Question about Dryers
Wiring Diagram fantasia ceiling fan
Connections for speed control
jonniewalker
  • 1031 Answers
SOURCE: Fixing Ceiling Fan
An easy-to-install ceiling fan can make a real difference in your home's climate - both cooling and heating - at a far lower cost and operating expense than almost any other item.
The installation begins with choosing where the fan should be located. In almost all homes, the fan is installed in the center of the room, replacing a central light fixture. This spot provides a smooth air flow to most of the room. Since a fan draws about the same power as a ceiling fixture, the electrical circuit shouldn't be overloaded. But if your fan includes lights, be sure the circuit it's on has enough extra capacity to handle the load. If not, you must run a new circuit with a new circuit breaker from the house main service panel or subpanel to the fan. If there is no central light fixture, you'll have to create a place to hang the ceiling fan. Then, you'll need to bring electrical power to it. You can tap into an existing circuit to do this.
Posted on Sep 25, 2008
  • 37 Answers
SOURCE: How to wire a remote control ceiling fan, without using remote.
If you don't want the to use the remote you don't have to, but you don't have enough wires to switch the upper light, the lower light, and the fan. You can, however, switch the upper and lower lights together if that's okay. In order to do that you'd connect the white from the ceiling box to the white (neutral) on the fan, then the green from the ceiling box to any green(ground) wires on the fan, then the black from the ceiling box to the black(motor) from the fan, then the red from the ceiling box to the blue and orange (lights) from the fan. I'm assuming that the black and red in the ceiling box are also in the switch box where the fan/light control switch is going. Those are the ones you'll connect to the controller.
Posted on Jan 27, 2009
SOURCE: Ceiling fan wiring Aloha ceiling Fan Model # 29079
I have an Aloha Breeze L-Style 52" Ceiling Fan(Polished Brass), Model # 29079 Bought From Wal-Mart about 1 1/2 years ago and the fan speed switch busted and the capacitor melted. I have a new switch but can't find a new capacitor because I can't read the spec info. Looking for a place to obtain the correct capacitor for this fan so I can make necessary repairs!
Posted on May 09, 2009
brnspncr
  • 67 Answers
SOURCE: wiring diagram for Kenroy 3 speed dual/multi level pull chain
Try http://resource.arcadianlighting.com/Vendors/Kenroy/Docs/34232BS-INS-B.pdf
Posted on Jul 05, 2009
  • 1114 Answers
SOURCE: Hunter ceiling fan-just installed -possible speed control problem
Sounds like the fan is defective. All internal wiring from the switch to the motor is factory installed. The fan has power going to it. Just to make sure, double check the wiring from the ceiling fixture to the fan.
Problem could be a faulty switch on the fan or faulty motor(bad winding for med. speed). Try reverse switch on the fan to operate the opposite direction and see if medium speed works. If medium does work in opposite direction, it pretty much points to a defective fan. In any case, unless you discover that the ceiling wires were reversed going into the fan, I'd say new fan to the returns dept.
Posted on Jul 21, 2009
Where is fuse in fantasia viper ceiling fan
It is highly unlikely that a ceiling fan would have a fuse, it would usually rely on the house wiring protection system in the event of an overload or a short circuit.
Jan 15, 2011 | Fantasia Viper (110927) Ceiling
I need a diagram for the wiring that goes from the fan to remote speed settings and then to electrical wires in ceiling
all of the white wires connect together and to the white house wiring (neutral from ceiling) ..also the neutral or return wire for the controller (may also be white) .. then the black house wiring(or red if you have an external wall switch) is connected to the controller wire marked AC or AC input .. the output marked "lamp" on the controller connects to the blue wire that goes to the light bulb (or bulbs) ... the output called fan goes to the black wire of the fan motor .. the green house wire goes to either a bare wire, green wire or a green bolt that is screwed to the metal of the fan.. thats the safety ground ...
Jun 05, 2010 | Hunter 52" Ceiling Fan With Light And...
Ceiling fan capacitor hook up problem. I have a 3 speed fan. 4 switch. A 3 wire capacitor - CBB61. Kids lost wiring diagram. Any which way I try to wire it up only one of the speeds works. Any wiring...
The reverse switch on my Hampton Bay ceiling fan didn't work. I cut the 6 wires; 1 white, 1 gray, 2 pink, 2 yellow. Here's what I did. Removed reverse switch. Had 6 wires white, gray, 2 yellow, 2 pink. Connected gray to yellow, connected white to pink and fan runs fine. Is this OK? I do not need to reverse fan. It's been running for 1 hour now with no problems. Don S.
May 15, 2010 | Dryers
Jul 21, 2009 | Hunter Ceiling Fan Control Switch
Remote needed
If you talk to Fantasia Fan people, they may be able to help you. I've had spares from them, & they were helpful.They also supply a wall mounted, wired controller, but it needs an electrician to do the wiring. The plus with hard wiring is that it doesn't have a wireless controller pack to go wrong.
Dec 18, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
WIRING OF 3-WAY SPEED SWITCH FOR HAMPTON FAN
1 - Red/Pink
2 - Purple
3 - Yellow
L - Black
Mar 11, 2008 | Oasis Hunter 54' Ceiling Fan
Dryers Logo
23 people viewed this question
Top Dryers Experts
