Question about Logitech Inc G7 Cordless Laser Gaming Mouse DH931375
Where can I find a replacement L-LL11 battery for my Logitech G7 Mouse?
Where can I find a good replacement L-LL11 battery for my Logitech G7 Mouse?
    New Friend:
  • 35 Answers
Here is a site that carries the replacement L-LL11 battery that you are looking for:
Replacement L-LL11 Battery for Logitech G7 Mouse
Posted on Jul 22, 2013
Pointer on a G7 logitech mouse and win vista 64 pointer will not access any buttons I am trying to access and its like someone else is taking control I try to enter a message and use the click symbol on...
Dirty lenses. Simply clean the lens with a cotton bud and some clean alcohool or.. replace the mouse.
Rechech if the mousepad is not a shiny refflective surface like glass. Try a sheet of paper under for test
Dec 14, 2017 | Logitech G7 Mouse
Mouse will not charge when put in the base
I have a very bad solution about this, but it works on my mouse that also doesn't work. Try to put a tiny bit of water ( or spit Oo ) on the little, usually copper, receivers on the mouse. That makes for a better contact. Just get your finger wet and touch those receivers.
May 15, 2010 | Computers & Internet
My g7 cordless mouse usb clip broke can i replace just the reciver?
Sir, I'm sorry to say it is not possible you have to buy new one.
Nov 11, 2009 | Logitech G7 Laser Cordless Mouse
The right button on my logitech g7 double clicks how can i fix it
Go to Control Panel
Double Click on Mouse
Take the check mark out of Switch Primary and secondary buttons
Sep 19, 2009 | Logitech G7 Laser Cordless Mouse
Need to replace the battery in a Logitech MX Revolution Mouse
Hello. Yes, it is quite simple to remove the battery of a Logitech MX Revolution mouse yet for some reason when going through the Logitech product support website it states that it is not possible. Just remove the 4 teflon pads located on the bottom of the mouse and then remove the four screws located under the pads. Once this is done turn the mouse back upright and remove the top off of the mouse. I would suggest temporarily removing the flex cable that holds the top and bottom of the mouse together. There is a small metal clip that holds the battery in place that must now be removed.
NOW FOR THE VERY IMPORTANT PART. There are two different generations of the Logitech MX Revolution mouse which have different batteries. The first Generation uses the L-LY11 battery and the newer generation of the MX Revolution uses the L-LL11 battery. There is no way to tell which battery your mouse uses without first opening up the mouse. Once opened you can easily tell which battery your mouse uses. Here is a link to a site that shows you an example of the L-LY11 battery: MX Revolution L-LY11 Battery
Here is a link to a site that shows you an example of the L-LL11 battery: L-LL11 Battery for Logitech MX Revolution Mouse
As you can see the L-LY11 battery has wires and a plastic connector and the L-LL11 battery has contacts. You should definitely determine which battery your mouse uses ahead of time to eliminate any frustration caused by ordering the wrong battery ahead of time.
Sep 12, 2009 | Logitech MX Revolution Wireless Laser...
Logitech G7 cordless laser mouse - erratic action
Acting on advice from another FixYa string, we blew out the mouse and dock several times with canned air. It performed slightly better, but then as we continued to use the mouse it suddenly cleared and is working almost 100% now.
From reading earlier strings, I'm wondering why Logitech (in its product material received on purchase) doesn't recommend this as periodic maintenance for the mouse?
Dec 08, 2008 | Logitech Inc G7 Cordless Laser Gaming...
Battery
Not sure how your mouse is configured but will give you two possibilities to use.
Turn your mouse over and see if there is a small door on the bottom where the batteries are located.
Normal 0 If the mouse doesn't have a little door to open on the bottom, then try this. Just behind the Left and Right keys where your hand rests, apply firm pressure down on the cover and slide to the rear. Some mouse manufactures have used this type of access to replace the batteries.
Hope this helps. Bud
Aug 21, 2008 | Logitech MX Revolution Mouse
Logitech G7 Laser Mouse not responding
Dont worry SourCandy, just use a soft cotton cloth and some mild detergent like a glass cleaner and clean the bottom of the mouse and use a plain dark coloured mouse pad...!!! This shd definitely work..!! Hoping a gud rating from u...!!!
Thankyou
Feb 15, 2008 | Logitech G7 Mouse
Logitech G7 Mouse problems
This is a well documented problem with the G7.  Which sucks b/c this is the best mouse I've ever used.  Thankfully though the problem appears to be the battery contacts on the inside of the mouse just get pushed back with changing the batteries.  Solutions I've read about is putting a few layers of tape on the back of the battery to push the battery further forward agaisnt the rear stop.  A drop of solder on each of the battery contacts would also do the trick, but getting the solder to stick is a trick.  (If you try this, it is very bad to heat up a battery with a soldering iron, so be extremely careful).  A better solution is to take the mouse apart, a brief overview of disembly can be found here,
http://www.bitbenderforums.com/vb22/showthread.php?p=441061
Although since I didn't have teflon tape laying around...if you have used the mouse enough or just push a bit on the pads, you can see the outline of the screw holes, and just cut through the pad w/ an exacto knife.  The one under the label already had scored lines which made that one easy.  Once the cover is off I just used the tip of the exacto knife to pry the contacts out a bit more (remove the battery before disembling), cleaned the scroll wheel off, and put the mouse back together.  Works like new so far, which is good b/c from what I've heard Logitech isn't very good about replacing the mice w/o a recipt (which I think I lost after a week, nevermind 3 years).
Hope that helps, this really is the best mouse.
Dec 29, 2007 | Logitech G7 Mouse
Logitech Inc G7 Cordless Laser Gaming Mouse DH931375 Logo
80 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
