Front Loader washing machine SAMSUNG WF7708N6W1/XSA door locked flashes door wont open
SOURCE: FRONT LOADER DOOR LOCK WONT OPEN OR JAMMED
On a Bosch wfmc3200uc there is a green plastic string, similar to fishing line, located behind the round panel on the front of the machine. It is attached to the top right of the round black piece. Just give a slight tug this will release the lock.
Posted on Oct 21, 2008
  • 1294 Answers
SOURCE: washing machine door locked indesit WD12X
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Posted on Apr 02, 2009
SOURCE: Maytag front loader washer--door won't open but lock light off
Open the soap dispenser. Look down in front of the fabric softener dish.
You should see a yellowy-green plastic cord (like weed-whacker line). Pull it.
The door should open.
If you don't see the cord, remove the four screws that hold the dispenser lid in place to find it. Just don't lose it when you put the cover back on.
Posted on Apr 16, 2009
GodBlessU
  • 3513 Answers
SOURCE: Samsung J845 front loader washing machine. Error
Hi
An OE error presents if the washing machine has not successfully drained the water in ten minutes.
there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting fixya.com
Posted on Sep 30, 2009
SOURCE: washing machine stops and flashes 4E
1. WATER SUPPLY ERROR – Display shows 4E.
Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
Posted on Feb 23, 2010
Samsung wf8750lsw front loader door wont open
Not sure if you mean when it is fully off or operating, but if you mean that once it is operating the door won't open, then the following applies...
Once a front loader wash cycle starts, the door on a front loader is physically (electronically) locked until the full cycle ends after spin dry. This is to prevent anyone opening the door and letting all the water out in the middle of the wash cycle, which a lot of people try to do to put in more clothing etc.
Apr 11, 2014 | Zanussi F1045W Front Load Washer
Sampsung wf7708n6w1 door won't open!
Your door switch/lock is broken, you need to unplug the machine and remove the top, you can then reach down (tight space) and using a small screwdriver you can pry around the switch and get the door to open, you need to get a replacement door switch for the machine.
Leaning the machine back can make it easier to access the switch.
Mar 06, 2012 | Samsung Washing Machines
Samsung Model WF7708N6W1 Washing Machine, just beeps and then flashes "door". Will not start wash?? Its always needed to be pushed in a little but now just assumes the door is not closed even...
The indications are that the door lock is not working or physically broken/misaligned. Alternatively there is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor probably requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jun 19, 2011 | Samsung Washing Machines
Door wont lock
door won't lock & shows d5 code what do i need to fix it?
Dec 18, 2009 | Samsung WF203ANW Front Load Washer
I put some washing in my samsung J845 front loader the door will not lock before the washing can be done. my husband brought a new door latch due to the other one been burnt out and he put it back on the...
Just bang the door again until the error goes away. The door is not lined up and won't latch properly. At least that is what ours does. I usually slam the door on my machine.
Sep 29, 2009 | Samsung Washing Machines
Oct 05, 2008 | Washing Machines
Washing machine
bottom right corner behind the little door
Sep 27, 2008 | Whirlpool AWM5125/1 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
