Question about Zebra Eltron LP 2543 Thermal Label Printer
Driver I am not able to find drivers that say this specific model number. What driver set should I be using? Also, I just received this printer today (I bought off ebay in supposed working condition) and although I do not have the drivers set up yet on my pc, when I plug in the power and try to turn it on, I hear no sounds of power and what I assume to be the paper feed button on the top does not work. Is it safe to say this is not in working condition?
  • 7 more comments
  • Ashley Montpetit
    Ashley Montpetit Jul 23, 2013
    Since my original post, I found out from the seller which printer drivers that I need to get and informed me that I would also need to get the RS-232 DB9 drivers for the RS232 Serial 9 Pin RS-232 DB9 Cable Adapter to work properly as well.
  • Ashley Montpetit
    Seemed easy enough but I am still stuck on the first step and not sure what to do. I did find the RS-232 DB9 drivers and installed them, even thought the website that I got them from said that if using Windows 7 or 8 and connected to the internet I would not need to download them as the wizard would do it for me. My problem is, I don't get the wizard. Every time I plug it in, instead of getting that add new hardware wizard, I get a message that says: "USB Device not Recognized, The last USB device you connected to the computer malfunctioned and Windows does not recognize it. Recommendation- Try reconnecting the device if windows still does not recognize it, your device may not be working properly." The seller assures me that everything worked fine up until he sold to me so I can't imagine the adapter doesn't work now. At this point, I just don't know what to do and fear I've gotten in over my head. Can anyone help?
  • Brian Sullivan
    Brian Sullivan Jul 23, 2013
    Windows 7 First, please disconnect all USB devices and then perform the following steps Click Start button, type devmgmt.msc in the Search bar and press Enter. Click Continue if necessary In Device Manager, double click to expand Universal Serial Bus controllers, right click on the Host Controller, click Uninstall and click OK. Repeat the step 2 to uninstall all items under Universal Serial Bus controllers.Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
  • Ashley Montpetit
    Will this work for Windows 8 as well? I'm sorry I think I forgot to mention that I am running Windows 8.
  • Brian Sullivan
    Right click in the bottom toolbar from the toolbars drop down list select desktop this will add >> in the bottom screen toolbar select it then you will see a number of options select control panel it might be the second one with all control panel items scroll up the list you will see devices and printers if your printer is being recognised it will be there if not select the device manager from the list above devices and printers scroll to ports com you should see either a yellow question mark or a red X the driver will need to be updated right click select update driver
  • Brian Sullivan
    Click on >> then on the first control panel Hardware and sound add a device it will search for any newly connected devices, also you might select control panel system and security Review you Computers Status then select the Windows Update from the bottom left of the page you will see what updates are available and if any optional updates are available
  • Ashley Montpetit
    Ashley Montpetit Jul 24, 2013
    Thanks SO much for all your help Brian, you made it very easy follow. I have tried all of the above but every time I restart and plug it back in I keep getting the same message. Not sure if I should buy a new cable adapter or what at this point. The guy I got it from says everything was working fine before sending it to me but I suppose that don't mean a thing when it's not working now. lol. I also wondered if I should be doing all this in any particular order. I figured out which set of drivers to use for the label printer and tried to go ahead and install those but every time I tried that it would get about 3/4 of the way done and just freeze on me. I'm feeling a lil doomed here. lol
  • Brian Sullivan
    Brian Sullivan Jul 24, 2013
    Click on the >> then on the first control panel under the system and secuity tab select find and fix problems select use printer it will take you through a process of detecting problems
  • Brian Sullivan
    if still no luck try configure a device tab.
  • Zebra Master
  • 27,725 Answers
If you have not set the printer up it will not be in a working condition ?
Make sure all Power an Data leads connecting to your printer have dust free secure seating.
You might have to uninstall the printer restart your computer then reinstall your printer.
