hinge if you took it off. and place the face on just for position.
  10. Attach the outer cover, back first and then bottom.
  11. Attach face and make sure hinge is working properly and you've tucked that wire back in.
  12. Attach legs.
  13. Remove anything else plugged into socket you use for the oven (just in case it blows the socket which has happened with some DIY repair in our house). Plug in oven and test it out.
  14. I hope this has helped you. If not, find some coupons for Bed Bath and Beyond and purchase a new one and sell your extra bulbs on ebay or craigslist. Good luck!
Jul 10, 2011 | Krups FBC2 1600 Watts Toaster Oven with...
Door spring broke on Cruisinart CTO 350 series Toaster Oven
I had same problem with my cuisinar 350 series broken door spring. After disassembly found a broken extension spring measuring about 3/16 dia.,by 6.5 inches long.Spring was broken about a third down. I lifted ,or bended a loop and a halve up from each broken section and joined the two sections together. lifting each loop of the spring is tricky at first, requires a small screwdriver to be inserted between loop to be lifted and then gently bent the loop with needlenose pliers.
Not knowing how to disassemble the unit I had a hard time assembling the unit back.
I would start by taking off the screws holding the front black backlite first, then the main cover.
The main stainless steel cover does not have to be removed completely, by just gently unbending
the cover I was able to access the spring for removal.
Lots of luck
Jan 29, 2010 | Cuisinart TOB-175 1500 Watts Toaster Oven...
Toastmaster Toaster Oven 357 is not heating when door is closed?
Mine just broke too - it won't heat - everything else works - lights, timer ect. but no heat can't cook
without it - love my oven - any solutions ( I guess it's the heating element ) Hope I can get a new one.
Aug 29, 2009 | Toastmaster 357S Cool Wall 1400 Watts...
Position of part for TRO910W
take the cover off by removing 6 screws around the back and 7 on the bottom (2 of these are safety screws but can be removed by a small flathead screwdriver); once you romove the wrap-around "hull" or cover you can see the spring on the left side of the oven from the frontal view.; the door stop is sort of a L shaped piece which you insert from the inside of the opening on the frame & thru the little hole on the left side of the door; once you do this stretch the spring and attach to the hole into hole you see on the middle of the L shaped piece.
May 29, 2009 | Black & Decker TRO910W Toaster Oven with...
The spring detached causing the door to stay open
Toaster oven
THERE IS A SAFETY MECHANISM ATTACHED TO THE DOOR THAT TURNS OFF THE OVEN WHEN YOU OPEN THE DOOR. INSIDE, BEHIND THE KNOBS THERE IS A SPRING THAT ATTACHES TO A WIRE THAT IS CONNECTED TO THE DOOR. WHEN THE DOOR OPENS THE WIRE RELEASES THE SAFETY MECHANISM AND THE OVEN SHUTS OFF. WHEN CLOSED THE WIRE PUSHES AGAINST THE MECHANISM AND THE OVEN WORKS. I WAS ABLE TO FIGURE OUT HOW TO RECONNECT THIS FEATURE SO THAT THE OVEN WOULD WORK.
Feb 24, 2008 | Black & Decker TRO210 Toaster Oven with...
Spring in door
I have the same problem. The end broke off. I heated the end with a torch and bent a new loop (cooled it in cold water). I hope it will work for a while. I could find a replacement on the internet. To get to the spring, just remove the left side panel (3 screws)
Jan 06, 2008 | DeLonghi EO1238 Toaster Oven with...
KitchenAid toaster oven Mod# KC010058
The overload switch is located above the theromostat.To check it put a jumper across the switch and plug the unit in. If the switch is bad you will now see the red light on and the oven will work. Take the switch off and gently pry the 4 posts back. Remove the pin, gently put it in a vise and put a drop of solder on top of the metal cap. Put the switch back togther, install it and you should be back in operation.
Oct 21, 2007 | KitchenAid KCO1005OB 1400 Watts Toaster...
Black & Decker TRO200 Toast-R-Oven Toaster Oven with Convection Cooking Logo
Top Black & Decker Toaster Ovens Experts
Dave
Dave
Steve
Are you a Black & Decker Toaster Oven Expert? Answer questions, earn points and help others
