Baitcast reel schematics
I was cleaning my kv1100hxe and when putting it back together I think I messed something up. The bearing for the spool will slip out and the spool is then not connected and the spool doesnt spin. I have it positioned right I'm pretty sure, but something is wrong.
Lumpy816
  • 246 Answers
SOURCE: My Oasis washer started flashing
Since I haven't heard back on this in over a week, I will assume it's been resolved with the clarification questions.
Posted on Jul 23, 2008
localwonder
  • 6784 Answers
SOURCE: RATTLING & DRUM NOT SPINNING EVENLY, ALTHOUGH CHANGED BEARINGS TW
Check the belt. it may be broken or, it may have slipped of the pulley or drive motor. if the belt is fine, replace the motor.
Posted on Jul 11, 2009
TheMobilian
  • 8220 Answers
SOURCE: I have just put new
I do not have the exactamundo but here is an GWlo3 Repair Manual with photos F&P Fileshare
Bonus
Posted on Dec 30, 2009
  • 1937 Answers
SOURCE: Kenmore out of balance after installing a new coupler
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washerhttp://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.24964300&pathTaken=partSearch:
and you'll see a list of major sub-components with diagrams and parts.
If you look at the section on "Machine Base Parts" you'll see a number of springs and vibration pads.
It's possible that one or more of the springs or pads has come loose or broken.
In order to get to them you have to remove the cabinet.
Here is a description of how to do it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=90fdc122f6335c7c64f46f2ea1b1c887
Also see the Whirlpool Service Manual for top load washers. It has a troubleshooting section that describes the reasons for excessive walking or vibration.
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
Posted on Apr 21, 2010
  • 1075 Answers
SOURCE: very loud when in the
yes your right the main bearing is gone and needs replaced,its not a easy job and unless you have a garage that you can work in then i would not recomend doing this job in the house as it means,stripping down the whole machine and then trying to remove the old bearing which is a days work itself, then replacing with the new one.I will leave the decision up to you.please rate this answer many thanks.adrian,,,,,,,
Posted on Aug 24, 2010
Get a fishing reel schematic
CUSTOMER SERVICE
This is a link to Quantum and the "Code Red" baitcaster.
You can also try the following warranty service center.
Home
Feb 21, 2015 | Quantum Code Baitcast Reel 8 ball bearings...
How to put back together a GSX Tournament Pro Spinning reel, GSXT2-40
Brian Neil here from Dark Side Reelz, the washers that feel off sound like they are the spacing washers responsible for the travel height of the spool. If they came off the main shaft immediately after you removed the spool it self that has to be what they are. on the shaft under the spool itself there should be a small gear that the washers sit on, the gear controls the clicker on the drag if this reel in fact has one. I did a quick search of my schematics and did not find a match if the schematic didn't come in the original boxing chances are youre going to need to contact the manufacturer directly. What is the actual Brand of the Reel ? www.darksidereelz.com for all your reel service needs
Jul 17, 2014 | GSX Tournament Pro Spinning Combo,...
How can I get my reel to cast smoothly?
Hey Ken, Neil here from Dark Side Reelz. it boils down to over oiled bearings, or bearings that require cleaning, your spool shaft only rides on 2 or max of 3 points, (depending on reel make) each of those points contains a bearing the spool shaft seats in those bearings any build up will greatly reduce casting distance. I specialize in reel cleanings, rebuilds and restorations as well as custom work like upgrades and super tuning. If you would like to read some really good info on what you can do read this article I wrote http://ezangler.com/tackle-box/gear-tips/the-reel-truth/ here is the link to my webiste as well www.darksidereelz.com
Jul 05, 2014 | Generic Ardent C400 Fishouflage Bass...
KVD Quantum kinetic PT baitcaster reel, problem is I took it apart to clean it and couldn't figure out the right way to put it back together with all the spacers please help
I know how much everyone loves those reels They are great when they are new. But the truth is They are made to sell and they do sell. But I will bet a dollar to a donut that You would have 300% less trouble out of a Shakespeare Reel with less trouble and 70% less on cost and you cant wear them out.
Mar 31, 2013 | Fishing
Howtoseyupaspincastingreel
use 10# test line or heavier. use 3\8 oz lure or heavier. set magnetic control to "5". tighten small silver knob under the reel handle down until the spool will not turn when you push the thumb bar. loosen the same silver knob while you have the thumb bar pushed and adjust the knob tension so that the spool stops turning when the bait hits the ground. this is basic tuning for any baitcasting reel.
Jul 08, 2012 | Abu Garcia Pro Max Baitcast Reel
Cant cast the pinnacle platinum plus lp 100 fishing reel more than 15 feet because the line tangles. Any suggestions?
Sounds like your drag is too loose. Best way to get used to setting a baitcaster, in my opinion, is to put a 1/2 ounce weight on the end of the line and engage the spool. The line should drop to the ground freely, but not full speed - if too fast, the spool will continue to spin and you'll get that dreaded birdsnest. If it doesn't reach the ground, you need to loosen it more. Once you have it set, keep that weight on and go practice, using the thumbing process Parorae noted in the previous answer.
They take some getting used to for sure!
Aug 04, 2010 | Pinnacle Solene SLP10 Baitcast Reel
Bird nesting I think something is missing like a washer on the spool shaft under the cap and I don't know what should be there
common problem especially with new users who are used to fixed spool casting, when casting with a multiplier you should keep your thumb over the drum so you can slow down the drum as your cast slows to fall in the water, if you had a drag washer you wouldnt be able to cast, you will get the hang of it with practice, but even with 30 odd years of use i still ocaisionaly get a nest.
Jul 06, 2010 | Pinnacle Inertia Baitcast Reel
How do you put line in
Run your line through the guide and tie around spool using a good double loop knot
Oct 14, 2009 | Pinnacle Inertia Baitcast Reel
I just recently purchased a shakespear sigma baitcast reel, and I can't cast the thing without backlashing it
Baitcast reels are very frustrating to some people. There should be a dial on the side which controls a magnet that keeps it from backlashing make small adjustment and cast also use your thumb to aid in controlling the spool.Then practice practice practice.
Sep 06, 2009 | Sport & Outdoor - Others
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
