Had it running , had it searching it went in the lock mode couldn't do anything with it. It shut off and now will not turn on
    Sergeant:
  • 396 Answers
What does that mean ' had it searching'? Try turning it on with only the power cord, and without the battery, and see if that helps.
Posted on Jul 23, 2013
2008 GMC Sierra pickup. Driving and all of a sudden it shut off then turned back on; the doors unlocked then locked again. Now it won't do anything. Checked the oil and it was empty - no oil at
Running with no oil is death for the motor ( Seized). When the alternator stopped working because the engine stopped the door lock control opened the door locks as it said you were below the required speed to have them locked
Mar 31, 2013 | 2008 GMC Sierra 1500
Two months ago I went through the car wash and my ebrake and battery lights started flashing intermittently heater blower losses strength when I accelerate and the headlights dim. Started idling crappy at...
it sounds like you have a bad ground. follow all your ground wires. should be one to the engine, body, and maybe frame. disconnect them and clean the surfaces with sand paper and reconnect
Jan 20, 2013 | Cars & Trucks
ThMy Dell inspiron b120 couldn't shut down?
Stuck process. Use Ctrl-Alt-Del to see what is not responding, kill the process.
Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. In Startup tab, uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Oct 24, 2012 | Dell Inspiron B120 Notebook
Stove went completly dead during self cean no power door remains locked
Check the breaker for your kitchen even if it isn't flipped, flip it off and on again.. I had the same problem it turned out that my dryer and stove were on the same breaker, so I couldn't run them both at the same time.
Aug 03, 2012 | Samsung Induction Range FTQ307
My maytag range model mer5765ras lock is stuck can not operate anything except stove top We turned off electricity it released but as soon as I shut the door it locked Thank
On something like this I recommend setting the control up into a self-cleaning mode. Let the self cleaning cycle run for about 5 minutes then press stop/cancel. This should cause the lock motor to reset the lock switches.
Oct 18, 2011 | Kitchen Ranges
I was using my Nikon coolpix s205. after taking pictures, it went on standby mode and when i was going to use it again, the monitor was just black and i cannot take pictures anymore. i tried to turn it off...
All I can suggest is 1) Fully charge the camera. and 2) Make sure NO cable is attached to the camera when you turn it on.
Background; Lens motors use lots of power and with a dead battery they do not work very well (stuck) When you have a cable attached to the camera the monitor WILL shut OFF.
May 02, 2017 | Nikon S205 Digital Camera
My computer just went belly up! It is a reconditioned IBM ThinkCenter, a little over 2 years old. It was running normally and then all hell broke lose, cooling fan went berserk sounding like a hair dryer...
you need to clean the heatsink of the processor remove it from the motherboard by turning the lock to counter clockwise to 90 degree only all four lock then pull it up gently check for the thermal paste if it is dry you need to add a new thermal paste before you add make sure that you clean the back of the processor or remove the old paste that already dried out, just a small amount you need to apply, then before placing back the heatsink to the processor make sure you already turn the lock to lock position by turning it clockwise 90 degree then make insert it correctly to the four holes in the motherboard then press the lock down slowly to lock one by one,
Aug 04, 2011 | IBM Computers & Internet
I just purchase Pandigital multimedia novel 7"
It sounds like your in sleep mode. Hold the power button till the display says power off and tap the power off on the display, the charging light will come on and the charging light will change color when it is fully charged. Here is the link to the pdf quick start guide:
http://www.pandigital.net/userfiles/file/Downloads/QSG_%20PRD07T-1_v2.2_09-08-10.pdf
Hope this helps thanks for using FixYa
May 13, 2011 | PANDIGITAL Digital Book 843967071153...
Computers & Internet Logo
11 people viewed this question
David Payne
David Payne
