Question about Panasonic TH50PX600U 50 Inch Plasma Flat Panel HDTV
Firmware update My Plasma tv has failed to start and it blinks two times to indicate the error code. Where can I find the error codes ?
5 Suggested Answers
  • 93 Answers
SOURCE: 3 months ago Led blinks 7 times now Led blinks 6 times
Sorry to hear that. You could fix it with Best Buy or the warranty service repairman recommended by Panasonic.com
I have a client that had used one of the panasonic repairman to fix the same problem that you have about a year ago,the TV is good ever seen.
I am in the A/V installation business, my recommendation(Pioneer Kuro Plasma TV or Sharp LCD.)Very good track records from my clients.
solutiondoct
Posted on Nov 06, 2008
tvservice306
  • 458 Answers
SOURCE: Panasonic TH-C42HD18 Blinking Power LED (7 times)
NEED SD OR SU OR SC BOARD REPLACED
Posted on Sep 21, 2009
  • 8457 Answers
SOURCE: My Panasonic Plasma Tv is not turning on. it tries
Ur power supply board it dead.Take the tv aparts.U have tools,like soldering iron and solders? U know basic soldering and electronics?U can look around all the boards for those capacitors that bulges,pup up replaced these capacitors should get ur power back.Or tries these Websites Shopjimmy.com or Ebay.com to buy a whole refurbish power supply to replaced.
Posted on Apr 16, 2010
gopakumarg43
  • 75169 Answers
SOURCE: plasma went out... red light blinking 4 times...
It sounds that the Y-Sustain or its driver sections has the fault. Visit this site for more details. Faults with Panasonic Plasma TVs are described in detail there. Blinking indications and faulty boards will be almost same to most of the Plasma TVs. Check this link, and select the site. Pull up older posts there. Sometimes, ads related to each post might help you to get details of availability of spare board.
Posted on Jul 20, 2012
TOSHIBA MODEL 32RV530U WILL NOT TURN ON YELLOW LIGHT IN FRONT BLINKS 3 TIMES
This could very well be a problem with the power supply not allowing the TVs to start up but can also be caused by a problem with the TVs firmware. I would suggest downloading the firmware and following the steps from the following link. The download and steps are in the firmware tab after clicking the link. Be sure that even if you have no picture while applying the firmware update that you under no circumstances remove power from tv for at least 15mins. This is to ensure the firmware completely loads. If you remove power while it's still updating the board may be corrupted. http://support.toshiba.ca/support/ceg/center/en/index.asp?p=32RV530U
Jan 13, 2017 | Toshiba REGZA 32RV530U LCD TV
TH 42PV8H A MY TV POWER NOT ON RED LED 2 TIME BLINKS
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Mar 16, 2016 | Panasonic TH-42PV8H 42 inch MultiSystem...
I have a 2009 panasonic tcp50x1 plasma tv and im getting a 10 blink error code. Is that the main board or power supply board issue?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Oct 14, 2015 | Panasonic TCP50X1 TCP50X1 50"" Plasma TV
What part of an HDTV has the firmware for a LCD tv by toshiba 42HL67 no public firmware for flashing want to replace board
Oct 09, 2015 | Toshiba Televison & Video
LG symbol on screen flashes on once and red light blinks twice slowly, no sound either. What does 2 blinks indicate ? please advise
Corrupted firmware. A firmware update is necessary. These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Sep 21, 2015 | LG Televison & Video
I have a pioneer PRO110-FD plasma tv with a 2 blink error code. What does the 2 blink error message mean
Jan 04, 2015 | Pioneer PRO-110FD 50 in. HDTV Plasma TV
Red light blinks on panasonic 50" Plasma TV, will not turn on
These blinks are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Oct 11, 2014 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Panasonic plasma tv indicator light blinks 10 times
Aug 12, 2014 | Panasonic Viera TC-P58S1 58 in. Plasma...
My panasonic plasma tv model#TC-P65S1 will not power up the led light blinks 8 times and failed to boot up
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Aug 01, 2014 | Panasonic VIERA TC-P60GT50 60-Inch 1080p...
Plasma Display Starting Up
Could be heat build up in the Plasma display unit. Make sure it has the correct space around it for proper ventilation. Also count the number of blinks on the power indicator it is a code for the reason the unit shut down. On the Pioneer PDP-5060HD I have I was getting 12 blinks on the indicator which indicated a tuner issue. Check your instruction book for info on the over heating problem if it continues. You may have a fan out.
Apr 29, 2008 | Pioneer PDP-5060HD 50 in. Plasma...
Panasonic TH50PX600U 50 Inch Plasma Flat Panel HDTV Logo
26 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
