Question about Dishwashers
IF THE MACHINE START IT SHOWS FLASH AFTER 2min
With all function
    Top Expert:
  • Dishwashers Master
  • 12,223 Answers
Test this steps and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Posted on Jul 23, 2013
Why is my1997 bmw Z3 1.9 start rough for 2min then is ok
The EGR valve opens when the engine is warming up, which allows exhaust to enter the intake manifold. This is essentially "extra air" coming into the engine. The engine has an "idle speed control" function, which is either a solenoid or small stepper motor connected to a valve that allows a controlled amount of air to "sneak" by the throttle plate in the throttle body. Fundamentally, it is the amount of air entering a fuel injected engine that controls engine RPM. A defective idle speed control ("ISC) motor or solenoid can cause the problem you stated. (I do not know which type is used in your BMW.) Often, a check engine light will illuminate of the engine computer cannot adequately regualte engine idle speed.
Aug 27, 2014 | 1997 BMW Z3 Roadster
How to do an idle relearn for 2001 cadillac DHS
is simple. start the car and let idle for 2min. drive 1 mi.w/o el. load and 1mi. with el. load(a/c, light) idle 2min. and is ready.
Apr 11, 2014 | 2001 Cadillac DeVille
Display shows Check Printer E 04 01
an E4-01 is a fuser warm up error...this is usually caused by a bad thermistor but can also be caused by a bad fuser lamp or thermostat
Apr 02, 2014 | Panasonic Workio Dp 8020e
All the function lights and pause lights flash
follow the steps and fix it. USE the VOM . God bless you
Check Power
Check the outlet by plugging an appliance into the same outlet the washer was plugged into an running the appliance a hair dryer works good for this it will draw some amperage. If it works fine move on.
Control
To check the control remove the top panel and then remove the console to access the wiring to the control. Find the wire feeding the control from the main power cord. If you cannot visually see this refer to the tech sheet or service manual. Connect voltmeter to the 2 wires feeding the control if it is recieving power and it does not respond replace the control
May 28, 2013 | Washing Machines
Can I use a full synthetic motor oil in my 94 toyota pickup truck
you can use full or semi synthetic after use engine flash oil for 10 min RPM 2000 then drain the flash oil and replace oil filter with new one . after you start engine for 2min then check engine oi level add to reach the level
Jun 20, 2011 | Toyota Pickup Cars & Trucks
Stop 2min and run for 2min, stop 2min and run for
your motor thermal safety relay is protecting the motor from burning out
this is usually caused by: an old motor about to fail (tight shaft bearings) bad centrifical switch or, an obstruction in the water flow causing the motor to work too hard (draw too many amps, get too hot then cool down and, start up again
check the relay it is located on the side of the motor on most motors; under a cover; unless the motor is bad the relay may just be too sensitive (old) and, may need to be replaced.
Jul 24, 2010 | Whirlpool Jacuzzi Jacuzzi Bath Fuzion EF50...
All lights flash and error E90 shows on my Zanussi ZWF1631 washer
e90 is a cable problem linking main board to user board on the front
Jan 12, 2010 | Washing Machines
How do I turn on the flash on 8025
1. Touch the flash function area (lightning bolt with downward-pointing arrow) until the flash icon with the "A" shows up on the left side of the display. This activates the automatic flash.
2. Touch the flash function area again until the flash icon shows up. This activates manual flash.
3. Touch the flash function area again the eyeball icon shows up on the left. This activates the red-eye reduction mode feature.
4. To turn off the flash, touch the flash function area repeatedly until the flash icon insie a circle shows up.
This is all explained on pages 13-14 of your manual.
Jan 05, 2010 | Vivitar ViviCam 8025 Digital Camera
With full, new cartridge, test print only shows 6-10 dots. Cleaning repeatedly does not fix.
Try powerful cleaning:
Press menu, then start black copy, then four times arrow-up quickly after another.Machine will be in maintenance mode
(all lights will flash).
Press 7-6-4 and OK (or start-black-copy).
When finished press 7-6-3 then start black copy,
printer will do a power purge.
Leave maintenance mode by pressing 9-9.
If this not help better think about new printer, because cost of repairing this one is profitable.
Nov 19, 2009 | Brother Multi-Function Center MFC-240C...
Dishwashers Logo
239 people viewed this question
Top Dishwashers Experts
