Question about Zanussi Washing Machines
Error code e54 - Zanussi Washing Machines
    Top Expert:
  • Zanussi Master
  • 12,223 Answers
TEST this steps and fix it. This error code is E54 which is something to do with the motor.What you can try first is pull machine out and take off the back panel. From there you will see the motor at the bottom. Unplug the wiring block from it and start the machine again.
Posted on Jul 23, 2013
How to solve e50 and e54 errors
Hi!
On Electrolux washing machines error e54 means the problem in the contact group of one of the two reverse relays. I would like to help you with the e50 error. What is your model of the washing machine?
May 12, 2017 | Washing Machines
My F1-3000N WNQ treadmill is stop and is showing E54 error, what does this error code mean?
If you wish to get some details treadmill error codes and calibration ; check the site linked here. http://electro-medical.blogspot.com/
Nov 05, 2016 | Exercise & Fitness
What does error code e54 mean
You have not specified Tumble dryer model so I can not say for certain that my answer is correct. Fault codes can sometimes vary depending on the platforms appliances because today some manufacturers release new models twice a year and thay have the absolutlly right to make changes and improve the efficiency of new appliances (also change fault codes).
E54 - means the motor is inoperational.
Could be:
  • Excessive wash load.
  • Voltage too low.
  • Motor/transmission system inoperative.
Dado
Aug 09, 2014 | Electrolux Dryers
What e54 error code mean on an electrolux dryer
Could be:
  • Voltage too low.
Dado
AEG LAVATHERM ERROR CODE E54
In your machine they put in a tech sheet, that will aid you on your error codes.
Jan 14, 2014 | AEG Dryers
How dop i reset e54 error of gestetner 2715?
To rest the error code > press the yellow Clear button then enter 1,0,7 then press and hold the red Stop button and hold till the screen changes. Then turn the main power switch OFF then back ON..... If the code comes back, you may have a thermister that is shorting out. Good Luck
Aug 12, 2012 | Gestetner Office Equipment & Supplies
Ricoh ft 3813 error E54
E54 is a fusing error. You can attempt to reset the code by entering service modes. To do that, you press CLEAR MODES key, then the numbers 1, 0, and 7 and then hold down STOP key. Once in service mode, press 97 then #. That resets the code. Power the machine off then back on to see if it comes back. If it does, then you may need main board or AC driver board.
Mar 14, 2011 | Ricoh FT3713 Copier
Error codes
Try to check the fuser section.
- Check the Lamp
- Check Motor Assembly
Sep 12, 2008 | Ricoh FT5832 Copier
Paper Jam E54
The one crinkled at the end on the left door is the problem.
Since it jammed it stops the whole copying process, ( you were most likely doing duplex)
The reasons for the crinkled paper are
1- the fingers or claws at the exit are worn and catch the paper instead of sliding them out.
2- you are copying something that has a black edge and is getting caught on those fingers ( or claws)
3- The rollers at the exit are in bad shape :
anyway check out this link and go to error codes :
http://checkitright.spruz.net/main.asp?page=dp&dis=592197
Nov 17, 2007 | Toshiba e-Studio65 Copier
Washing Machines Logo
313 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
Chris Hall
Chris Hall
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
