Question about Waterco 00B9012 Baker Hydro Skimmer Parts Skimmer Control Plate Decal
Hello I have two Baker Hydro Skimmers in my 30 year old pool. From what I can tell the main drian was capped. Im only running on skimmers now. The drain is opened and I'm going to a side by side drain system. Is it neccessary to have a seperate pipe from the main drains to my pump?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 45 Answers
It is highly advisable to have a separate return line from any bottom or side drain plumbing. It is also advisable to have an on/off valve on this line. This allows for greater control of your filtration, assists when repairs are required and is most useful when seasonally closing the pool.
Hope this helps,
Osko Pool n Spa
http://www.oskopoolnspa.com
Posted on Feb 21, 2014
I have a pentair cartridege pump for my inground pool. In the skimmer basket there are 2 holes.one to the pump and one to the main, it looks like the one to the main has something blocking it. on the
all inground skimmers have 2 holes some pools use the front one for a equalizer that is if you pool water gets low the skimmer will still work if no hole in the side below skimmer it will be plugged sometimes pool builders mix them up and use the back one for the equalizer like I said if no round hole on wall below skimmer just disregard
Jul 06, 2014 | Pentair Pool & Spa
How do i set up the hoses on the BHR170 pump?
front of pump goes to skimmers and main drain if inground pool skimmer if above ground top goes to inlet of filter then outlet of filter goes to pool returns
Jun 01, 2014 | Sta Rite Sta - Rite 24" Sand Filter & 1 Hp...
What are the main types of aquarium skimmers?
The main types of aquarium skimmers are: Air Driven CC skimmers, Venturi skimmers, downdraft skimmers, and aspirating skimmers. For more detailed information about these skimmers, check out this website: http://reefkeeping.com/issues/2002-06/fm/feature/index.php.
Sep 05, 2012 | Fish
Suspected air leak from pentair 3 port valve?
One way to test this is to pour cool aid on the valves with it set to both settings and see if the water effluent changes color. If it does then you are looking at a rebuild or new valve. If it does not then you need to check the line to the skimmers.
Aug 10, 2012 | Pentair 2" Pvc, 3 Way Lube Free Diverter...
The jacuzzi magnum force pump can it be used for a fish pond
This is a lot of pump for a fish pond. You should use the safe-guards as you would find in a pool, two drain's separated by 3 or so feet and/or a couple skimmers. You dont want the fish getting pulled into the drains/skimmers. It will also be a lot of $ to run the pump compared to a smaller 'fish pond' pump ... of course your pond may be much larger than the average garden variety.
Personally, I dont think this is a good idea for a small pond. Tell me more about your pond.
Thanks for your question @ FixYa.com
Jul 08, 2011 | Jacuzzi Magnum Force Series Pool Pump 1...
My pump is running and water is returning to the pool but there is no suction.
Are you saying there is 'no suction' or there is 'little suction'? If your pump is running and water is going back to the pool, that water is coming from somewhere ... probably being pulled from the pool. Is this a new pool? If not, did it operate properly last year? Are you getting air into your system?
You don't say much about your pool ... is the suction line attrached to a skimmer? Two skimmers? Two skimmers and a bottom drain? Attached to the bottom drain? I don't understand why you are reporting no suction since there is a discharge ... Is this pool in the ground or above ground? Do you have one circulator pump or do you have multiple pumps? If you have two skimmers and are trying to vacuum, close the shutter on the other skimmer or put a plug into it. Make sure the plug is the proper size, you don't want to get the plug pulled into the system!
Perhaps there is not enough suction for you to vacuum? If your suction is attached to several points in your pool, can you cut back on the other ports? For example, if you are drawing from the bottom and a skimmer, can you shut the bottom drain off?
Have you checked your impeller for hair clogging? What about your filter, if sand, have you back washed? What is your discharge pressure? If DE, how is the DE doing? Might it be due for a change? If a cartridge filter, is your cartridge clean? Of course dirty filters will cause high pressure and poor flow of water. If your impeller is clogged with hair, that will impede the flow of water.
