Question about GE Energy Star WCVH6260F Front Load Washer
Why is my kenmore washer shredding sheets?
My washer is shredding my bedsheets. I even loaded the washer with only the top and bottom fitted sheet, so there would be plenty of room for the sheets to wash. I took the sheets out, they were spiraled like as if wrung, and there was a big spot totally shredded! This is the 3rd set of sheets this has happened to. I need to know if there is something that can be done. Is it the agitator? I called sears to see if there was a recall and they didn't have one. I am sick of this washer tearing up my sheets. I have noticed ripped spots on some of our large towels. HELP!
  • cneatherl112 Jul 22, 2013
    Oh I forgot to mention, the agitator it is working fine!
  • GE Master
  • 2,514 Answers
Check the drum for any Sharpe edges or splits also check the activator for the same . Something in side may have a rough edge to cause this .
Posted on Apr 25, 2017
SOURCE: Final Spin Drum BANGS around--terribly frightening noise!
Check the spring that hold the drum in place. They are about 4-5 inches long on the top of the drum at about 2 and 10 o'clock. The springs suspend the drum and if broken the drum will bang around. About $40 to order springs online
Also check on the bottom at about 4 and and 7 o'clock because there are 2 shock absorbers that help keep the drum from just bouncing and bouncing with no end in sight. Again about $40 to change each one.
I am in the process of the first repair and doesn't seem too difficult. The second was done about 6 months ago and was not too difficult but was awkward because you had to lay on the floor to get the replacement pins in place.
Posted on Jan 12, 2009
  • 89 Answers
SOURCE: Black spots floating on top of water
the top seal in the transmission is bad causing oil to get inside you will need to replace the trans but it will be cheaper to buy a new washer
Posted on Jul 12, 2009
  • 582 Answers
SOURCE: need to remove agitator
IF THIS IS AN OLDER UNIT THE AGITATOR WILL BE SEIZED TO THE SHAFT ODDS OF GETTING THE AGITATOR OFF ARE VERY SLIM. IT SOUNDS LIKE THE NUT UNDER THE CAP IS SEIZED ALSO YOU SHOULD BE ABLE TO REMOVE THE CAP AND THEN USE WRENCHES TO REMOVE THE NUT
Posted on Aug 10, 2009
SOURCE: GE top loading washer Washer wwse5200- Agititation?
It is a cast aluminum peice below the agitaror that costs about $50.00 from GE.
Posted on Nov 22, 2009
  • 3 Answers
SOURCE: My Adora front load washer is shredding my
Had that problem for a while with mine, It seemed to do it once in a while....then we stopped putting our jeans/pants in with the rest of the colors. and it stopped happening. we was our pants seperatly with them zipped and buttoned now, have not had anymore ripped or torn clothes since.
Hope it helps.
Posted on Oct 30, 2010
What are the criteria one should use to judge bed sheets?
There are some important parameters on which you can judge any bed sheet like-
Good Thread Count
Quality weave and finish
Good quality yarn with long staple cotton etc.
To purchase quality bed sheets in India, visit- http://www.maspar.com/bed-linen/bed-sheets.html
Jan 15, 2014 | Furniture
Kenmore series 80 top loader washing machine 11029852991. When turned on spin cycle, makes a loud grinding kind of noise. I believe unit may have been overloaded with three kingsized bedsheets &...
unless some thing inside the washer is broken i would say the drum bearings have started to wear out badly,,,my washer will easly take 3 king size bed sheets and covers,,,that not a lot realy,,,how old is your unit? and how many washes has it done,,,years old and 1000's of washes?
Jul 16, 2010 | Kenmore Washing Machines
What happen when A kenmore oasis he washer has no power. Is there A reset button
In them tech sheets is some info on what to do in case that puppy appears to be dead in the water. OASIS TECH SHEET
Jun 16, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Looking for a manuel for a kenmore elite oasis he,stopped washing
If you are looking for a REPAIR manual, each one of these washers come with a technical data sheet located inside the front panel of the appliance. The tech sheet includes all diagnostics procedures, error code definitions, troubleshooting flow charts and wiring diagrams. To access it, you can pop the top panel open by locating the two retaining clips in the seam along the front of the washer where the washer top and front panel meet. About 2 inches in from each side slide a putty knife into the seam and push in to release each clip. Hold the lid shut as you lift the top. The tech sheet is located on the inside of the front of the washer between the wash tub and casing. Or....you can have someone lift the washer and tilt it back and you can try reaching up from the bottom between the wash tub and front casing.
If you need an OWNER'S manual, you can go to managemylife.com and type in the your model number under the "Manuals" link. They have an extensive list of manuals in .pdf (Adobe) format that you can download or print for FREE.
I hope this helps you.
Feb 12, 2010 | Kenmore Washing Machines
KENMORE WASHING,wATER IS LEAKING FROM THE BOTTOM NOT THE HOSES
Possible circulation or drain pump leaking or associated hoses. See page 11 Oasis Tech Sheet
Jan 25, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Washer manual
If you are looking for an Owner's Manual, go to managemyhome.com and type in your model number in the following format: "110.28032700" under the "Manuals" link. Your owner's manual is available in a .pdf (adobe) format that you can download or print for FREE.
If you need technical data sheet to troubleshoot a problem, the washer comes with a tech sheet inside the cabinet. It is located between the wash tub and cabinet in the front of the washer. The tech sheet includes all diagnostics procedures, fault codes and technical data to troubleshoot any problems you may encounter.
You can access it by lifting the washer top, or by reaching up from the bottom of the washer. If you choose to open the washer top, you need to locate the two retaining clips along the front of the washer in the seam where the top panel meets the front of the washer. Push in on the retaining clips and the top panel will pop free and can be lifted up. Make sure you hold the lid closed while lifting, so that it does not fly open when lifting the top. I recommend taping it closed.
If the tech sheet is missing, you can order a new one. The part number is W10026628.
If you have questions, please let me know. I hope this helps you.
Oct 18, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Leaking
Sheets Or Comforters? This Normally Occurs With An Overload Such As Pillows And Comforters Due To The Large Circumference. Which Simply Means That Anything That Has A Large Area Will Make The Water Come Over The Top Because When The Machine Is Running The Spin Cycle The Large Area Of Fabric Covers The Side Of The Machine. Actually Causing Water To Spin Off The Top Of The Fabric And Over The Sides Of The Washing Machine Bucket Thus Ending Up On The Floor Below.
Feb 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Sheet stuck under washer agitator.
remove agitator top remove 7/16 bolt to remove agitator. tub mounting hub may be worn which allows the tub to drop down. the hub is located on the center post below the agitator.
Dec 20, 2008 | Kenmore 23822 Top Load Washer
Washer ate a sheet
the wash plate has a rubber seal all the way around the bottom even the smallest gap can grab clothes and pull the under only solution is replace plate
Aug 06, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
GE Energy Star WCVH6260F Front Load Washer Logo
89 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