Click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you
might see a yellow? ! question exclamation mark or a red X this will mean you need to install a new driver for this device right click to update driver.
Rather doing a driver hunt which can take hours
http://download.cnet.com/SlimDrivers-Free/3000-18513_4-75279940.html
Windows XP/Vista/7/8
it might take some time being a freeware driver solution
Note: it will find all of your outdated drivers
This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
Posted on Jul 22, 2013
SOURCE: tlp 2844 printing issues
try powering off the printer, pressing the green button while powering back up then when u see it blink let go of the green button
Posted on Jun 25, 2008
  • 9 Answers
SOURCE: not printing
this problem will address on label and ribbon issue. you must establish your printer set-up first, meaning see to it that the label and ribbon was correctly loaded, if still problem occur try using manual calibration you can see how to do at the manuals you have..
Posted on Oct 31, 2008
  • 4 Answers
SOURCE: Zebra LP2844 not working at all after wrong power supply
what I learned.
the printers being sold as LP 2844 all over the place is actually an LP 2543. It was made for UPS, specifically, and they are being sold in large lots to refurbishers. It looks almost identical to the LP 2844.
LP2844:  DC 20V 2.5A tip positive; all of them have USB ports!!
LP2543: AC 16V 4A; have only parallel and serial. Cover has a lighter shade to it. Most either have the label scratched off or a fake one put on.
Posted on Apr 10, 2009
SOURCE: Zebra Printer LP 2844 not feeding
Thanks for the response. It turned out to be a faulty power supply which did not send enough power to turn the printer. now it works like a champ
Posted on May 08, 2009
  • 53 Answers
SOURCE: Zebra LP2824 not printing
Sounds like you put your printer into line mode. Line mode prints code so you can see what is sent to the printer to look for possible mistakes in the code.
To switch from line mode back to page mode.
  1. Turn printer off.
  2. Press and hold the feed button down. And switch printer on.
  3. Release the feed button when the LED flashes red.
  4. When the LED flashes green, press down the feed button.
  5. When the LED flashes amber release the feed button.
  6. Try printing now that the printer is back in page mode which is used for print your labels; line mode prints the labels code.
  7. Do this fast or else it wont work if you are slow.
Posted on May 12, 2009
I can not find a HP color Laser Jet 1600 driver in my computer to set it for printing. Can you help me down load the HP Color Laser Jet 1600 driver to set my printer up?
You need to download the printer drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the XP or Vista Windows version of the drivers you require and install them. Click on this link to download the drivers: -
http://welcome.hp.com/country/au/en/cs/support.html
Sep 06, 2010 | HP LaserJet 1000 Printer
I just bought this printer from someone and they dont have to manual and I can't get it to work what can I do
You can download the manuals and drivers from here:
http://welcome.solutions.brother.com/BSC/public/us/us/en/model_top/colormfc/mfc210c_all.html?reg=us&c=us&lang=en&prod=mfc210c_all
Download the drivers, install the drivers and connect the printer using a USB cable. Turn the printer on and it should be recognized by your computer.
If you have problems, please report back what specific problems or error messages you're getting.
Mar 28, 2010 | Brother MFC 210C All-In-One InkJet Printer
What printers are compatible with the ASUS G1 laptop? I bought an HP printer/scanner which wouldn't install. I asked Geek squad and they told me there were a large number of incompatible printers - but...
While I have never heard of a printer being incompatible with a specific laptop model, I have heard of geek squad giving bad advice. This situation would be the latter. If you are using Windows Vista or Windows 7 there are some older model printers that may not work up front, but right clicking on the software and selecting properties>>compatibility>>and selecting Windows XP from the dropdown list might help. Also going to the manufacturer website (HP, etc) to find updated drivers for the specific model printer and for your specific operating system may help you out as well. More often than not with Windows 7 simply running windows update will find the drivers you need, as long as you have everything selected to show up in updates and not just the important ones.
