Question about Garden
Shindaiwa eb3410 operators manual
Blower
Do I mix the fuel for my shindiawa 575 chainsaw
Re-fill with fresh fuel of the correct mixture
(Shindaiwa Premium 2-cycle Engine Oil
and gasoline-40 : 1 ratio;
other brands-25 : 1 ratio).
Workshop manual
http://www.golftechs.us/Manuals/shin%20chainsaw_current.pdf
Dec 12, 2016 | Garden
Where is the fuel air mixture screw on a shindaiwa backpack blower
Look on the side of the carb. they are there. You will probably need to remove the air cleaner form the carb to see them and then you may need a special tool to adjust them due to the EPA covers on the screws. Hope this helps.
Jun 27, 2014 | Echo Pb265l 25.4cc Gas Powered 158 Mph Low...
I need a carb kit installation guide for my Shindaiwa n452 hedge trimmer
There is no guide. Post the model and manufacturer of te carburetor itself. Walbro, zama, tk, etc.
Sep 20, 2013 | Shindaiwa N452
Shindaiwa trimmer carburetor adjustments
contact shindaiwa direct on web and make this request on them
Jun 09, 2013 | Garden
Shindaiwa leaf blower EB8520 loose power every 5 secondes for 5 secondes
Sounds like you are running it with the choke on - is it spitting black smoke?
Jan 12, 2013 | Garden
Do you use 2 cycle or 4cycle oil for mix in shindawai blowers
Not knowing what model blower you have, I do know that Shindaiwa manufactured both two cycle and 4 cycle blowers. In either case, you run the required 50:1 ratio. I would also recommend using the Shindaiwa branded oil since it is formulated to run in their equipment at that ratio.
Other manufacturers have 4 stroke blowers on the market that run "straight" fuel because they have an oil sump for the engine oil, much like a 4 stroke lawnmower. However, that is not the case with Shindaiwa's 4 cycle design which still runs "mixed" fuel.
Feb 20, 2011 | Echo Back Pack Blower Rack Fits Stihl...
How do you fix the plastic gas line? It doesn't stay in the gas tank. When I prime the bulb the gas squirts out and when the echo blower is in use, gas ends up leaking on my leg.
The holes in these gas tank are made to fit available fuel lines tightly enough to prevent the problems you are having. If yours is leaking either someone put on too small a fuel line or made the hole larger so it would be easier to put the fuel line in the tank. The only fix is to get the next size larger fuel line or replace the tank. You can try to seal the line with RTV or silicone but he gas will degrade it and it will leak again plus you'll have a harder time the next time the line has to be replaced.
Jan 05, 2011 | Echo Back Pack Blower Rack Fits Stihl...
Shindaiwa Blower - when throttle pushed, engine sounds flooded and it dies. any thoughts on how to fix?
Its not flooded- its lean.
Heres a way to test me. Try to give it throttle but keep it running. At the same time slowly close the choke. does it run better as you close the choke? Does it run pretty good on half choke?
Rebuild the carb, replace the fuel lines and fuel filter.
Dec 20, 2009 | Garden
Craftsman weedeater wont start
The problem that I had with my craftsman was that I found that there was a tube in the fuel tank that goes to the carb, & at the other end - inside the tank, there was a small screen with maybe a weight on it (to keep it in the gas no matter what position the weedeater is in). Mine was plugged up and i went to the saw shop and got a generic hose & end with the screen deal & changed them out. Solved my problem. Rick
Mar 24, 2009 | Poulan Genuine Weedeater Part # 36006-128
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
