Polaroid DVC-2010 unresponsive
I have a Polaroid DVC-2010 and if i leave it on for a while then turn it off the next time i go to use it the green light turns on quick for the vcr then you hear a click and it turns off. Instead of the time the clock just has --:-- and no other lights are on not even the red light from the digital audio. No buttons work the only way to turn it off is to unplug it and then it continues the same process. Please help.
  • 1689 Answers
SOURCE: Insignia 42 inch TV won't turn on
The power supply is in the protect mode. There are many things in the set that can cuase this. Most likely there is a short on one of the circuit boards, or the power supply itself has failed.
You will have to have the set serviced in order to get it going again.
Jerry G.
Posted on Jun 03, 2008
  • 259 Answers
SOURCE: viewsonic 32" N3250W LCD TV won't turn on
by what you say it sounds like the power switch but i am no expert when it comes to tv's hope this helps regards Jim
Posted on Apr 18, 2009
  • 7 Answers
SOURCE: tv wont turn on
Posted on Aug 31, 2009
SOURCE: LG 42 LCD no sound or picture
Did anyone find out the solution for this??????? I have the exact same problem with my LG 32 LCD. I only had it for a year and a half, and the green light blinks a few times and it shows no picture. Not even a red light when the tv is off. The same thing happened a couple weeks ago and by some miracle it started working again.
Posted on Nov 22, 2009
  • 1591 Answers
SOURCE: I have the Philips 50
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it on, it may eventually stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for 5 mins, then try.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
utube.pngYou-Tube video "Mm51C_RDIZE" placeholder
utube.png You-Tube video "BNHHrgX_6cs&feature=related" placeholder
(do not delete)
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Posted on Mar 25, 2011
DVD player is not playing on Polaroid dvc-2010
clean the laser is all you can do unless you have a widdle lab like me
Aug 17, 2014 | Polaroid DVC-2010
Im trying to program my remote so all my compents will work on one remote but dish network doesn't have the code for my polaroid vhs/dvd player. The model no is dvc 2010. If anyone has the code please post...
Try these steps for progamming the remote, if this doesn't help there is a compatibility issue.
  1. With the desired equipment on, press and hold the correct Mode button until all mode button backlights illuminate (about 3 seconds), then release.
  2. For AUX mode Power Scan ONLY: press 0 for a TV, press 1 for a VCR/DVD, press 2 for any other device, then press *.
  3. Press and release the Power button.
  4. Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
  5. Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
  6. To verify the code works try several different functions for that equipment.
Daniel Busa
DISH Network Customer Service
Jan 18, 2011 | Polaroid 1720-7 Remote Control
Digital video camera DVC-00725F 2 years old I think its the battery- was holding charge for a short time now not at all -
Rechargeable batteries don't last forever, unfortunately. Lithium ones in particular can have their life shortened if you allow them to discharge completely. This camera uses np-60 (Fuji type) batteries. I recently bought a couple of these off Amazon (Polaroid branded!) for less than one pound ($2) each, so there's your solution!
Nov 03, 2010 | Polaroid Cameras
Is there a way to reset the Poloroid DVC-00725F, I seem to have lost my menus, just a black box appears with no text ?
Well, it didn't fix my camera, but when I plug it in to the USB port, and hold down Enter, Play, Record, and the Pic/Shutter top button simultaneously for 5 seconds or so when the camera boots, it goes into test mode. At which time it goes through tests, but doesn't really fix anything. Good luck to you.
It should say: pcba test program 2 times d50h-polaroid-g0911n
then prompt you to hit the power button
Oct 24, 2010 | Polaroid DVC-00725F Flash Media Camcorder
Turns on, but buttons don't respond.
If you have a remote,just press down on the volume up button and roll it around in circles.It sounds stuck and that sometimes will help unstick it.Also do it on the TV's button.If that doesn't work please let me know and we'll try something else.Good luck!
Aug 01, 2010 | Polaroid FLM-3232 Television
I recently received an x530 from a neighbor, and it didnt work.
You say that the lens moves a little, this is the case when required power is not sufficient,.
Remove the battery, clean the battery connecting terminals, recharge the battery and try it.
Jun 17, 2010 | Polaroid x530 Digital Camera
Where do I find an inexpensive (under $25) Universal Remote control that works with Kodak VCR/DVD player (model #DVC2010)? Is there a website that I can do a search for a compatible remote? I've alr
Radio Shack should be under $25 and there Remotes are usually made by RCA a division of Phillips, RCA is the Mfg of Most Polaroid/Kodak Audio/Visual equipment. Unless it has a lot of features, I'm sure it only uses a 3 digit remote code, If you need  a 4 digit remote code Remote it might cost you more than that. make sure you take the model # with you to Radio Shack & they will be able to tell you if you need a 3 or a 4 digit remote code remote. : )     Jay..........
May 29, 2009 | Polaroid DVC-2010
Polaroid DVC-2010 says ''lock''.
I just read through the online manual. I tried their solution, and it worked! Just hold down the POWER button for about 8 seconds straight ... it unlocks! Simple as that.
Mar 28, 2009 | Polaroid DVC-2010
Televison & Video Logo
Top Televison & Video Experts
