Question about Champion International Champion 8000lb Winch Kit - 18001
Electrical diagram for 8000lb champion winch
Solenoid click wont run
    Top Expert:
  • Champion Int... Master
  • 45,363 Answers
Winches are out in the worst weather so before I looked at a wiring diagram I would be checking the condition of all the terminals for clean and tight. Next check the charge rate and condition of the battery driving the winch even having a load test done on that battery to see if all the cells are ok as when the solenoid clicks but no more the results are the same as a bad battery in the car.
Posted on Aug 07, 2013
Champion 8000 pound winch parts list
Contact them direct. Here is your manual and contains contact details.
http://www.championpowerequipment.com/media/1264/10021m_manual-english.pdf
This place does parts, and shows a schematic, but they go by model number.
Champion Winch Parts
Apr 14, 2017 | Cars & Trucks
My warn vantage 3000 will not spool in. solenoid clicks but motor does not turn. winch operates on out. use for snowplow, only a month old
If motor runs in one direction motor is not burned out.
Solenoid clicks, solenoid is ok.
Most likely points on solenoid on one side. If you can get to it, then look at the points.
To check , reverse battery terminals then click. the reverse should work and the other not. This will prove the points are bad on one side. .
In that case, you have to take it apart put in new points or get new switch.
Feb 15, 2015 | Vantage 3000 Winch-ATV
How do i rewire a warn 12v 8000lb winch
There are lots of links on the internet to wiring diagrams; just make sure they match the winch you have
warn 8000 lb winch wiring diagram Google Search
Feb 01, 2015 | Cars & Trucks
What is the wiring diagram for winch remote
Ramsey website shows Badger wiring diagram for solenoid hookup etc but not plug. Shouldn't take a good DIY mech or auto electrician too long to work out which wire goes where especially if they loosen the socket it plugs into which should reveal which wires go to where on the solenoid block. Basically that's all they do, there's a supply side, a ground wire and all the hand control does is switch the supply to the solenoid for forward and reverse. From memory there's only 4 wires? Supply to hand control,1 wire to one sol, 1 wire to other sol, 1 ground wire. Supply could be red, ground is usually black, fwd / rev will be 2 other colours. Look at the socket to see match up?
Jul 20, 2014 | 115101: Ramsey Badger Series Winches
Was installing a winch on my 2009 prowler 700 xtx hooked positive cable to selanoid winch did not work,hooked direct to battery,works,rig wont start
Where did you ground the winch motor? You need a separate, heavy duty, switch with a relay to transfer the positive side voltage properly... DO NOT ground to the battery..use a clean, free of paint, place to ground. You may have fried the solenoid..do not connect the positive side to the solenoid. Direct connection to the + battery from the relay is good with a good waterproof fuse in line. Sometimes I have seen the "maint. free" batteries die when used "wrong" and still show 13 volts+.
Apr 08, 2014 | Arctic Cat 2009 Prowler 700 H1 EFI XTX 4x4
Irrigation valve parts diagram
Most likely cause is small bit of contaminant (TFE tape, etc.) is caught in the seat area, or possibly (if electrically actuated) the solenoid is not working properly.
Jul 24, 2013 | CHAMPION IRRIGATION PD Champion Irrigation...
Tmax winch no power
The winch has electric solenoids to control the motor. Most of the time when these things quit working, it is either because the solenoid has failed or the wire connections to the solenoids has come loose.
Mar 23, 2012 | Cars & Trucks
How would I get a manual for a 10,000 lb Champion winch
Navigate to the Champion website using this link
http://www.championpowerequipment.com/truck.php
Scroll to the bottom of the page and select your winch model (there are five different 10,000 pound winches to choose from). From there you can download the manual in PDF form.
Hope you found this helpful.
Jul 28, 2011 | Cycling
I have a Champion 8000 lb. winch. It was working great and then just stopped. When I hit the control button for it to pull in I hear a click but the motor does not turn to bring in the cable. When I hit...
It's most likely your selinoids it probably has 4, 2 for in and 2 for out. (If it's anything like the warn 8000) and it could be just 1 of each or both of each. I was told by warn to change one out at a time to find the bad ones.
Apr 03, 2011 | Champion International Champion 8000lb...
My winch won't work anymore...there is a clicking noise and winch wont turn....I check the connection and its good.
Take your voltmeter and verify your voltage at the switch. If it is 11.5 or better, try reversing the motor. Reverse direction requires less ampreage to run and should work fine, then try forward or wind.
Nov 04, 2010 | Electric Superwinch LP8500 Series Utility...
Champion International Champion 8000lb Winch Kit - 18001 Logo
259 people viewed this question
Top Champion International Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Champion International Boating Expert? Answer questions, earn points and help others