Good Luck,
NOLA Tech
Mar 21, 2010 | ASUS G1 Notebook
Do not have instalation disc what can i do
Please let us know the brand and model number of the printer and also the operating system of your computer so that we can provide you with the link to download the installation drivers if they are available online.
Thanks for using FixYa.
Mar 05, 2010 | Office Equipment & Supplies
I can't set uo the 2nd tray to print
Hi
Could be that you need a different driver I had the same with my printer so I found another printer drive and in the printer set-up options it can use 2 trays, try finding another driver for it.
All Best Pineworks
Jan 22, 2010 | Dell M5200n Laser Printer
I need a Vista driver for the Compaq A4000
hp does not currently have drivers available for Vista for this model
Jul 13, 2009 | Compaq A4000 All-In-One InkJet Printer
I bought lexmark printer (x4650)today but my laptop (acer travelmate c110) does not have a disc tray so can't load the software, is there a way around this, please help i know nothing about computers, I...
Go here to download the driver:
http://downloads.lexmark.com/perl/downloads/downloads.cgi
Input your system info, operating system and model number and your good to go.
Please rate this solution, the only compensation I receive is a good rating from you.
Lone99star
May 03, 2009 | Acer TravelMate C110 Tablet PC
Connecting Denon receiver to DVD player
Normally the optical inputs are disabled unless specifically turned on. I dono't know your specific model. I'll research the model and update this with more specifics.
Dan
Jun 17, 2008 | Denon AVR588 Receiver
Will not auto detect incoming faxes
Review the information below to determine why faxes cannot be sent or received. Review the symptoms below carefully and then select the symptom that best fits your problem. If the solution links you to a different document that does not resolve the problem, return to this document to continue troubleshooting. The fax machine doesn't receive or send a fax and prints an error report (bpu02549). Faxes cannot be received but they can be sent . Faxes cannot be sent but they can be received . Faxes fail intermittently or with only one fax number . Faxes cannot be sent or received or you're not sure of the problem . Faxes cannot be received but they can be sent Review the information below to determine why faxes are not being received. Phone company services: Do you have any of the following telephone line services from your telephone company: Voice Mail, Privacy Block, Security Screen, Anonymous Call Rejection, and Privacy Manager. These phone services are meant to prevent unwanted calls, but they will also stop faxes. Contact your telephone company for their recommended solution for receiving faxes on the same line with these services. If you wish to receive faxes automatically, verify that automatic answering is enabled on models that have an Auto Answer button, or that the Rings to Answer setting is set to a number equal to or larger than one for models that do not have an Auto Answer button. On models with an Answer Mode setting, it should be set to Fax, FaxTel, or AnswerMachine depending on your setup. If you have a HP PSC 2200 or an Officejet 6100 that interrupts calls or will not receive faxes, download and install the HP Firmware update for these products. Visit the HP Support and Drivers Home page . Select Download drivers and software. Type in your model number (HP PSC 2210xi for example). Click the search arrow to the right of the text entry box. You may be asked to select your product from a list of models. On the software download page, select your Windows version. Locate and select the firmware update. Follow the directions to download and install the update. If an answering machine is connected to the same line, fax reception problems can occur. These problems may be corrected by changing settings or phone line connections. For more information on using a TAM or distinctive ring service, go to Using the HP All-in-One and Fax Products with a Telephone Answering Machine (bpu04072). If you have a PBX phone system, or an ISDN or DSL modem connected to the line, there may be some phone line configuration problems. Fax machines are analog devices and cannot be used on a digital phone service such as those used in many businesses (PBX systems). Install an analog phone line for a fax machine. Refer to document Using an HP All-in-One or Fax Product on a PBX, ISDN, or DSL Phone System (bpu50333) to learn how to correct these problems.
Aug 02, 2006 | HP OfficeJet 6110 All-In-One InkJet...
Zebra Eltron LP 2543 Thermal Label Printer Logo
119 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
