Question about Sony VAIO Computers & Internet
Error beeps Two very quick error beeps sporadically and with no apparent connection to anything I'm doing. Computer working fine.
  • 2 more comments
  • D Auclair Jul 23, 2013
    My memory is fine, the computer is working fine, it doesn't do it only on startup, it is randomly doing it while I'm using the computer and in no specific pattern. It also keeps causing whatever I'm using to zoom in. So if I'm on the web, the page zooms to 115%. Same for Word, Excel, etc. Doubt it's a motherboard issue, it seems like it might be an app that's working in the background that can't stop, no?
  • Lars Olsson
    Lars Olsson Jul 23, 2013
    try shift the memorysticks place.use some caned air gently to blow away possible dust.or invest in new memory.
    why would a memory issue make my applications zoom in???
  • Lars Olsson
    if you made up your mind why ask about advice.
    Brigadier General:
  • Sony Master
  • 3,400 Answers
Http://www.pcmag.com/encyclopedia/term/38515/beep-codes
TWO BEEPS CAN MEAN MEMORY OR MOTHERBOARD.
READ FOR MOORE INFORMATION.
Posted on Jul 23, 2013
Viking fridge top and bottom model#vcbb536rss is beeping sporadically, the display screen is flashing, what is wrong with that? what part we need to check?
high low voltage board were likely not needed
board registers high temp and after a few days of constant high temp alarm will restart
by replacing low volt board all you did is start with empty register also when replacing low volt board they have to be programed for your model
sounds like you need service for your cooling issue
May 31, 2017 | Viking Refrigerators
Fisher and Paykel WA75T65GW1 3 lights flashing and beeps won't go
Your water valves are 24volt,
should read 60 to 64 Ohms on a multimeter.
Your error code 49 is Cold valve faulty in your machine.
1 amp fuse and 1 of the Mosfets on the board are blown.
You need to get a Technician to replace the parts.
Jan 05, 2013 | Fisher and Paykel Washing Machines
2004 monte carlo ss supercharged. The headlights have gone off a couple times for no apparent reason, then I lost blinkers. Very sporadic. I had the blinker assembly changed, but blinkers still go out...
try turning hazards on off n see that makes a difference if so u need new hazard because ur turnsignals are routed through that switch... if not most likely the turn signal stock is bad if playin with hazard switch doesnt change anything
Sep 24, 2011 | 2004 Chevrolet Monte Carlo
I am repairing a computer for a friend. When I start the computer I get a continual short beeps. I have checked connections but nothing shows bad. The computer worked fine previously and I haven't...
depending on the number of beeps and their durations you can search your motherboards bios beep codes which should tell you the general area of the fail
try unplugging and re-seating memory cpu videocard / monitor
these are the usual main culprits
May 06, 2011 | AMD Athlon64 2800+, 1.8 GHz Athlon 64...
When I turn my computer on just a black screen and beeps
the prob is with your RAM only just chang your RAM it will be fine
May 05, 2010 | Apple Computers & Internet
My internet service is working sporadically when it is connected to the D-Link router. Right now I have my computer directly connected to the cable modem and it works fine. When the computer is connected...
You need to update the firmware of your router. Download the latest firmware from Dlink website. You need to hard reset the router, load the firmware, then do another hard reset after you successfully updated the firmware.
Jun 25, 2009 | Computers & Internet
Black screen with error codes
I think the msg you are seeing is just the default monitor message when there is no video to display. Here is a list of common beep codes: Are you getting the one long beep at each restart?
Beep Code: Description of Problem: No Beeps Short, No power, Bad CPU/MB, Loose Peripherals One Beep Everything is normal and Computer POSTed fine Two Beeps POST/CMOS Error One Long Beep, One Short Beep Motherboard Problem One Long Beep, Two Short Beeps Video Problem One Long Beep, Three Short Beeps Video Problem Three Long Beeps Keyboard Error Repeated Long Beeps Memory Error Continuous Hi-Lo Beeps CPU Overheating
Dec 16, 2008 | Computers & Internet
Error Beeps On Start Up
Hi!
It could be a problem with the keyboard that it might have a sticky key. Try to check the keyboard for some sticky keys and check if you can still clean them or else replace it. :)
Hope this helps!
Thanks,
Karlox™ :)
Jul 10, 2008 | Computers & Internet
Computers & Internet Logo
90 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