Fill in some of thedetails and I will continue to try to assist you. Thank you for your interest in FixYa.com
Jul 05, 2011 | Sta Rite Pool & Spa
I have a Hayward SP-715XR50 Vari-Flow Control 2" and I need to drain my pool due to high Cyanuric Acid. My pool has 2 skimmers. It has been suggested that I plug the 2 skimmers and turn the valve to...
Do you have a bottom drain that the pump can draw the water down from?
If not, you may find that if you plug the skimmers you may find that there is no flow from the pump.
Gary
Jun 13, 2011 | Garden
Just had pool opened. They turned port dial to 2
Welcome to FixYa
Dear Sir/Madom,
If your skimmer is tied to your main drain, then both holes have to be uncovered for your skimmer to work.
If you have a separate line all the way back to your equipment from your main drain, then you may want to try to open both holes in the skimmers. Turn off your Unit to unscrew the retaining screw on the valve, and then slide the big end over.
If you've not had your pool run all winter, then you may have leaves/debris caught in the line.
If so-you can swing by a plumbing supply house and get a powerflush hose attachment.
  • Make sure that none of the holes in any of your skimmers are covered by the oval tab in the skimmer.
  • Then, if you have any valves on the inlet to pool pump, rotate them in such a manner to isolate the skimmer line that isn't working, making sure that it is open.
  • Place the hose and powerflush device in the upper inlet port of the pool pump, with the pump lid/cover and basket removed. Then, pressurize the line back to the pool with tap water.
  • If it doesn't release right away, then let it sit a little while, as you may have to "pulse" it as water pressure drops as water leaks around the clog.
  • Pulsing it means to turn the water on for a few minutes, then turn it off. Then, turn it back on, and then turn it off again.
Look down into the bottom of the skimmer. It will have either one or two holes, depending on your model. These holes are where the pool plumbing attaches to the skimmer. Most skimmers have threads inside the holes, and a copper or PVC threaded fitting screws into these ports. Squirt food coloring just above the holes and see if any of it is pulled down into them. This indicates a leak which may be caused by a poor seal between the skimmer threads and the fitting. If you put your finger into the holes, you should be able to feel where the top of the fitting meets the skimmer threads.Repair any cracks or breaks in the skimmer walls with epoxy putty.Use the silicone sealer to repair areas where the skimmer has pulled away from the pool wall, where the corners are cracked, and in tile cracks. These leaks are the result of a cracked bond beam or shifting soil from water getting into the ground around the skimmer.
Also Check this Link
I hope you got an idea...thank for Using FixYa...
Jul 03, 2010 | Hayward SAND FILTER, PRO SERIES
We have a less then 1year old heater that is burnt out becuse we put clorine tablets in the skimmers lxi gas pool heater
You owners manual will tell you that putting chorine tabs innto your skimmer will damage your heater and void the warranty. I am sure you already know this now. It is bad procedure to do this. I assume you have a leaking heat exchanger. This is very costly, and you will probably need to call a professional to install it. If the heater was much older, i would probably say to just buy a new heater. The exchanger usually run about half the price of a new heater.
May 18, 2010 | Hayward 250kbtu Ng Pool Heater - Inground
NOT FILTERING, NO SUCTION, CHANGE SAND,,,SINCE DAY ONE..WRONG HP?
You are correct. Your lines are extremely small for this system and the pump is to small for this system. You are going to have to do a total upgrade. from the pump to all the lines. I know this is bad news, but it is a common problem for system that where put in more then 10 years ago
Jun 01, 2009 | Hayward SAND FILTER, PRO SERIES
Waterco 00B9012 Baker Hydro Skimmer Parts Skimmer Control Plate Decal Logo
294 people viewed this question
Top Waterco Pool & Spa Experts
Andrew Taylor
Andrew Taylor
bigdawg7299
Are you a Waterco Pool and Spa Expert? Answer questions, earn points and help others
