Question about Maytag Skybox Beverage Vendor
Skybox Dispenser Starter
I have a Skybox that along with everyone else seems to have a problem starting. I have tried the erp410 with no luck and also have ordered the replacement part #4387535, which came with a wire and two small pieces. I have no idea how to install this. The connection at the back of the skybox has a three prong device I had hooked up to the erp410 but I can't figure what goes where with the new pieces. Help. I really don't want to take this thing out back and shoot it.
  • 1462 Answers
SOURCE: We've got a Maytag SkyBox
make a note of the gas type used and all the numbers and codes on the compressor. a good refrigeration spares supplier will be able to give an alternative. replacing a compressor is not a diy job
Posted on Aug 23, 2008
SOURCE: water filter in fridge leaks
if the filter froze, its probably cracked the housing.
Posted on Sep 15, 2008
tborn6
  • 700 Answers
SOURCE: skybox wont dispense
look for ice blocking the door on the unit and causing it not to fully open , good luck
Posted on Jan 08, 2009
SOURCE: Skybox parts # 4387535 installation issues
You don't need to keep the round metal piece or the black wire that you take. The replacement part (flat one) is installed in its place. Put it in first, attach the green wire to it, and then put the two prong piece and install the wires (blue, white and brown) as you took them off the original part.
Posted on Apr 20, 2009
  • 13 Answers
SOURCE: Look for a Service Information on a Maytag Skybox MBV1976AAP
Go to Parts Direct.com and type in your model #
Posted on Jun 29, 2009
I do not have a skybox problem ... I was looking at Starter relay information and skybox guy posted starter relay info ... I decided to pay for help ... Frigidaire Gallery side by side DFRS26ZSHB2 ... no...
If it's not cooling and the internal lights and fan are working, then the problem is either the start relay or the overload relay. I checked the model number you posted and I didn't get any information for the number. Please double check the number that is posted inside the unit. In the mean time, take a look at this relay kit. It is a combination start relay, run capacitor and overload relay all in one. Usually the start relay will run you around $25.00 alone so this is what I use to repair this type of problem at a fraction of the cost. Again, please check that model number again and I will get you the pricing for the individual parts. It is best to replace all the relays if one goes out.Here is a link to the ERP410 relay kit.
Regards,Richard
Dec 09, 2011 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag skybox stopped cooling Skybox stopped cooling. Sounds like the relay will kick on briefly and then click off. Everything else works. I took the back panel off and could hear the relay clicking on...
The relay on your box is damaged.. You have to get it replaced.. Not to be tried by a novice but if you have some experience in electronics it can be fixed by you. The relay costs around 75$. Good luck!
Mar 26, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
The skybox doesn't cool anymore
How old is the unit,the sealed system may still be under warranty.Call Maytag first.
Aug 31, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Hi my skybox stop cooling
The SkyBox operates with two individual systems. The dispenser assembly, the LED indicators and the circulating fan operate on a low voltage circuit. The circulating fan runs anytime the SkyBox is plugged in.
The cooling system operates on 120vac. The cold control inside the beverage compartment is an on demand switch that sends 120vac to the compressor when cooling is needed. There are no parts available for the compressor, so if it determined that power is reaching the compressor, the windings are ok, a 3 in1 hard start kit (Supco URCO210) can be installed by a qualified service technician.
Mar 16, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag Skybox has stopped cooling
the whirlpool part is the oem part and is the best part for your repair it should replace wire for wire and require very little instruction. the 3-n-1 will cause premature failure of the compressor and is not recommended. As far as I know there really isnt a service manual available for the skybox. It was a very limited production product that didnt stay available for very long. thnaks Peyton
Mar 02, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
CAN A SKYBOX 'MAYTAG' BE PERMENENTLY INSTALLED OUTSIDE
The Maytag SkyBox is not a commercial vending machine. It is designed for INDOOR use only. The possibility of electric shock is likely from a unit that has gotten wet. In addition, the electronics are not designed to withstand the outdoor elements.
Aug 10, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag Skybox Beverage Dispenser Not Cooling
Sears.com is selling skybox parts. Go to appliance and parts and put in the model number of the skybox it is either mbv1976aab or mbv1976aap -- you can find this on the back of the skybox. It might have the part you need.
Apr 27, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
I just replaced my in-pieces starter relay and thermal swich with a Whirlpool 4387535 kit. My Skybox has been working fine ever since.
Note I had the same symptoms as other posts of the compressor turning on/off continuously (but no cooling)...I believe what was happening is that the starter relay would allow current to flow to initially start the compressor, but would never stop providing current to it after it had already started (as it should) thus in a few seconds the thermal switch would sense this and trip / remove power to the compressor...then this cycle would start all over once the thermal switch cooled down again and let power back to the compressor...
This kit is evidently the newer style of what is on the original Skybox compressors (functionally speaking)...the new starter relay looks and installs like the old one, but the thermal switch is different and you need to remove the old one (follow the black wire on the top post of the compressor back a little to a small black round thing with a flexible metal piece inside). The good news is that once you remove it, it already has the correct spade lug on the wire to plug directly into the new thermal switch which sits right on the top lug of the compressor above the starter relay.
Note I'm not a service tech, just a Skybox owner who was/is tired of Maytag disowning this product and calling it a "throwaway" when any part of it stops working (and all local authorized service centers laughing when asked to repair one).
Continuing on with my rant a little, I also see other posts on the internet which also state "throwaway" when you actually have a bad compressor because you can't get direct replacements anymore - my friend who does AC work on the side said he most certainly could put another compressor in there from probably just about any other mini-fridge...he just noted that it is a small place to do it so the replacement compressor form factor will have to be considered. He stated you may get a little more or less cooling efficieny but who cares if you really want to keep your machine working that you can't buy anymore (nor get a close alternative).
Mar 13, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag skybox cooling
Is it cooling at all? Do you hear the compressor start or just a buzz for a few seconds? This sounds like a compressor or compressor start relay failure. Unplug the machine. Access the compressor and remove the relay that is plugged to the side of it. Shake it and see if it sounds like there are a lot of loose pieces in it. Inspect it for burned spots. If you find either one of these, it is bad. If it doesn't rattle or appear burned then the compressor is probably bad. Even if it seems ok, I would try a new one on it anyway. They aren't usually very expensive. If the relay is not the problem, check your owners manual for the warranty info. The compressor may still be covered by warranty even if the rest of the unit is out of warranty.
Oct 10, 2007 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag Skybox Beverage Vendor Logo
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
