Washing machine SAMSUNG WF7708N6W1/XSA door wont open
SOURCE: Door Wont Open
Your washing machine is fucked, and your clothes probably have more chance of fitting your cat than they do you. is your washing machine french...?
Posted on Jan 02, 2008
SOURCE: FRONT LOADER DOOR LOCK WONT OPEN OR JAMMED
On a Bosch wfmc3200uc there is a green plastic string, similar to fishing line, located behind the round panel on the front of the machine. It is attached to the top right of the round black piece. Just give a slight tug this will release the lock.
Posted on Oct 21, 2008
  • 1294 Answers
SOURCE: washing machine door locked indesit WD12X
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Posted on Apr 02, 2009
  • 3230 Answers
SOURCE: Washing machine door wont open
well, Either clip on the door is faulty or its the door interlock in which the door locks into easily replaced by undoing the clip pullling back the door rubber and replacing ..
Posted on May 19, 2009
  • 1382 Answers
SOURCE: door wont open on bosch classixx 6 1400 express washing machine
The "F16" on a Bosch indicates the door is open / unlocked. If it's happening during a wash it would suggest either a faulty door lock, faulty wiring or worse, a faulty main control board. The wash program should halt when this comes up but you should be able to restart it when the door is closed. As the cost of a new door interlock isn't overly expensive. The best way to fix this problem is to purchase a new lock and fit it.
Thank you !
Posted on May 19, 2010
If its a bearing on the samsung wf7708n6w1 is it repairable
Yes and you can either go on amazon or ebay and get a repair manual or try and find a free downloadable one on the net
Nov 19, 2014 | Washing Machines
Service manual for Samsung washer J1045
Go to the Samsung website & put in your model number. I have the same machine. http://www.samsung.com/au/support/model/J1045IW1/XSA
Jun 05, 2012 | Washing Machines
Sampsung wf7708n6w1 door won't open!
Your door switch/lock is broken, you need to unplug the machine and remove the top, you can then reach down (tight space) and using a small screwdriver you can pry around the switch and get the door to open, you need to get a replacement door switch for the machine.
Leaning the machine back can make it easier to access the switch.
Mar 06, 2012 | Samsung Washing Machines
Samsung Model WF7708N6W1 Washing Machine, just beeps and then flashes "door". Will not start wash?? Its always needed to be pushed in a little but now just assumes the door is not closed even...
The indications are that the door lock is not working or physically broken/misaligned. Alternatively there is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor probably requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jun 19, 2011 | Samsung Washing Machines
My samsung washing machine indicates the door is open yet its closed whats wrong
the door switch is broken or a wire has come off take the switch unit out and check its connected then check it to see that its working if you dont know how to take it to a service shop they should test it for free and tell you if it needs to be replaced then you can order one from your nearest samsung auth repairer.
hope this helps
merry christmas
please rember to rate this advice thanks
Dec 07, 2010 | Samsung WF337AA Front Load Washer
My samsung mp3 went though the washing machine and wont turn on.
Might be a lost cause, but you could try putting it in a bag of dried rice. Maybe for a day or two. You should have done this right after it came out of the washer so I'm not sure it will do anything. It's worth a try though.
Jan 17, 2009 | Samsung Yepp YP-T9 Digital Media Player
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
