Question about Western Digital WD2500AAJB 250 GB EIDE Hard Drive
Dead drive? I inherited a computer and when I try to turn it on the fans start for a few seconds and the hard drive engages but then everything immediately shuts off. If I disconnect the drive then it will try to boot but finding no bios it then shuts off.
    New Friend:
  • 24 Answers
Double check that the hard drive jumpers are set for auto select/ or master. may have come from someone that had multi drive setup. reconect the cable to the master position on the motherboard, and master on the cable.
Try to enter the bios setup for the computer, and check that it is finding the hard drive. the system may not be configured for that drive. some computers setup can be accessed by pressing f1 or f10 button while first powering up unit.
Posted on Jul 23, 2013
APremkumar
  • 564 Answers
SOURCE: My external drive was working fine. After shutting
Click Here to take control
If you wish I can take control of your computer and try to fix it.
Thanks, PREM
Posted on Mar 22, 2009
SOURCE: Windows Vista does not boot with hard drives plugged in
I had the same problem with vista home 32bit. I accessed the bios then went into usb configuration, and disabled the "legacy suppor" for usb, this is an older support for usb 1.0 before 2.0. Once disabled was able to reattach two external hdd, and reboot normally
Posted on Mar 25, 2009
philschneide
  • 448 Answers
SOURCE: purchased an external hard drive for backup. When
When you first turn your computer on, during the first few seconds the screen should give you information about what is happening, AND it should tell you to press the delete key in order to get to the bios settings. Do that (press the key several times to make sure you get there). Once you get to the bios settings find the ones that control the boot disc (usually you will see 1st boot and 2nd boot, and each will allow several possibilities, including floppy boot, if you have one, as well as cd or dvd boot, etc.) Make sure your hard disk is selected as your first boot choice, then save the selection and reboot.
I think this will work for you.
Posted on Oct 06, 2009
  • 181 Answers
SOURCE: my computer can not find my second hard dirve
go to the device settings and try to find it by scanning the usb port.when he removed the info was it still in the case .if not the problem is with the usb out-put board in side the unit.
Posted on Dec 09, 2009
  • 10406 Answers
SOURCE: the Green Ring just keeps
The external storage device has several major components:
* USB cable
* external power-supply
* disk-drive inside the enclosure
* USB-to-disk-drive adapter inside the enclosure.
Try a different USB cable.
Try a different USB port on your computer.
Try a USB port on a different computer.
Take a multi-meter, and measure the output voltage/amperage of the power-supply,
and compare with the specifications on the label of the power-supply.
Open the enclosure, and remove the disk-drive, and attach it as a "slave" drive in a desktop computer, to see if bypassing the USB-to-disk-drive adapter bypasses the problem.
Look at the label on the disk-drive, for manufacturer, product-number, serial-number, and manufacture date. Access the manufacturer's web-site, and use "check warranty status" to see if the warranty still is valid. If so, the drive can be replaced, at minimal cost to you.
Buy a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive.
Posted on Nov 05, 2010
Acer aspire 5532 won't start
I had the same identical problem with a Toshiba. I got hit with a 'rootkit'. It's like a virus on steroids. If it didn't cook your hard drive AND motherboard, a computer shop MIGHT have the necessary resources to fix it. Hopefully, you kept everything backed up.
Dec 28, 2012 | Acer Computers & Internet
I have a computer that would do nothing when turned on, including giving no beep codes. Everything seems to be getting power - the CD drive, CPU fan, and hard drive all start spinning. I disconnected...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
hope this helps
Dec 05, 2010 | Acer Computers & Internet
I push the ?Power? button on my P205-S6237 and the power light is on, and hard drive starts to spin ( I hear the sound), the DVD-ROM and the processor fan start to spin, but nothing else happens. The...
I have the same problem with this computer if you are like me the battery life is also VERY short so it goes dead quite often.
