Question about Robinair Cool Tech 34700Z Recovery, Recycling, Recharging
My robinair 34700z won't recover or fill tank
First off I was recovering a van and I heard a funny noise and it stopped recovering so I cleaned and swapped the recovery solenoid and cleaned all other solenoid in the machine my oil drain wasn't working right because when I disconnected it like 25 oz of oil came out so this may have something to do with it. The compressor turns on but was very warm I think the compressor got flooded with oil from faulty oil drain solenoid but don't want to buy something I don't need any help I'd appreciate
    New Friend:
Pleas e 288 wat is that
Posted on Jul 23, 2013
3 Suggested Answers
mhkamran
  • 180 Answers
SOURCE: Robinair 34700z not filling source tank / slow recovery
Please check the following:1# For not filling ISV tank (internal storage vassel) Check tank fill solenois,it's may need to rebuild or replace.2# For not compleet recovery,Check & make sure your machine compressor haveing 13''HG suction.if not then you have to replace new compressor.3# Check 13'' vacuum sensor is working properly.
NOTE:PLEASE CHECK FILTER CAPAICITY,BECAUSE EVERY 68Kg/150Lbs OF REFRIGERANT RECOVERY YOU MUST CHANGE SPIN-ON FILTER.
Posted on Jul 30, 2009
mhkamran
  • 180 Answers
SOURCE: I have a Robinair cooltech 700 a/c machine. does
Please check your machine ISV tank liquid hose,it's may lose or too tight
Posted on Jun 11, 2010
Robinair model 34288 will not stop recovering
what is the pressure reading on your guages? if it is below 0 if so the vacuum pump should kick on. if the vacuum pump keeps turning on and off check the software version on the machine if it is not 3.09 or 3.11 the software needs updated contact your local robinair service center. if it is not the software then the recovery solenoid may be sticking closed and will need replaced.
Jul 07, 2012 | Robinair Cool Tech 34700Z Recovery,...
Machine says pressure exist unable to vacuum system down
It's not clear that you machine is doing recover or not! If the machine is doing recover theh follow the bellow steps.This is a common problem of Robinair 34700Z / 347002k
Sep 16, 2010 | Robinair Cool Tech 34700Z Recovery,...
I HAVE A 34700Z UNIT AND I WAS RECOVERING AND AFTER A BIT IT STOPPED AND SAID HIGH PRESSURE UNIT DISABLED WHAT COULD BE THE PROBLEM.
This is a common problem of Robinair 34700Z / 347002k & 347112k series machine.so don't worry just check the following :- 1# Verify the ISV tank is not overfilled.if full,remove some refrigerant manually from tank. 2# Purge excess air from the tank manually.( Open air purge hose from the tank,then press tank valve as needed to purge air from the tank) 3#Check the air purge solenoid & High pressure switch for proper operation.Hope this will solve your problem, Best of luck & vote for my solution
Aug 21, 2010 | Robinair Cool Tech 34700Z Recovery,...
Hi, My robinair model 34700Z wont recover refridgerant from a vehicle or lines. It goe through a vacuum cycle and charge cycle fine. It also wont transfer from my source tank or Recycle . It has 61 hours...
It is clear to me you need to Replace the Compressor! But if you want to make sure yourself, please do the following: Press recover & fix a vacuum gauge on your machin Compressor suction port & monito the gauge is going up to13"HG suction,if not then you need to replace the compressor.
I wish this will help you to solve the the problem. if so, pls vote for it. Good luck!
Aug 11, 2010 | Robinair Cool Tech 34700Z Recovery,...
I have a Robinair 34430 that will not charge, refill from new tank and will not recover. Freon used to flow through the sight glass, but not anymore. The control pad works fine and the compressor comes...
You can do the following :
1# Rebuild/Replace ''charge'' solenoid.
2# Check ''recover'' solenoid is working properly. Repair as need. If recover solenoid is OK, Then you may have to replace the "Compressor".
I hope this will help you to rectify the problem. If so, please vote for solution. Best of Luck!
ROBINAIR 34788 NO MANUAL REFILL
You may did not open the tank valve before you press fill key! please try as bellow:
Connect tank fill adapter to source tank & open tank valve then make the tank up side down,now press tank fill key. screen will change to checking source tank for 30/60 sec. then start filling.
If you try as above direction & still the problem exist,it may need to replace or rebuild tank fill solenoid.
Jul 14, 2010 | Robinair Cool Tech 34700Z Recovery,...
My 34700Z is not discharge low side existing pressure, wen i select vaccum the low side hose have pressure and stop to make vaccum
Please Check the following 1# Check ISV tank may overfill,if so manually discharge extra pressure from the tank.2#Check High & Low side small recover solenoid (in small manifole assy.) it's may neet to rebuild.3# Check Recover/Vacuum/charging (in main manifold assy.)solenoid,rebuild if need.4# Check ISV tank liquid hose is connected properly & make sure it's not too much tight OR loss.5# Check high side coupler is opening properly.Hope this will help you to solve the problem.
Apr 13, 2010 | Robinair Cool Tech 34700Z Recovery,...
I have a robinair cool tech 700 not recovering
You Need to replace your unit compressor.Because may be you did not change spin-on filter after recovering 150 LBS of refrigerant.
May 17, 2009 | Robinair Cool Tech 34700Z Recovery,...
Robinair  Cool Tech 34700Z Recovery, Recycling, Recharging Logo
558 people viewed this question
Top Robinair Measuring Tools & Sensors Experts
Mike
Jay Finke
Jay Finke
Are you a Robinair Measuring Tool and Sensor Expert? Answer questions, earn points and help others
