Question about Dryers
Wintair need plastic connector; fan to base
I need the fan blade for a Sunbean aircondition
You can order the parts from this site
http://www.searspartsdirect.com/partsdirect/part-model/Wintair-Parts/Room-air-conditioner-Parts/Model-AW24CR3FHUE/3305/0904032/50031430/00001?blt=06&prst=0&shdMod=AW-24CR3FHUE
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Leave a comment if you need more help.
Thanks for using Fixya.
Aug 19, 2011 | Sunbeam AW24CR3FHUE Air Conditioner
The base where i lock de fan for the cpu it broke in one side the fan is hook only en 3 corners can i buy the plastic base atach to the motherboard?
you can collect from damaged mother board (intrel p4).Youb should go nearest computer technician collected from them.shibuda.jpeg
Hope this helps.
Jan 12, 2011 | EliteGroup P4S5A Motherboard
My wintair window unit stopped blowing. It turns on and cold air is slowly seeping out of it but it's not blowing like it used to. It's only 1 or 2 years old. Is this something I can easily fix?
Hi1!
You would need to check he blower motor capacitor and speeds. Try turning on just the fan to see if it blows faster and more air.than when the compressor is on.
Worst case scenario, your fan motor is failing and needs to be replaced
Good luck!! Rate this post!!!
Aug 14, 2010 | Heating & Cooling
Heating and cooling work fine, but regular fan does not work.
TURN THERMOSTAT TO OFF AND FAN SWITCH TO ON. IF FAN DOES NOT COME ON THEN IT IS NOT RECEIVING 24 VOLTS. TAKE FRONT COVER OFF THERMOSTAT, THEN THE SUB BASE. YOU SHOULD NOW SEE THE COLORED WIRES CONNECTED TO THE BASE ITSELF. NOW DICONNECT ONLY THE RED AND GREEN WIRES AND TOUCH THEM TOGETHER, THERE MAY BE A SMALL SPARK, BUT HOLD THEM TOGETHER, WAIT FOR THE FAN TO RUN, AND IF IT DOES YOU ARE GETTING 24 VOLTS TO THE THERMOSTAT. REPLACE THE WIRES BACK ONTO THEIR CONNECTORS . NOW CHECK THE FAN SELECTOR SWITCH, THE PLASTIC LEVER. UNDER THE LEVER IS A METAL BALL WITCH WHEN MOVED DROPS IN A SLOT ON THE BOARD. SOMETIMES THE BALL DOES NOT DROP IN PROPERLY AND MAKE THE CONNECTION WITH THE BOARD. IF THIS IS THE CASE, MAKE SURE IT SLIPS IN AND OUT OF THE ON AND OFF SWITCHES EASILY AND CHECK FOR WEAR IN BETWEEN THE TWO HOLES. IF YOU CAN'T SEE A GRAY COLOR BETWEEN THE TWO HOLES , THEN IT'S NOT GETTING 24 VOLTS. IF YOU CAN SEE GRAY BETWEEN THE HOLES, THEN PUT THE SUB BASE BACK ON AND TURN THE SELECTOR SWITCH TO OFF AN ON. IF YOUR FAN DOES'NT WORK AFTER THIS, THEN REPLACE YOUR THERMOSTAT.
Apr 13, 2010 | Amana PTH123B35AE Air Conditioner
How do I replace the headlight bulb on a 2000 Ford Escort ZX2?
² Coupe
² Sedan/wagon
2. Open the hood and disconnect the headlamp wiring socket from the
in-line connector. This will make it easier to change the bulb.
3. Remove the protective dust shield
from the housing by turning the
dust shield counterclockwise (when
viewed from the rear).
4. Release clip and disconnect the electrical connector from the bulb.
5. Remove the bulb retaining ring by
rotating it counterclockwise.
6. Without turning, remove the old
bulb from the lamp assembly by
pulling it straight back out of the
lamp assembly and replace.
7. Install the new bulb in lamp assembly by pushing straight in with the
bulb’s plastic base facing upward. Turn the bulb slightly to align the
grooves in the plastic base with the tabs in the lamp assembly.
8. Install the bulb retaining ring over the plastic base and lock the ring
by rotating it clockwise until it snaps into place.
9. Connect the electrical connector into the plastic base until it “snaps”.
10. Install the protective dust shield and lock the shield by rotating it
clockwise until it locks into position.
11. Connect the headlamp wiring socket to the in-line connector.
12. Turn the headlamps on and make sure they work properly. If the
headlamp was correctly aligned before you changed the bulb, you should
not need to align it again.
__________
Feb 03, 2010 | 2000 Ford Escort
Kenmore Humidifier not operating?
Turn the unit off, lift the fan assembly off the base, and push the connector together that goes to the float switch on the bottom of the fan motor. If you hold the switch in with your finger (careful not to get into the fan blades) and turn the unit on, the F indication should go away. F (as in Fill), apparently, means the base has no water. The plastic tube that sticks up out of the base floats on the water and pushes the switch. Put it back together, it should work!
Dec 08, 2009 | Kenmore Humidifiers
How do you remove the base from an AWA LC32G78 LCD TV in order to wall mount it?? I can't find anything in the manual.
normaly has on rear base plastic (nerby where cabes connectors), with a small screw to show another screws atach on the base, take this out to realease base. and find a extra plastic to cover where the base attached.
Nov 01, 2009 | Televison & Video
How do I change the heater fan speed control in a Jeep Liberty (2006)? Speeds 1-2 and 3 don't work, only 4 does.
On the back of the control panel there is a plastic connector that plugs into the fan speed control. You can unplug it and use a meter to find incoming (hotwire) take a jumper or a 6 inch peice of wire and insert it into the spade where the hot wire is wired to. Take the other end of the wire and insert it into the 1st spade in the plastic connector next to the hot wire spade this will let you know that the fan will run at the selected speed. Then pull the test wire out and plug it into the next spade and so on and so on. I am sure your fan will respond step by step , fan speed 1 then 2 and then 3. After you make this test you will know that your fan is ok. You will just have to replace the plastic connector with new spades in it. You should see some evidence of over heating on the old connector. It may be that you only need to unsnap the connector and then reconnet it and it will probably work fine. It has proberly just become partially unpluged. All the other info that I gave you early on was just to trouble shoot it. mike
micmor68@gmail.com
Oct 12, 2009 | 2006 Jeep Liberty
Lost manual for Wintair AP08CK1FDS Portable Airconditional
I have a Wintair portable air conditioner as I bought thru craigslist and it didnt come with a manual so I want to know how to use it.
Aug 18, 2009 | Heating & Cooling
Find a free manual for a Wintair AP-08CK1FDS
You can download a Spanish and English manual at: http://goo.gl/M4zkLIt is in PDF form.
Please leave feedback if this was helpful. Thank you.
Jul 31, 2009 | Heating & Cooling
Dryers Logo
22 people viewed this question
Top Dryers Experts
