Question about Sanyo SRA2480M (5 cu. ft.) Compact Refrigerator
Freezes everything, temp control won't vary
No matter how I set the temp control, it freezes all the bottled water we store inside. This is a recent problem.
I have amagic chef 4.4 cu ft mini fridge. when I turn it on, no matter what I set dial to it freezes everything inside. How do I fix this ?
Hi.
This is a classic example of a faulty thermostat.
If it has a electronic controll system the temp sensor is defective.
Oct 28, 2015 | Refrigerators
Sanyo Mini Fridge Freezes Everything
For me I think you have a problem in Thermostat switch contact. Or the rotary switch was not in good contact point, better check it and if still the same, proceed to check your thermocouple if functioning.
Jul 22, 2013 | Sanyo 2.4 Cu. Ft. Compact Mid-Size...
Refrigerator freezes water and cola drinks inside it
have the thermostat checked as it appears that it has stopped controlling the temperature you set to
Jun 16, 2013 | Haier Refrigerators
NO WATER COMING OUT OF WATER DISPENSER ON MY SAMSUNG RS21DCNS/XEU
you either have a kinked water line, or a frozen one. There is a possibility that the solenoid isn't working.
Nov 08, 2009 | Samsung Refrigerators
GE Arctica Profile getting too cold, temp set to 37 actual temp is 25-35
Use the damper control to direct less air into the refrig compartment from freezer
Apr 23, 2017 | GE Profile PFS22 33" Artica French Door...
New 700BR freezes everything in it. Worked ok for
Sounds like a stuck thermostat, you can try to tap it and this may "unstick" it, or you would need to replace it.
Mar 09, 2009 | Refrigerators
Fridge area freezing food; water dispensor line freezing
sometimes when the cooler weather comes in you may need to chnge temp setings to a warmer setting to prevent some items from freezing ie: leafy vegetables, water bottles, eggs, etc etc.
now if you are having total freeze up of everything in the ref section then you could have bad temp control or damper assy.
Oct 22, 2007 | Frigidaire GLRS234ZA Side by Side...
Refrigerator freezes everything even on the lowest setting
Is everything really frozen or just the top shelf stuff? You may have a thermistor (temp sensor) problem if the compressor just runs and runs and runs all the time. Take a glass of water and place a thermometer in it for about 3 hours then take a temp. reading. That will let you know what the real temps are. See if you can cause the compressor to kick off and on by changing the temp settings (go to real low for about 5 minutes then back up to high). Let us know what happens.
Dec 24, 2006 | Sanyo SR-3620 Compact Refrigerator
Sanyo SRA2480M (5 cu. ft.) Compact Refrigerator Logo
18 people viewed this question
Top Sanyo Refrigerators Experts
John Tripp
John Tripp
christian nielsen
Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
