Question about Clothing Accessories
Trying to find out how old and what this belt buckle is worth?
    Master:
  • 519 Answers
You can try to search in Amazon or ask in forum
Amazon com YELLWWORS 2 Pack 10ft Extra Long Denim braided Charging Cable...
Posted on Dec 28, 2016
    New Friend:
No photo is showing.
Posted on Aug 19, 2013
How do I remove front seat warning screen?
Are you trying to get it to turn off? If so, the actual lap belt connection is a switch that closes when you push in the buckle. You can test the switch by placing a butterknife into the buckle to depress the switch, if it turns off the overhead lap buckle might be worn or the actual harness is worn out. Hope I made some sense. You can buy good used lap safety switches from crashed cars at junkyards, make sure you take your old switch and a picture of the buckle for a proper mate.
Feb 20, 2016 | Seat Cars & Trucks
Tip
Middle seat belt buckle tip for booster seats, car seats, and large humans.
In trying to fit a booster seat into my 2004 Honda CR-V, I realized that the CRV has the belt buckle in the middle of the seat. This is a big problem for someone using a child seat in the middle seat as the buckle receptacle is completely covered by the booster seat. I thought about buying an extender but realized it wouldn't completely solve the problem. After much thought I came to the conclusion that the buckle receptacle could be moved to a new location without compromising any safety of the belt. I first pulled the buckle receptacle all the way out and then cut the fabric to enlarge the hole from which it protrudes from the seat. Then I pushed it through the hole and back into the seat with the head pointing towards the window and outer edge of the seat. After flipping the window seat out of the way I was able to peel the fabric away from the bottom edge of the middle seat enough to reach in and retrieve the belt receptacle. It was a little tight but I was able to buckle the belt and use the seat belt to pull the receptacle through this new "hole" and VOLIA the belt receptacle is now in a better position to the side of the middle seat. You can now used a booster or car seat or put a fully grown human in this seat and buckle with ease.
on May 20, 2015 | Cars & Trucks
How do you reverse the swiss gear reversible belt
While gently pulling the buckle away from the rest of the belt, rotate the buckle 180 degrees.
Sep 14, 2014 | Swiss Gear Mens Genuine Leather Reversible...
Broken seat belt buckle
If I had the problem I would look at a junkyard or on line at e-bay for a replacement. You will need to get the buckle and the belt that it is attached to that goes down to the floor down through the crack in the seat.
Remember the buckle receiver is made for the certain belt in the front and rear seats. I have often tried to put the wrong belt in a buckle and it would not fit. ( Example: the right belt goes in the right buckle.)
Be blessed.
Nov 08, 2013 | 2002 Nissan Xterra
I'm looking for a truck looking buckle for my dad's belt, he is a truck driver
Check out these 2 websites:
http://www.bucklesofestes.com/trucking.htm
http://www.buckleshop.com/trucking_belt_buckles.htm
Jan 10, 2013 | Clothing Accessories
2003 deville seatbelt will not engage
  • Hello again, sometimes them belt buckles get old. You can open that buckle up and sometimes work them little hook's with some WD-40 or and good bolt breaking lubricant. You may be able to save the buckle with just some lubricant. Personally, if giving that much trouble I would replace the buckle itself. Not to hard really.
Regards,Tony
Oct 08, 2011 | 2003 Cadillac Deville
Seatbelt on passenger side want work
sounds like you have a buckle failure....this is the removal procedure...
  1. Remove the front seat.
110881806
  1. Disconnect the front safety belt buckle electrical connector.
110881807
  1. Remove the front safety belt buckle.
NOTE: The front safety belt buckle retaining bolt is part of the safety belt buckle and should not be separated.
Installation
110881808
  1. To install, reverse the removal procedure
Aug 11, 2011 | 1989 Jaguar XJ6
1992 cadillac deville, driver's side seat belt
OK, I had the same problem with my 1990 Cadillac Deville. Had to go to a junk yard where they gave me the entire bolted on assembly. I got a 3/8" impact wrench and unbolted the belt buckle from the frame, and did the same to the one on the assembly they gave me. After that my buckle worked great. The color even matched the old one.
Jul 08, 2010 | 1992 Cadillac DeVille
Bicycle type: bodyguard ergocycle 955 The buckle on the tension belt broke this is an old bike but I LOVE IT! Any suggestion ore help as to where i can get a belt and a buckle from is greatly...
I have the same issue. I love this bike and want to fix it. Did you get any help on where to find a new tension belt and buckel
Sep 10, 2009 | Cycling
Clothing Accessories Logo
736 people viewed this question
Top Clothing Accessories Experts
Da Doc
Tom Chichester
Bill Boyd
Are you a Clothing Accessory Expert? Answer questions, earn points and help others
