Question about Refrigerators
Ge profile refrigerator with bottom freezer not cooling, no display
Fan is not running, Compressor is not running. When plug in after unplugging, compressor clicks on for fraction of a second and then nothing. Temperature display not lit or responsive. Repairman replaced main electronic board and temperature control board and no change. Repairman says its a short in the wiring and could be anywhere -- labor to try to find too expensive -- could take hours -- so buy a new fridge.
  • 237 Answers
SOURCE: side by side not cooling
Couple of things... first need to see if the compressor is really hot to the touch and "clicking" on and off every 3-5 minutes due to high heat (trying to start). If that's what is happening you likely have a "start device" failure (little box on the side of the compressor). If the box is white in color and you pull it off and it makes noise when you shake it (along with little bits of debris falling out) you know it's bad. They make a kit to fix that known problem. If the compressor isn't trying to start but actually runs quietly... check that the cooling coil isn't all iced up preventing proper air flow inside the cabinet (take the panel of the rear inside of the freezer section to check it). If that is all a block of ice basically you likely have a defrost cycle problem (defrost t-stat bad, defrost timer bad, etc.). Other than that you should have a little fan right above the coils to move air around, if the compressor is running and the compressor fan (called condensor fan) is running then this fan (called evaporator fan) should also be running to move the cold air around. If that fan is dead then you will have a nice cold coil but no air flow over it to cool the rest of the refer/freezer properly. Let us know what ya find out.
Posted on Dec 29, 2006
  • 700 Answers
sounds like either your fan is bad or a wire may have burned off of it. Follow the wires forthe fan back to where they make the junction with the compressor wires. when ever the compressor runs your right that the fan needs to run. If you have a meter you could ohm out the fan and see if the motor windings are indeed bad. a reading of infinite would tell the tale.go out and spend 15 or 25 o us and get a new condenser fan motor after you remove your old one and make sure that the one that oyu get is the same. and replace it. Thanks for using FixYa and don't forget to rate this answer please. Happy New Year!!!!!!
Posted on Jan 01, 2009
  • 146 Answers
SOURCE: Evap fan stops running/low cooling, Unplug Frig Evap fan runs
Is there anything obstructing the fan area, ice build up ? It is normal for your freezer to get warm if evap fan is not working, it is essential for it to work :) A defrost cycle should kick on a timer or as needed (adaptive) and there should not be excessive frost buildup that it blocks your evap fan. I would have suggested you unplug your refrigerator for about 10 minutes and see if that resets your control board - if not, then you will need service - either replacing motor assembly or a faulty control board.
Posted on Aug 22, 2009
Testimonial: "Thanks for your help. The control board was faulty. This is what I suspected but I wanted a second opinion before buying the board. "
Sea Breeze
  • 4655 Answers
SOURCE: Compressor & Evap. Fan both work for 12 hours then evap stops
I believe that because defrost is done by the mother control board this is why this is happening the part of the board that controls defrost is malfunctioning and the only way to resolve the problem is to replace the mother board part number WR55X10656 You can find the replacement board at these places below. Sea Breeze
Posted on Aug 25, 2009
Testimonial: "You were right, thanks for your help. The control board was bad. That is what I suspected, but I wanted a second opinion."
  • 1218 Answers
SOURCE: Refrigerator fan running not cooling
Good day,
That is the compressor not running. Could be a bad compressor, or one of it's starting components.
You can remove the start components from the compressor, by removing the cover, and pulling them off the compressor pins.
Any decent sized appliance parts house will test the components, usually made up of the overload protector, start relay, and on some models a start/run capacitor.
If any parts check bad, replace them, if they all check O.K. then you will need the services of a trained service tech.
Posted on Feb 20, 2010
GE Profile French door not cooling 70degrees
The thermostat allows power to flow through to the compressor, evaporator fan and condenser fan. If the cooling system fans and compressor are running, but the refrigerator or freezer is not cooling correctly check for an airflow or defrost system problem.
in other words is there ice frozen all inside if so unplug and take a hair dryer and melt the ice thouroghly
GE Profile French door not cooling Google Search
Feb 04, 2018 | GE Refrigerators
My ge profile refrigerator evaporator fan motor stops while the compressor is running
this is normal as if one compartment is cold enough but not the other compartment the sealed system has a valve in the refrigerant circulation system to channel the refrigerant flow to the compartment that is calling for cooling so that fan will cease operation in the compartment thats cool enough
Dec 14, 2012 | GE Profile Stainless Bottom-Freezer...
Freezer will not freeze. Fan is always running
pull the ref out from the wall remove the back panel and see if the condenser coil is dirty if so unplug the ref clean the coil and place a fan behind the ref for 1 hour to cool the compressor then plug it back up give it 24hours to get back into cycle
Nov 18, 2010 | GE Profile Arctica Stainless Steel Top...
My 5 year old fridge/top freezer ge profile just stopped cooling, motor running but no cooling
First thing I need you to do is unplug pull away from wall and remove the cover over the compressor. Feel the top of the compressor and if too hot to hold your hand on the top leave the refrigerator unplugged until we can decide if this is the start components or another part like a fan not working all the time. I will send a manual and be available for assistance if you want, Thanks, Sea Breeze
Jan 24, 2010 | GE Profile Arctica Stainless Steel Top...
Hello my GE profile is making a clicking sound. and is not cooling
That id the compressor external overload. You need to unplug and let the compressor cool. It's possible a defective start relay, start capacitor and the external overload needs replaced. We may also need to look at a few other things, But for now unplug the refrigerator to prevent damage to the compressor. Sea Breeze
Sep 13, 2009 | GE GDS18LBR Bottom Freezer Refrigerator
My GE Profile bottom freezer and frig's temps are also
has a FF error shown up on your display. If so that is your freezer fan, and if not it still might be the FF motor is running to slow.
Jul 20, 2009 | GE Profile Stainless Bottom-Freezer...
My ge profile fridge won't stay cold. the fridge is at 45 deg.
First things first - pull the fridge/freezer out from the wall, and look at the bottom.  You should see a metal coil somewhere - it probably needs to be cleaned.  Next, somewhere around the compressor (the big bulky thing in the bottom of the freezer) should be a fan blowing on the coil - make sure it is running.  That MIGHT have been the buzzing noise you describe - dirt on the fan blades or the fan hitting something.  Additionally, you can check the fan on the inside of the freezer - if it is stuck and/or not working, the air won't circulate properly, and you'll get pockets of different temperatures in your freezer.
Best of luck!
May 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile Stainless Steel Top Freezer Refrigerator
Check the compressor.
Unplug for 15-20 min. plug it back in and listen for the compressor to start. You will have to be behind the ref to listen and make sure you hear the compressor start and not just a fan running. If you hear a clicking noise then the compressor relay is bad.
Dec 16, 2008 | GE Profile Arctica Stainless Steel Top...
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
88 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
