Question about Toshiba Satellite A60 Notebook
SOUND PROBLEM NO SOUND FULL OFF VLOME SWITCH NOT WORKING
    Top Expert:
  • Toshiba Master
  • 12,223 Answers
Restore go to control panel, use the utility system restore, and use the last date that you know was working GOOD.
God bless you
Posted on Jul 23, 2013
Phone MT65xx is not switching on what to do... charging already full.. it was working suddenly everything gone now no display on phone
Sounds like hardware problem. Maybe screen dead and needs to be changed. I would take it to a service centre to get it tested...
Mar 09, 2013 | Apple MD379LL iPhone 4S 32GB Sprint Mobile...
My dehumidifier is only about a year old and the bucket full light keeps blinking. i turn it on, it sounds like its going to kick on but shuts off a second later.
It sounds like the switch under the bucket is stuck. Remove the bucket and there should be some kind of switch where the bucket rests against. Make sure the switch works freely if not spray a little contack cleaner on it and work the switch by hand until it frees up.
Mar 11, 2011 | Goldstar DH504EL Dehumidifier
Will not start at all not a full sound bat on full charge
Does the engine crank OK?- was it running?
Is there fuel? check for a spark by pulling off the HT lead and fitting a plug & cranking - Spark? No? Check clutch switch, neutral switch & sidestand switch & kill switch work OK.
Spark? Yes?
Drain carbs via bottom screw to get clean fuel / any sediment out.
Clean plugs. Check choke linkages,
Feb 10, 2010 | 1996 kawasaki GPZ 500 S - GPX 500 R
Full beam will not stay on !
it sounds like the switch is bad. I assume it is pull for "flash to pass" and push for high beams. Check your owner manual.
May 14, 2009 | 1996 Volkswagen Golf
I put in a load this morning .
The switch on the door, is it clicking when you open/close it. Sounds like the switch.
May 09, 2009 | Maytag Atlantis MAV6000 Top Load Washer
The bosch 11227e rotary hammer will not energize when
It sounds like the cord is ok as you have power to the switch. It also sounds like the switch is OK. These units have a governor on them as well. I suspect the governor because you indicated that the hammer will not come up to full speed. Beyond the governor, the only other thing to look at is the motor. You did say that you didn't notice any sparking so the motor sounds like it is OK.
In my opinion from everything you said, its the governor.
May 01, 2009 | Drills
Toshiba 35AF44 Sound on full & will not shut off.
Well, a shorted diode on the keyboard circuit would be likely. When you change out the tactile switches, did you check for any shorts on any of the switches?
Nov 07, 2008 | Toshiba 35AF44 35" Rear Projection...
Full bag system works properly, but doesn't reset easily
Either there is something wrong with your switch. Which it doesnt sound like it. Take it to your dealer or call another one it sounds like the control valve needs to be replaced. I am a dealer 1-866-966-9350.
Jun 19, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
Strange buttons work
Press the reset button for more than one second with a pointed tool to reset the Network Walkman series .Any audio files stored in the memory/the clock setting will not be erased by resetting the unit
Aug 11, 2006 | Sony NW-E105 MP3 Player
Toshiba Satellite A60 Notebook Logo
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
