Where can I purchase a new 'upper looper for my Silvercrest KH4300 overlocker?. Mnay thanks..
SOURCE: timing on a Huskylock 535D surger
the eyes of the needles must line up with lower looper as they pass (timing) the distance between the needle and the looper must be exact. No distance between them and not touching. yep, that tight. they shouldnt move the needle even the slightest amount as they pass each other, yet no space between them.
Kent
SOURCE: Owners Manual needed for Overlocker Toyota SL 3404D
"World of Sewing" have these manuals.....you need to ask for "Toyota SL series". I got my replacement manual from them and the service is excellent. Their phone number is online if you want to ring them (UK ) Hope this is helpful to you
SOURCE: Serger stitch not forming right
It sounds like the timing needs to be reset by a sewing machine repair tech.
SOURCE: I bought a silvercrest overlocker
Kindly confirm the model number? Do you have an instruction book for the same?
Thanks!!
SOURCE: I have a singer Overlock
Yes, it can. What do you have your differential set at? Try it in the middle and see if it makes a difference.1 is usually for overedging, 2 is usually for easing in a sleeve, etc. I have my tensions set at 4,4,4,4, stitch length at 3 to 4. Do not be afraid to try gradually changing the tensions, but do them one at a time, that is what I did and finally got it.
