Im using acer laptop, my mouse and keyboard stops working during windows xp installing, why??
    Sergeant:
  • 396 Answers
When you turn it on, do you see a message to press F2 (or some other key) to enter setup? If so, go into that and change the settings to default, and save and exit. See if that doesn't help things along. If not, Windows XP can sometimes 'hiccup' on some hardware problems during installations. If it doesn't like what's happening with certain hardware, it will fail, or freeze.
Hope this helps.
Posted on Jul 23, 2013
TheTechGuy
SOURCE: acer notebook 3002
I would try plugging an external keyboard or mouse in to see if that works. If it does, either the keyboard/mouse (2 in 1 on laptops) drivers are invalid in which case you can go to http://support.acer.com and download the keyboard/mouse drivers and/or utility. Otherwise, most likely the keyboard/mouse hardware is the porblem. In which case either the cable connecting it to the rest of the laptop is loose or more likely the entire keyboard/mouse device is fried. I suggest contacting the manufacturer (Acer) and if your laptop is still under warranty get them to replace it; if not buy it. -The Tech Guy
Posted on Apr 15, 2007
Beni S-P
  • 1006 Answers
SOURCE: Xp hangs and pc stop responding during Xp installation.
Location off viruses is on SYSTEM RECOVERY and it can't be cleaned.It's just one way:
If u can change the PIN off HDD.It can do just programmer!
So my solution is just buy new hdd
Posted on Nov 24, 2007
SOURCE: Acer Aspire 3004 keyboard and touchpad error
Just resolved same problem on Acer Aspire 5000 by removing the battery, then goto device manager and disable "Microsoft ACPI-Compliant Control Method Battery" you can then put your existing battery back into the latop with any problems with the keyboard and touchpad. Mad solution I know but it worked for me
Posted on Jan 22, 2008
  • 5 Answers
SOURCE: how to install XP in toshiba Satellite L45-S7423 laptop
I found it!!!>>>
Just go to Toshiba support web site Download the Storage Manager Driver for XP 32 then have an External floppy drive with formatted Disk ,install the drivers Files in the floppy connect the floppy drive put the XP sys CD Boot from the CD as in Solution #1 or by press on F12 tell choices boot screen popup select the CD then after that when the third party appear press F6 to chose the Driver for HDD to get recognized by the system. J
Posted on Apr 14, 2008
CheTzu
  • 3 Answers
SOURCE: toshiba satellite touchpad & keyboard stopped working
As I understand your keyboard is now working and your usb mouse. But the touchpad does not work.
Have you or someone opened up your laptop recently? If so it is possible the touchpad was not connected properly.
Can you please post the exact name of your laptop. I'll see what else I can figure out for you.
Posted on Oct 03, 2008
TOUCHPAD MOUSE ANS KEYBOARD NOT WORKING
Try these steps.. Click start button, type "mouse" on Search Programs and Files, click "mouse" under control panel. In mouse properties options....as you an see the touch pad driver tab? click it. Choose or click option button and you can enable the right and left click button. About the keyboard problem,,,,,go to device manager, right click the standard PS/2 keyboard..uninstall it. Windows restarting and the keyboard driver will re install automatically.. check if the keyboard works fine.
Aug 17, 2014 | Acer Aspire 3810T 4810T 5810T
How can i install a wireless keyboard and mouse to an Acer Aspire, windows says it's install but only the built in keyboard works while the wireless mouse does work
Fred I have an acer too Im running Linux and use a LogitecM305,,see if you can get one,,it has a small receiver which plugs into the usb port and remember to put a battery in the mouse itself and also to switch it on ,,there is a small switch on the underneath
Jul 19, 2011 | Acer Aspire One AOA150-1435 PC Notebook
Aspire 5601 Laptop. It freezes during XP welcome window Simply the mouse and the keyboard stops working and the computer gets stoned. The only way to turn it off is to unplug and take out the battery. I...
dowload defraggler it clean your system up it sounds like you have to many to many start programs popping up go to run put msconfig that should shout down the programs u dont need comeing up.
Jan 25, 2011 | Acer Aspire 5600 Series 5630-6951 Laptop
My windows Xp on mac wont run
Try getting the latest version of bootcamp again, and making sure you create the driver cd it asks you to create during the install.
This part is critical as it installs the software needed for your keyboard and mouse to be recognised by windows xp.
Hope this help.
Nathan.
Apr 13, 2009 | Apple MacBook Pro Laptop Computer with...
Mouse frozen of my latop ACER TravelMate 252LC_DT
if your mouse driver installed remove mouse driver and instal new driver....http://support.acer-euro.com/drivers/downloads.html
Mar 15, 2009 | Acer TravelMate 240 Notebook
No kb or mouse in winxp
go here and download the drivers that you need for xp ....
http://global.acer.com/support/index.htm
put them on a usb flash drive and transfer them to the laptop... use a usb mouse to access give you a mouse on the acer and install the drivers ... reboot and all should work... there is one issue... is that is a very new computer that had vista pre-installed ??
sometimes they are not reverse compatable for operating systems... i've tried putting xp on my compaq desktop computer and there are no xp drivers for some of the devices.
Robert
Dec 17, 2008 | Acer Aspire 3000 Notebook
Acer Extesa 6601 Keypad & Touchpad Problem
you need the drivers for the touchpad and keyboard, click on the drivers and utilities section, then allow active x when the pop up appears
http://support.acer-euro.com/drivers/notebook/ex_6600.html
Aug 23, 2008 | Acer Aspire 5100-5022 Notebook
Keyboard + toucpad freezes
Might seem ovious but you may want to try Acer support and look for a new Driver.. Also check under Control Panel...Mouse options... and also check device profiles to make sure windows isn't loading a "docked profile which may disable touchpad and laptop keybaord use.
Feb 21, 2008 | Acer Aspire 5670 Notebook
Keyboard not responding when loading windows xp
Get out the battery and reseat it. and try again
Sep 19, 2007 | Acer Aspire 5100 Notebook
Acer notebook 3002
Apr 13, 2007 | Acer Aspire 3000 Notebook
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
