Question about managemylife.com
Motor and light won't turn on with switch. - managemylife.com
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • managemylife... Master
  • 102,366 Answers
What make and model device?
Posted on Jul 23, 2013
It will not turn on. When I unplug it and plug it back in the start light is constantly blinking. I checked for error codes and the 4 lights blink 9 times and the start button blinks 14 times.
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=MhVUEhngZMg
https://www.youtube.com/watch?v=9xD7lCXJ0ZM
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
Kenmore Whirlpool Dryer Won Start Easy Fix What to Test When Whirlpool or Kenmore Dryer Won Start or Run Kenmore Whirlpool Dryer Won Start Easy Fix Troubleshooting Why Your Dryer Won Start PartSelect com
Nov 09, 2015 | Kenmore Dryers
I have a 2004 Dodge Neon and I just replaced the battery and for some reason sometimes when I'm running a lot of errands when I turn it off it won't turn on again. It won't even make any noises...
Something is wrong in your start circuit. From battery to ignition switch, and ending at the starter solenoid. You would have to start checking for where power is lost between the switch and the starter. If you have power to the starter solenoid on the small wire at the starter (can check with a test light while someone holds the key in start), then the starter would need testing.
Jun 08, 2013 | Cars & Trucks
05 Honda Pilot Wipers won't turn off
Your switch is probably gone bad.For the time being you can yank the wiper fuse till you get it looked at.
Mar 17, 2013 | 2005 Honda Pilot
MY PLYMOUTH GRAND VOYAGER 'S HEADLIGHT'S AND DASH LIGHTS WORK, BUT THE ENGINE WON'T TURN OVER. THERE IS NO SPARK COMING FROM THE ELECTRICAL WIRES.
When you say no spark, are you talking about the spark plugs, or just the general wiring?
If the engine won't turn over, then it isn't moving, and if it isn't moving then you need to check the following in this order:
1) Does the battery have power i.e. around 12.4 volts or over?No? Charge, test or replace battery.
2) Do the car's head lights dim considerably if turned on when attempting to crank? Yes? Possible lack of battery charge or faulty battery.
3) Assuming the battery is fine, can you turn the dash warning lights on and off with the key? No? Faulty ignition switch.
4) Is there a click sound when you turn the key, but no starter motor spin? Check starter motor connections or replace starter motor.
If none of the above prove to be of help, then please report.
Oct 31, 2012 | Plymouth Cars & Trucks
My heater/ac fan sometimes won't work. What do I check first?
$24the AC light does not light until you turn the fan on, that is ok, the issue with your fan only working sometimes is more than likely a faulty blower motor, in some cases it is the switch, when the motor does not turn on try tapping it and see if that makes it work, if it does then it is the motor.
the switch at autozone is part number SW295 and is $16
the motor at autozone with the blower wheel is part number PM136
cost is $24
Sep 29, 2012 | 1998 Pontiac Grand Prix
Passenger window won't go up
When you press the window switch button for the passenger door window turn on the dome light at the same time, carefully watch if the dome light dims slightly, this means the switch is ok and the passenger window electric lift motor is defective. You can also try stricking the bottom of the door while holding the switch down, this may cause the window motor brushes to unstick and the window will work for awhile again.
Nov 01, 2011 | 2000 Ford Windstar
1996 buick riviera heater blower won't run. I jumped the motor and it runs. Turn on the switch and it won't run
you have a piece of solder broken off the controller of your hvac unit, causing power not to get to the blower motor it self. take test light and see if you have power at the blower motor. check and see if you have continuty or brake between the power wire at the blower motor and at the hvac control unit. if wires are good then the problem will lie in the hvac control unit. check and see if the blower is working at all speeds, if it works on some speeds thens the blower motor resistor.
Sep 29, 2011 | 1996 Buick Riviera
Kenmore 70 Series Dryer won't turn on. I don't think it is a door switch problem because when I hold down the door switch to make the dryer light turn off, the dryer still won't start. I...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 19, 2011 | Kenmore Dryers
My Shark 7133 slowed down while sewing and stopped. The handwheel won't turn at all. I cleaned the bobbin area but it still won't work. The light switches on and the machine motor reves up but...
Slacken the stop motion as if to wind a bobbin and press on the foot control, if the motor runs really fast then you have either thread stuck in the bobbin case area or you may need to oil the machine
Sep 01, 2011 | Euro-Pro Shark 80 - 7133
I just replace a T101 with the same timer. The old one stopped turning. The new one has the same problem. It is getting power because I can manually switch on the pool pump. The timer just won't...
The switch for the pool pump does not necessarily run from the same power as the timer motor...
Check for timer motor rated power on the first two terminals that run the timer motor...you may not have proper power there...you may have 120v but not 240 volt...
heatman101
Aug 12, 2011 | Intermatic T101 - 24 Hr. Dial Time Switch...
managemylife.com Logo
14 people viewed this question
Top managemylife.com Computers & Internet Experts
thinksewfast
Steve
Paul Bade
Are you a managemylife.com Computer and Internet Expert? Answer questions, earn points and help others
