Question about Sanyo 2.4 Cu. Ft. Compact Mid-Size Refrigerator- Platinum Model: SR-A2480M R
Sanyo Mini Fridge Freezes Everything
No matter how I set the temp control, it freezes all the bottled water we store inside. This is a recent problem and I cannot figure out why other than a malfuntioning temp control.
For me I think you have a problem in Thermostat switch contact. Or the rotary switch was not in good contact point, better check it and if still the same, proceed to check your thermocouple if functioning.
Posted on Oct 21, 2013
5 Suggested Answers
SOURCE: Sanyo Mini Fridge
Same problem - When defrosting and moving away frost had a spray come from the left side of fridge. Can I repair - if a leak and how to add more freon?
Posted on Aug 18, 2008
  • 254 Answers
SOURCE: Sanyo mini refridgerator won't get cold
This sounds to me like your fridge might be in defrost mode. There should be a switch up toward the top of the fridge near the cold setting. It's not always very visible, but feel around for a little round hole. There should be a small, plastic rod sticking out. Push it back in. (If it's out.) If this is the problem, you should hear the compressor turn on and the fridge should start cooling off again. If you still have the owners manual, it'll probably point you to its exact location.
I hope this helps! :)
Posted on Jul 23, 2010
rickead1
  • 1998 Answers
SOURCE: The Sanyo SR 366 does not cool until I turn it all
sounds like a defrost issue What can you do about this. so you get an understanding of what is going on here is a short explaination of how the defrost works in the freezer section behind the freezer panel.
The coils inside the freezer are the only part inside the whole refrigerator that "get cold".The fan blows the cold air from the freezer into the fridgerator side. They need to stay free from excess frost build up so that air can pass through the coils and reach the refrigerator section of your refrigerator. Every eight hours or so, depending on the type of defrost timer or control you have, the compressor and fans will shut off and the machine will go into defrost mode.When the refrigerator is in defrost there is a heater that is tied into the evaporator coils inside the freezer that comes on. This heater is behind the rear panel inside the freezer where the evaporator coils are located. It melts the frost that has accumulated over the course of time. After about thirty minutes the machine comes out of defrost and goes back to normal operation.
Now the air can continue to pass through the coils and keep the freezer frozen and the refrigerator cool the defrost cycle is made up of 4 functioning parts the defrost timer, the defrost heater, the defrost thermostat and the fan .I will go through what each of these do
The Defrost timer Some refrigerators have a defrost timer. This type located on the inside upper ceiling of your frigerator works like a clock. Every eight hours or so the machine hits the defrost spot and that's when defrost occurs Some refrigerators have an Adaptive Defrost Control. This is what makes a refrigerator energy efficient. It varys the length of time it takes the machine to go into defrost. Some models dont have a defrost timer and instead use a control board that works just like the timer it is usually located in the rear of the machine under a metal panel.
Defrost Thermostat
This is the component that controls how long the heater stays on when the machine is in defrost mode. Say the defrost cycle is thirty minutes, the heater may only be on for ten of those thirty minutes on the timer controls. On Adaptive Defrost Controls, when the heater shuts off, shortly after the machine exits defrost mode. Basically if the heater only stays on for ten minutes, the whole defrost cycle will only be about 12 or 13 minutes long.
