Question about Evisu Watches Womens Minako Black Dial Two Tone Two Tone Black Dial 8
Evisu Minako watch not working out of the box
Can you help?! My evisu Minako watch doesn't seem to be moving. There is no second hand, but after watching for about 5 minutes didn't move. This is new fresh out of the box. Help!
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 69 Answers
It may be fresh out of the box but how do you know how long it has been on the shelf or sitting in the box at the manufacturer? It probably just needs a battery.
Posted on Sep 13, 2013
Second hand sticks to minute hand diesel dz 4021 watch
Likely the two hands are touching. A watchmaker can adjust them, shouldn't cost much,
Oct 04, 2012 | Zenith Watches 03-1260-4021-02-C505 Watch
Tip
======= http://www.2kuu.com ======= jordan air max oakland raiders...
Issue.... is those equipped with 4.0L engine may experience coolant leaking from the coolant expansion tank. This may be due to cracks that develop in the tank at the radiator mounting bolts locations. The action to be taken is replace the tank.
on Jan 24, 2011 | 1998 Ford Explorer
Tip
There is a known issue with the 2005-2007 Corolla automatic transmission shift logic. The shift points may seem harsh, and the Check Engine light may be illuminated.
There is a technical service bulletin published (TC015-07) that will address and rectify this condition.
The diagnostic code P2716 will be stored in the computer memory. The procedure involves replacing the Engine Control Module (the computer) with an updated unit.
The repair is covered, under the factory warranty, for 96 months, or 80,000 miles, which ever comes first.
I hope that this helps Corolla owners out.
Regards,
Toyota Ed
on Jan 24, 2011 | 2003 Toyota Corolla
I'm able to set the time and date but once i push the crown back to its original place the watch doesn't start so i push the upper bumper and the seconds begin to run nevertheless the minutes never...
your watch is chronograph,. and it is not in the picture. probably your problem is the second hand won,t move, it is because that the sub dial on the lower part it is the real second hand. the big second hand is for the stopwatch. the to sub dial on the upper sides of your watch. the upper button/bumper is to start and stop the stopwatch or the big second hand and the bottom bumper/button is to reset it. i hope this can solve the problem...
Jul 25, 2011 | Swiss Army Wenger Sportedge Bracelet Watch
Workshop manual
==== http://www.voguecatch.com ==== top Cheap Nike air Jordan shoes33$,Air Force 1 33$, Nike dunks SB shoe,Nike Shox shoe. Wholesale Cheap Nike shoes with discount jersey, High quality T-shirts,ED hardy t-shirts,ED Hardy hoodies,ED hardy shoes,ED hardy Jeans,Evisu shoes,GUCCI shoes,LV Handbag,Chanel Handbag
Jul 10, 2011 | 2006 Honda CBF 1000
Just had the battery replaced on my Wenger Swiss Army watch Model : 7987X/T. The red second needle is no longer moving.. its stuck on the 30 min mark. Watch works fine otherwise. Could not find any info...
If the second hand of your watch isn't moving, but the watch is otherwise keeping time, you most likely have one of two problems. The simpler to fix problem is that the second hand might have come loose from the post onto which it's been fitted. It's a simple friction fit, and a watch technician would simply remove the watch movement from the case and very (very!) gently push down on the seconds hand to re-seat it. If that's the problem, that's all there is to the repair.
A second potential cause for this behavior could be that a speck of dust or crud has gotten into the gears that operate the seconds hand, preventing it from moving. This can easily happen when changing a battery--many watches tend to get somewhat of a buildup of crud where the watch back meets the case. Especially with screw back cases, the process of loosening the back also loosens the crud layer, making it easy for little bits to fall in. If you do have crud in your movement, you're a bit limited in what you can do. Unlike old-time mechanical movements, very few quartz movements are made to be disassembled and cleaned. Instead, a watch repairer may be able to blow some air (not compressed air from a can--that will probably wreck your movement) to try to clear the gears. If that doesn't work, there is a little device that some watchmakers have that runs your watch at about 50 time as fast as normal. Spinning the gears like that can sometimes generate enough force to clear a blocked gear train. I have done this to resurrect several watches whose hands were stuck. However, I was still able to see the "pulse" of the second hand on those watches, even if the hand itself never moved forward.
May 16, 2011 | Watches
We have a Carriage watch by Timex that's my mom's (she's in a nursing home). The watch wasn't keeping time so my brother replaced the battery. It was running fine, now it's lost time....
A second hand that pulses but does not advance usually indicates one of two problems: (1) a weak battery that provides insufficient power to the tiny motor that advances the second hand; or (2) a bit of dust or grit somewhere in the watch's gear train that is jamming up the works.
Try testing or replacing the battery. If that doesn't work, some watchmakers can try to blow out (using very gentle air puffs, not cans of compressed air) the watch movement and/or put it on a special machine to try to unjam the gears. It is usually does not make economic sense to perform further repairs on a watch of this price range, though it is also possible to replace the entire movement.
May 06, 2011 | Watches
Brand New Watch second hand won't move. won't keep time.
The watch has a problem in the timing module and the second hand won't move (a cog wheel issue) this is clearly a manufacture defect that can not be remedied and should be returned since it is under warranty.
Feb 27, 2011 | Fossil Watch Style # ES2074
Touch screen is not working for several functions on tissot t-touch: notably started with altimeter, then meteo, now alarm.
==== http://www.voguecatch.com ==== ====accept credit card and paypal
Cheap Nike air Jordan shoes33$,Air Force 1 33$, Nike dunks SB shoe,Nike Shox shoe. Wholesale Cheap Nike shoes with discount jersey, High quality T-shirts,ED hardy t-shirts,ED Hardy hoodies,ED hardy shoes,ED hardy Jeans,Evisu shoes,GUCCI shoes,LV Handbag,Chanel Handbag......welcome to ==== http://www.voguecatch.com ====
Nike shox(R4,NZ,OZ,TL1,TL2,TL3) $35
Handbags(Coach lv fendi d&g) $35
Tshirts (Polo ,ed hardy,lacoste) $13
Jean(True Religion,ed hardy,coogi) $30
Sunglasses(Oakey,coach,gucci,Armaini) $15
New era cap $16
Bikini (Ed hardy,polo) $18
Oct 23, 2010 | Tissot T-Touch T33159851 Wrist Watch
Evisu Watches Womens Minako Black Dial Two Tone Two Tone Black Dial 8 Logo
221 people viewed this question
Top Evisu Clothing Accessories Experts
Da Doc
ray gallant
Tom Chichester
Are you an Evisu Clothing Accessory Expert? Answer questions, earn points and help others
