Question about Drills
Neither my light or motor will come on. - Drills
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Drills Master
  • 102,366 Answers
What make and model drill press?
Posted on Jul 23, 2013
Motor red error light comes on, pump won't turn on
if power to motor bad pump motor if no voltage to motor bad relay
Mar 01, 2015 | Marathon Electric Marathon imPower...
F-03
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board
f1 and f17 share the same light
Jun 21, 2011 | Indesit W 123 Front Load Washer
Indesit wd12 (old) timer just goes round without stopping. door light flashes 9 times, help!
Hi, this is the list of the Indesit wd12 error codes...
Error codes and their meaning..
f01 light 4, motor triac f02 light 3 motor, jammed/ tacho f03 lights 3&4 Ntc fault f04 light 2. pressure sw stuck on empty f05 lights 2&4, pressure sw stuck on full f06 lights 2&3, N/A? f07 lights 2&3&4 heater relay f08 light 1. heater relay f09 lights 1&4 eprom/setup error f10 lights 1&3, pressure switch not sensing f11 lights 1&3&4, pump/draining error f12 lights 1&2, communication error f13 lights 1&2&4, dryer ntc/ fan motor f14 lights 1&2&3, dryer heater f15 lights 1&2&3&4, dryer heater relay f16 N/A f17 light 4, door lock f18 light 3 comms error (3 phase motor) power board
Door flashing 9 times means 1&4 eprom/setup error
Dec 20, 2010 | Washing Machines
How do I determine if my my switch on my Blower motor is bad or if my Blower Motor needs replaced. Right now nothing works.
Disconnect the electrical connector from the blower motor itself. Then jump 12v tol one of the motor leads and induce ground to the other on the motor. If the motor spins, it's good. Then check to see that you are getting 12v and a good ground from the harness side of that connector that you detached from the motor. That will tell you if the rest of the system is working up to the motor.
Sep 23, 2010 | GMC Safari Cars & Trucks
E03 error code
Error Codes
f16 N/A
Aug 09, 2010 | Siemens WTXD8300 Electric Dryer
Hunter fan model 25706 both the lights & fan have stopped working
mcdevito75 here, VeryGood question, very good, here we go, ------ First a re-set for the motor, I really don"t know but if there is it"s on the motor itself, you"d have to un-screw the cover just at the ceiling and let this cover slide down the chain Attached from the ceiling to the fan itself. and check the motor itself for a reset swtch, usually a red bitton. Now!! true, if the fan motor is bad it could affect the lights, here"s how, the wall switch supplies electricity to the fan motor and the pull chain on the motor turns the fan on, from the motor itself to the fan lights another wire also from the fan motor goes to the fan lights, SO!! if the fan motor is no good it won"t allow electricity to go on to the fan lights. Maybe you Fan motor is just stuck, specially if you haven"t used it in a whlie, with the wall swiotch on and fan speed on low try to gently move the fan blades them selves. If not you may have to repalace the fan.
Jul 18, 2010 | Hunter Ceiling Fan Light Switch Control
Drivers window wont go up
Either the motor or the switch is bad.
Put a test light on the motor connector from the door
operate the switch. If you use an LED test light like they sell at walmart, it lights up red and green.
Up will light one color and down will light another color.
If it does not light up or it only lights one color, replace the switch.
If it lights up red one way and green the other or the standard bulb test light lights up both directions off the motor connector when operation the switch,
Replace the motor in the door.
Mar 21, 2010 | 1992 Pontiac Grand Prix
My heater isnt blowing out any hot or cold air how do i fix problem if i hit blower motor sometimes it will kick on but onlt on high
The blower motor needs to be replaced. Also if it only blows on high the blower motor resister block may need to be replaced as well.
Feb 25, 2010 | 1997 Chevrolet C1500
2000 dodge dakota sport blower motor won't work
Hi my name is Allen!
This is a very hard motor to get out!
This will save you time, if you have a test light and jumper cables, hook the jumper cables to the battery, then hook your test light to the positive side of the jumper cable, turn the ignition key on and turn the blower motor on. Next at the blower motor connector touch the test light to the negative side of the connector if the test light, lights up you have a good ground. NEXT; move the test light to the negative side of the jumper cable and test the positive side of the connector if it lights, you have power coming to the motor, if you have both power and ground you need to replace the motor, if no light on one side you need to repair the one that doesn't light up.
For further assistance contact me at FixYa!
Dec 21, 2008 | 2000 Dodge Dakota Quad Cab
Drills Logo
27 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
