Question about Car Audio & Video
How can I install a speaker/sub into the backseat of my 1993 gmc sierra?
I want to install a speaker literally into the bottom side of my backseat because I drive with it up most of the time and the extra sound would be nice. Any ideas?
    New Friend:
Nt Best choice to go with would be 1 or more shallow mount 10" or 12" depending on sound. 6" deep box to bound to bottom of seat.
If use of 10" subs use hole 15" of width provieded off set your subs 3" up from the center of box allowing 3+ " for a lengh size slot port (allowing for more air and clearer sound since it under the seat) this will also allow you to lay seat down and get full use.
Posted on Jul 23, 2013
The firing order for a 1993 2500 GMC Sierra
V-8 engine firing order is: 1-8-4-3-6-5-7-2
4.3 liter V-6 firiing order is: 1-6-5-4-3-2
Jul 29, 2014 | 1993 GMC Sierra K2500
I need a diagram for 1993 gmc sierra 1500 truck firing order from dist. to plugs
Sierra 1500 also C/K Series have three engine sizes; check this...
1993 GMC C 1500 P/U 5.0 liter V-8 VIN "H"
1993 GMC C 1500 P/U 4.3 liter V-6 VIN "Z"
1993 GMC C 1500 P/U 5.7 liter V-8 VIN "K"
Hope helps (remember to rate this answer).
May 03, 2011 | GMC Sierra 1500 Cars & Trucks
We need the Firing order.
Hope this helps (remember to rate this answer).
Mar 20, 2011 | 1993 GMC Sierra
15PLB76 15 Inch 800 Watt Woofer Car Speaker: what subs will be good to fit in my gmc sierra sin...
single shallow with a sealed box it would sound great!! no air tombs they **** thats called ported they really ****
May 17, 2010 | Audio Pro 15PLB76 15 Inch 800 Watt Woofer...
Where do i find a knock sensor a 1993 gmc sierra
Should be on the right side of the engine by the starter.Has a 1 wire connector.It does not go into the cooling system so you can just take it out without draining the coolant.Hope this helps.Good luck.
Jan 06, 2010 | 1993 GMC Sierra
My GMC truck 1993 Sierra just had new headlights installed. But the high beams point into the trees. It seems both the high and low beam lights are in one enclosure. Can I adjust these down?
Yes you can. There is an adjustment screw at the top of each head lamp and you just turn them out or counter clockwise and the beam will come down. You may also have to adjust them side to side also. There is an adjustment screw as well.
Aug 27, 2009 | 1993 GMC Sierra K1500
I am trying to install a amp and sub in my 08 gmc
dont need a diagram,, most amps have a speaker level input...dont mix this up with line level....connect your wires from back of factory speakers to speaker level input on amp...then if your amp has a low pass switch select lowpass setting now you have punch
Mar 29, 2009 | 2008 GMC Sierra 1500
Hydraulic lifers in 2004 GMC Sierra
You have a coolant leak into the lifter valley,I suspect the engine is equipped with aluminium cylinder heads,cracks can appear at the cyl.head bolt bosses causing a wash out condition to the lifters.Add a coolant dye,run engine for 15min,apply a pressure test to cooling system,remove left valve cover & rocker rail & check around centre 4 cylinder head bolts for signs of the dye.The only correction is replacing the cylinder head & while you are at it also have Tec check the right side as well.
Mar 29, 2009 | 1993 GMC Sierra
Car Audio & Video Logo
79 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
