Question about FixYa Computers & Internet
Re: Baffle Part Ordered for Washer
Ordered the baffle today for my washer. Is it safe to use washer with baffle missing? Or, do I have to wait until I receive the new one? Thanks!
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 43 Answers
I would not recommend it.
Posted on Jul 23, 2013
Washer door leaks
The front baffle/boot will likely need replaced. You can do this yourself but it takes some patience. You can order the part, list model #, at 888-321-3107. The procedure is as follows:'
1. Tilt washer, back against wall.
2. Remove wire spring with needle nose plyers. The spring is located at outside perimeter, under lip, of baffle.
3. Peel baffle from front panel.
4. Remove clamp from the outer tub lip. Look closely and you should find a large hose clamp. Use small socket wrench to loosen.
5. Install in reverse order. Be careful and take your time.
Rich
Western Appliance Repair
Washer Repair
Sep 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F & 5 flashing, clothes not drained
don' t remove back!  top comes off and drum can be spun  to access each of impellers in drum.
Jul 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Change one baffle only or do you need to replace all three?
No as long as the baffles are screwed in properly and no other damage is present it is not important at all.
Sep 30, 2009 | Kenmore Elite 45986 Front Load Washer
Coin stuck in front loader washer
GO TO www.repairclinic.com IN THE BRANDS WINDOW CLICK ELECTROLUX THEN IN APPLIANCE TYPE CLICK WASHING MACHINE AND LOOK FOR PART 1154917 CLICK ON THAT PHOTO AND LOOK AT ADDITIONAL PICS.YOU WILL SEE THAT IT SNAPS INTO PLACE. FROM HERE I THINK YOU CAN TAKE IT OUT AND RETIEVE YOUR COIN. GOOD LUCK
Apr 24, 2009 | Electrolux AWF1235 Front Load Washer
Kenmore he2 washer/baffle
those are a little tricky baffles to remove u should slide them toward u should come off they are tight
Sep 22, 2008 | Kenmore Elite HE4 Electric Dryer
Replacing the drum baffle in kenmore elite he3t front loading washers
The baffle basket, I ordered from sears for my Kenmore Elite he3t washer was a "new" design but the screw holes lined up. My baffle basket did not come with the screw either. I took out the screw from an existing baffle basket and found something close. Test it in the baffle basket before you try to install it. Be careful not to drop the screw or bit.
To replace the baffle basket. Remove top of washer using a screwdriver with a T20 torque bit. There are three screws at the rear. The top slides back about an inch and lift up. Place aside. Then you will see a hose going into the drum. Ignore the clamp, just squeeze the end going into the drum and work it out. Now you need to insert the baffle basket in the drum through the front door. It is easiest to rotate the drum so you are inserting it on the bottom. It slides in with the small end toward you and you must pull it forward. Hold the drum for leverage. Now rotate the drum so the new baffle is on top. You need to line up the screw hole and screw in a small screw. Replace the hose and top of washer.
Good Luck...
Aug 09, 2008 | Washing Machines
Replacement baffle installation
its a little tricky but can be done. Can you remove the top panel of your washer?? 3 screws along the back lip and the entire top will slide back and off. theres a little black hose leading from the soap dispensor to the top of the outer tub assy. its only pushed into the tub and is real flexible, pull it out .you see through the maybe 2inch hole and see he inner basket. as you rotate the basket from inside with your hand the inner baffle(s) will line up to the hole and depending on date of manufacture. they might have put a small stainless screws in from behind to hold baffle in place,ifso remve the screws and the baffle (although a little tricky should slide toward the rear of machine to remove, and pull toward the front to reinstall
Mar 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
How do I get to the baffle on my maytag atlantis? It broke off and I ordered a new part
pop open top using screwdriver, rotate drum slowly by hand until broken baffle at 12:00 position remove two screws and reverse process.
Feb 13, 2008 | Dryers
Baffle broke off
Hi, one of our baffles broke recently and I ordered a replacement kit from http://www.appliancepartspros.com/
Here is the link that will take you directly to the page:
http://www.appliancepartspros.com/Appliance-Parts/WHIRLPOOL-Baffle-kit--3-pack-item-number-AP3769371.aspx
Dec 30, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Replacing the fins on Duet whirlpool washer
most paddles are removed by grabbing hold of the paddle and pull towards the front of the washer which should release them youll need to lift it out when you have pulled on them love
Sep 12, 2007 | Washing Machines
Computers & Internet Logo
14 people viewed this question
Top FixYa Computers & Internet Experts
Mark Magill
Mark Magill
Are you a FixYa Computer and Internet Expert? Answer questions, earn points and help others