I fixed a laptop a few months back with this problem "or atlest the exact same symptoms" what I did to fix it was take out the ram and the bio battery which rest the the bios and I was able to start it normally.
I however am currently unable to easily find the bios battery on this motherboard. I have been looking for a diagram to no success. I know about computers but dont want to just start taking it appart. If you find the battery or a diagram please let me know.
Jan 31, 2010 | Toshiba Satellite P205-S6237 Notebook
Acer Aspire 5100 will not boot
Two possible Solutions:
1) The Hard Drive has come unseated - Disconnect the Power and REMOVE all connections, Close the Screen & Turn your Laptop Upside Down and Remove the Battery, Locate the Hard Drive Access Panel and Remove the Screws from the Panel, Remove the Panel, Remove the Hard Drive. Carefully Replace the Hard Drive, Replace the Panel and Reconnect the Battery & Power Supply. See if the Computer will Start
2) The Operating System is Damaged OR the Hard Drive is Dead - You will need to slave Your Hard Dive into a Second Computer and Backup ALL you Personal Data OR RISK loosing it. If the Second Computer can NOT read the Drive, the Hard Drive is Dead (A Computer Repair Company may be Able to Help)
Once your Data is Safe, you can try to Repair the OS by Booting your Computer with the Drive in it. Begin pressing F12 or F10 at bootup (Once a Second). You will be presented with an Options Page for:
System Restore (FIX WINDOWS)
System Recovery (Wipes your Computer and Retores the Factory Software)
Hope this Helps!
Dec 22, 2009 | Acer Aspire5100 Notebook
ACER Aspire L100 Desktop is dead?
If the hard drive is OK then you can remove the hard drive from the desktop case, and insert the hard drive into a USB 3 1/2" hard drive adapter case, this should come with a power adapter. These are available at your friendly computer shop.
Boot up the laptop then plug this USB hard drive adapter into the laptop's USB port. The laptop will see this as an external USB hard drive. You can open the various folders and files on this external drive and copy the folders and files to the laptop.
You can delete the Windows folder and Program Folders on this external drive to free up disk space and use this as a back up drive etc.
If you are not sure how to remove the hard drive and install it into an USB hard disk case, then I suggest you get a computer savy friend to help you.
Dec 08, 2009 | Acer Aspire L100 PC Desktop
P4 PC with Antec power supply won't start when ''cold''.
The first thing you should do is replace the power supply with another and see if the problem continues. if it does call me and we will work it out
Marc
215-729-1745
Apr 15, 2009 | Computers & Internet
Computer won't start up and has a constant tone.
If the noise is constant then it means the problem is either:
1: a Power supply issue
2: a motherboard issue
3: a keyboard problem
the latter of the three being the easiest to fix, try booting with your keyboard unplugged or even better if you have another keyboard try using it to see if that corrects the problem.
If the above does not work then you have a problem with 1 or 2, and in order to find out for certain you will need to test it, you can goto your local computer diagnostic store to see if they can check which it is.
and hope its not a problem with the motherboard.
Hope this helps, and Good Luck
Apr 13, 2009 | Computers & Internet
Took cmos battery out
The battery is dead... please replace it.
this keeps all your system settings for start up.
Apr 06, 2009 | Toshiba Satellite L305D-S5904 Laptop
Western digital 1TB porable hard drive problem
a clicking harddrive means thats its dead, if you have a warranty still call up western digital and get it traded out. i wouldnt tell them it was dropped .
Jan 23, 2009 | Western Digital My Book Essential 1TB...
P4VP MX Mother mother turns on but shuts down after few seconds
If you have replaced the power supply, the motherboard is the next possibility. Try disconnecting the power plugs from everything except the hard drive your operating system is on to make sure that they aren't causing the problem (possible but unlikely). Then restart the computer. If it continues to shut off you'll need to replace the motherboard.
Dec 14, 2008 | ASUS P4VP-MX Motherboard
Western Digital WD2500AAJB 250 GB EIDE Hard Drive Logo
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
