I have a vaio laptop and uts on "Startup Repair" i
I have a vaio laptop and uts on "Startup Repair" i need to know the password can u guys help me with it?
    New Friend:
  • 21 Answers
Is that an OS message "Startup Repair"? If so, the Administrator password should work.
Posted on Jul 24, 2013
3 Suggested Answers
TimmayG
  • 86 Answers
SOURCE: startup repair won't repair
It sounds like your leaving your Installation Disk in the drive. Take that out and run safe mode, then just plug in your flash drive as normal and it should detect it and you can copy your files to it. If not, use s CD and burn the files you need on them then you can proceed with Wiping the drive. If this fails, Install XP but there is a option to not have the drive formatted thus this keeps all files in tact. Reinstall XP like this, take the files you need and then reformat and reinstall XP and you should be fine. After doing all this, run a virus scan and have it run regularly because it may have been a virus that caused the problem to begin with.
Hope This Helps
Posted on Nov 21, 2008
  • 2246 Answers
SOURCE: At startup, my HP laptop (running Vista) says
reinstall your pc, not as repair modde but with new instalation mode, but your data at drive C: will formated, back up it first before you reinstall
Posted on Jan 17, 2011
Cant log in forgot pass word need new pass word
You need someone else with a computer. Download NT Password deleter here:
http://pogostick.net/~pnh/ntpasswd/
Press F12 on startup to get the boot options, select yr DVD/CD drive and this will reset your password.
Alternatively find a local PC repair guy. If they're any good they can do it in 5 minutes for a nominal charge. If they try to charge lots of money walk away. It's an easy fix if you know what you're doing.
Sep 09, 2013 | Computers & Internet
Tip
How to perform a Sony VAIO System Restore
NOTE: A recovery also can be performed using recovery discs.
  1. Close all open programs and turn off the computer.
  2. Disconnect all network connections.
  3. Disconnect all peripheral devices.
  4. Turn on the computer.
  5. When the VAIO screen is displayed, press the F8 key.
  6. At the Advanced Boot Options screen, ensure Repair Your Computer is selected and press the ENTER key.
  7. In the System Recovery Options window, under Select a keyboard layout: , click the Next button.
  8. Under To access recovery options , next to User name: , click the down arrow , and click to select an account with Administrator rights.
  9. Next to Password: , type the appropriate password for this account.
  10. Click the OK button.
  11. Under Choose a recovery tool , click to select the desired option: NOTES:
    • The Startup Repair option can automatically resolve certain issues that can prevent the operating system from starting.
    • System Restore can return the computer to a previous configuration of the operating system when it was working properly.
    • Windows Complete PC Restore will restore a previous backup of the computer created using the Windows Backup and Restore Center .
    • The Windows Memory Diagnostic Tool can determine if any problems being experienced are caused by issues with the computer's memory.
    • The option to open a Command Prompt can be used by advanced users and technical support personnel to perform troubleshooting on the hard drive or the operating system.
    • Clicking VAIO Recovery Center will launch VAIO Recovery Center from the Recovery Disc.
on Feb 11, 2010 | Computers & Internet
Sony Vaio with Windows 7, same message at startup help
Are you able to log into your Account? If so download ccleaner and run registry cleaner. That might work
Feb 05, 2013 | Sony VAIO Computers & Internet
Some problems in laptop
Have the hard drive tested for issues, from your description it is the harware that is causing the problems.
Jun 27, 2012 | Computers & Internet
How to clear sony vaio vpcea 43fx bios
Read the manual. it will tell you the process.
Get online and got to www.google.com In the google search box type: "Sony Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Look for manuals and search them for Bios Password or Bios Password Reset.
Jun 03, 2012 | Sony VAIO(R) VPCEA43FX/BJ 14" Notebook PC...
I need to reset the administrator password for bios for model dell inspiron 8600
To reset the Bios Password do the following.
If you know the Bios Password then when you boot the machine look for which key is required to press to get you into the Bios or System Setup. Once inside you can change the password if you know the current password.
If you don't know the Bios Password, then you will need to unplug the laptop and you will need to remove the CMOS Battery from the laptop that is on the motherboard. Some computer models make getting to the CMOS battery simple by remove the Hard Drive or Memory Chip door on the bottom of the laptop and voila there it is. I fyou can get to the CMOS Battery remove it and let the laptop sit a couple of hours before replacing it. This clears the computer's memory of everything including the BIOS Password. Most manufacturers make it a difficult task which means you will have to disassemble your laptop to get to it. If you are uncomfortable doing that then get a quote from your local computer repair shops, then check the guys out at: http://www.generalsystemsconsulting.com They will repair it and ship it back by Fedex or UPS and most times it's cheaper than any quote you received even with the shipping included.
Mar 14, 2012 | Dell Computers & Internet
When I startup my Sony Vaio Netbook, it boots slowly, but never gets to the startup screen. The screen is black with the cursor being the only thing showing (meaning that the screen my be fine). When I...
reboot the system, wait for the VAIO logo to appear, and then start pressing F8(keys depends on the model ) . The Advanced Boot Options screen will appear shortly. Use the arrow keys to highlight the “Repair Your Computer” option and press Enter.
Oct 15, 2017 | Sony Vaio P VGN-P530H Netbook
WINDOWS WILL NOT START - CANNOT START IS SAFE MODE OR ANY OTHER
OK try doing this below.
You will have to use a Windows DVD and boot on it, try a "Repair" install, If this doesn't "Take" then you will have to do a complete reinstall.
Feb 11, 2010 | Sony VAIO Notebook
VAIO PASSWORD
it may not have a password set.
try just pressing enter.
if no password set then entering one would be wrong.
if it has no password then it would accept the blank space left when you just press enter and continue.
if not, let me know and i will try to run you through a few loopholes to get you past it.
Feb 25, 2009 | Sony VAIO VGN-FS810/W Notebook
Computers & Internet Logo
David Payne
David Payne
