Question about Boating
1985 johnson 85 hp outboard bogs under load
Ran great all speeds for about an hour and then started bogging out under load. restarts and idles fine...
    Sergeant:
  • 352 Answers
CHECK IGNITION COIL OUT PUT AFTER THEY HEAT UP. A WIRE CONNECTION (INTERNAL) COULD BE SEPERATING, NOT MAKING CONTACT AFTER HEAT EXPANSION
Posted on Jul 24, 2013
captainjeffq
  • 52 Answers
SOURCE: 1974 60hp johnson outboard won't run on full throttle.
Carbs probably need to be cleaned and re-built. Common problem in outboards that havent been run in a while
Posted on Apr 13, 2009
  • 5575 Answers
SOURCE: We have very little reverse any thing above idle
There are two things to look for. With the motor off disconnect the shift cable. Pull the boots off the plugs so the engine can't kick back. Grab the shift lever directly on the motor and pull it in the direction reverse is. Turn the prop and you should be able to feel reverse click in. If you just barely feel it "tick" the gears, the shift rod inside the housing is not adjusted. If the reverse "bites" into place as good as forward then leave it is that position. Next, line up the shift cable but DO NOT connect the end with the shift lever. Put the cable in reverse and you will see a gap from the old setting to the where it has to be to work correctly. Then its as simply as adjusting the shift cable to match the lever.
The second possibility is the rubber hub in the prop. It could be slipping. But usually its gone in both directions when this part breaks.
Posted on Jun 27, 2009
  • 23 Answers
SOURCE: how do you set floats on a 60 hp johnson
Hold the carb in your hand in the position it is in on the motor the float and the carb body should be in line with each other. What year and what type of motor,these directions hold true for 90 percent of outboards. Jim OMCRetired Mech
Posted on Jul 07, 2009
SOURCE: 30 hp johnson outboard motor trys to start. It
1985 30 hp johnson used a cdi system(solid state, no points) check the power pack.
Posted on Mar 09, 2010
  • 64 Answers
SOURCE: My 1999 150 hp Johnson outboard skips at idle and
Fuel mix is a common cause of this kind of performance. Take special care to follow the manufactures instructions on fuel mix, most modern outboards run on100 to 1 while it is easy to continue an older mix like 50 or 33 to 1. Sometimes the mix is written on the engine cowl.
Cheers, Timo
Posted on Apr 29, 2010
How do you advance idle rpm?
Hello R Lynn Johnson,
This question is submitted under Cars & Trucks?
Timing and Idle screw... I don't think so...?
Actually sounds like you have been adjusting the CHOKE...
I hope you are COUNTING TURNS... Because what you are describing about "timing" certainly does NOT sound like you are working on any car I've ever seen.
It would be wise to set everything back where you started...
DISCLOSE WHAT MAKE, MDDEL & YEARS...
(engine & transmission)... you are fiddling with and PERHAPS WE COULD STAND A CHANCE OF TELLING you WHICH SCREW is your idle speed screw (if any).
Else I would strongly recommend you buy the books for your car and study up...
Oct 17, 2016 | Johnson Evinrude Wiring Harness, 89-90...
What will make a johnsonew 50 hp out board motor bog when under load
Evinrude 50 HP Bogs at WOT - MarineEngine
www.marineengine.com > ... > Johnson Evinrude Outboard Archive
Aug 6, 2002 - 17 posts - ‎3 authors
83 50 HP Evinrude - sat out in weather for 4 yrs. Been cleaning ... At WOT, she bogsdown. Up to. ... Yes, this boat/motor is new to me. Actually ... Mercury 50 1987 bogs down when full @ full throttle
Sep 12, 2013
Motor Runs great bogs down under load.
Jun 23, 2011
1984 Johnson 70 idles but won't go
Jun 1, 2011
Johnson 70 hp no power under load Update
Oct 30, 2006
More results from www.marineengine.com
motor bogs down at full throttle Page: 1 - iboats Boating Forums ..
Dec 09, 2015 | Cars & Trucks
1992 60 hp motor bogs under full power????
try priming the fuel bulb when it boggs down and if it speeds up then replace fuel pump diaphrams etc and clean carbs and balance to start a fresh ! fuel tank clean ?
Jul 24, 2014 | Seloc Johnson Evinrude Outboards 65-300HP...
1985 johnson 85 hp outboard troubleshooting
You can use auto scanner to check the engine system. Make sure i don't fault codes.
Jul 23, 2013 | Cars & Trucks
85 xj700 runs rich, terrible mileage, and "bogs
Is there an air fuel mixture adjustment screw? I'd try lookin for one and adjust it a little and see what happens. Sounds like your mixture is way too rich. A more lean mixture won't bog down, but too lean of a mixture will bring your idle speed up too high
May 28, 2011 | 1985 Yamaha XJ 700 S Maxim
93" 115 H V4 Johnson outboard motor will start and idle fine
your carburetors might be dirty blocking flow to the high speed jets causing it to bog down
Jun 29, 2010 | RTO Outboard Motor Bass Fishing Boat Rod...
How do you set floats on a 60 hp johnson
Jul 06, 2009 | Boating
Boating Logo
132 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