Basically when the heater comes on, it starts to melt the frost on the evaporator. Once all the ice and frost is gone, the temperature behind the panel will start to rise. Once the temperature behind the panel rises to a certain temperature, the thermostat will break the current of electricity going to the heater. Bam, it shuts off and prevents your freezer from becoming a sauna, or an oven. I'm sure you get the drift. The heater is on the bottom of the evaporator coils and the defrost thermostat sits on top of the evaporator coils. A continuity test can be done ona the defrost heater and when there are only the two wires and there is no connection point to do the test i always like to keep two sewing needles that i use for this test. Simply thread each needle through the half of the wire not all the way though to the other side and you can use them to perform your test to assure that there is continuity in the thermostat if there is not then replace the thermostat
Defrost Heater
Some defrost heaters are a coil of wire in a glass tube under the evaporator coils,older ones are just a curved piece of metal that wraps under the condensor. Works like a light bulb basically. The other style looks like the bake element in your stove. They both get red hot either way and melt the frost.A continuity test can also be performed to assure that the heater is functioning properly as well. Simply go to each side of the heater and do your continuity test
The Fan
Some dont consider this to be part of the defrost cycle but if the fan is not working then the air is trapped inside the freezer and sometimes can cause the same ice up situation which is why I say to always look at the fan first
you can also do an ohms test between terminal 1 and 3 on your defrost timer which will tell if the motor section of the timer is good then you can check between terminals 1 and 4 to by doing a continiuity test which is to the compressor and tells the compressor how long to run if you turn the timer till you hear the click it goes into position to and you can do a continuity test on the heater between terminals 1 and 2 and then you can do a continuty test on these two terminals as well And here is a guide to how your freezer defrosts and some ways to test each piece to assure that they are working in proper order if you have any further questions message me back in order to see if you do have this defrost type of issue you have to remove the rear panel on the inside of the freezer if there is ice you do and please remember to rank how this opinion has helped it allows for me to help others in similar situations in the future Thanks Rick
Posted on Feb 13, 2011
imufo2
  • 3773 Answers
SOURCE: My Sanyo SR-3770s mini fridge is too cold. It is
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
If you need more help, Go here:
http://www.applianceaid.com/procedures.html
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Posted on Aug 19, 2011
I have amagic chef 4.4 cu ft mini fridge. when I turn it on, no matter what I set dial to it freezes everything inside. How do I fix this ?
Hi.
This is a classic example of a faulty thermostat.
If it has a electronic controll system the temp sensor is defective.
Oct 28, 2015 | Refrigerators
Refrigerator freezes water and cola drinks inside it
have the thermostat checked as it appears that it has stopped controlling the temperature you set to
Jun 16, 2013 | Haier Refrigerators
Refrigerator 1/2 temp will not get warmer than 28 degrees
try and replace the thermastat control.
turn both knobs to the off position and listen i the fridge for the cold air damper to close it is located top left side rear of the cabinet in the fridge if the door does not close then you may need to replace the damper
Apr 13, 2010 | Frigidaire FRS26R4A Side by Side...
NO WATER COMING OUT OF WATER DISPENSER ON MY SAMSUNG RS21DCNS/XEU
you either have a kinked water line, or a frozen one. There is a possibility that the solenoid isn't working.
Nov 08, 2009 | Samsung Refrigerators
My daughter's mini fridge has a freezer compartment. Her issue is, if she turns it up high enough so the freezer freezes, the fridge compartment also freezes everything; if she turns it down so that the...
This is a drawback of most mini-fridges. Start by defrosting everything. Then fill ice cube trays with water and keep lowering the setting until the water freezes. Just go a little lower, no more. Fridge should not freeze food. If the fridge stays closed all the time food will freeze. Also if the freezer element gets ice buildup it must be defrosted. Not automatic like home fridge. Most kids today weren't born when the last fridges that had to be defrosted were in service.
Sep 01, 2009 | Refrigerators
My mini fridge freezes everything
Need to replace the termostat.
Apr 03, 2009 | Refrigerators
My fridge stays on and freezes everything inside
not a breathing room issue, if anything that would cause it to shut down and not cool at all, where you got just the opposite, it never shuts off. is it an electronic model, or is there a control knob you manullay turn to adjust temp
Feb 23, 2008 | Sanyo SR-4910M Compact Refrigerator
Fridge area freezing food; water dispensor line freezing
sometimes when the cooler weather comes in you may need to chnge temp setings to a warmer setting to prevent some items from freezing ie: leafy vegetables, water bottles, eggs, etc etc.
now if you are having total freeze up of everything in the ref section then you could have bad temp control or damper assy.
Oct 22, 2007 | Frigidaire GLRS234ZA Side by Side...
Refrigerator freezes everything even on the lowest setting
Is everything really frozen or just the top shelf stuff? You may have a thermistor (temp sensor) problem if the compressor just runs and runs and runs all the time. Take a glass of water and place a thermometer in it for about 3 hours then take a temp. reading. That will let you know what the real temps are. See if you can cause the compressor to kick off and on by changing the temp settings (go to real low for about 5 minutes then back up to high). Let us know what happens.
Dec 24, 2006 | Sanyo SR-3620 Compact Refrigerator
Sanyo 2.4 Cu. Ft. Compact Mid-Size Refrigerator- Platinum Model: SR-A2480M R Logo
192 people viewed this question
Top Sanyo Refrigerators Experts
John Tripp
John Tripp
Steve
Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
