HELP! Dog stepped on remote and now volume on Sony KP53S65 won't work.
    Top Expert:
  • 12,223 Answers
Test this steps and fix it. God bless you
  1. Check if the TV and Amplifier (if connected) is turned on and set correctly.
  2. Check if the TV, DVD player and Amplifier are connected properly.
  3. Make sure the TV, DVD player and Amplifier volume are not set to Mute.
  4. There will be no sound output during Reverse Play / Pause / Step / Slow / Search.
  5. If the DTS soundtrack is enabled in the DVD Disc Menu, but you are using Stereo Analog audio, the sound will not work. Try switching the soundtrack to Dolby 5.1 or PCM mode in the Disc Menu.
Posted on Jul 22, 2013
4 Suggested Answers
MikeL DISH
  • 92 Answers
SOURCE: I changed tv's and everything
I came across your post, autumlite; that's interesting! I have a few steps for you to follow to get that taken care of so you can start enjoying the convenience:
Address To Other Equipment Using Power Scan
  • Remote: All Remotes (except Basic)
    1. With the desired equipment on, press and hold the correct Mode button until all mode button backlights illuminate, then release.
    2. Press and release the Power button. AUX Mode: Before pressing and releasing the Power button
      • Press 0 for a TV
      • Press 1 for a VCR/DVD
      • Press 2 for any other device
      Then Press STAR (*)
    3. Press the Up button once a second while pointing the remote at the desired equipment. Note: If the code for the equipment comes up, the equipment will power off.
    4. Press the POUND (#) button. Note: If the code entered is valid for the remote, the mode light flashes three times.
Hope that helps and let me know if you need any further assistance!
Posted on Aug 31, 2011
  • 1116 Answers
SOURCE: Lost the volume on new cox universal remote. Reset
This is a common problem with these remotes, just call Cox or go to the local office and have it exchanged.
Posted on Oct 01, 2011
gopakumarg43
  • 75571 Answers
SOURCE: remote to tv doesn't work
Hello
Check the remote first for its infrared emission. If it is OK, the infrared sensor inside your tV is faulty. It should be replaced with same type and number. It can be located just behind the infrared window at the front panel of your Tv. You ahve to open your TV ot access it. It will have three solder terminals, and will look somehat brownish black in colour. Will look like this.
Posted on Nov 14, 2011
No sound at all on my sony cdp-ce500, why?
I bought this too and can't believe they forgot to add a volume control!!!! It's not on the player OR the remote.
Oct 27, 2012 | Sony Audio Players & Recorders
My sony bravia klv40ex600 won't turn on,the light indicator for power,volume and channel is on, the screen is still black
Hi, have you tried pressing the TV button that is under the On/Off button on top right hand side of remote control? Some times its possible to accidently press the DVD or VCR controls and this by-passes the TV as a remote?
Another cause can be a poor or low battery in the remote itself. If you have no luck let me know & we can try some more things, however, I have heard that The On/Off Switch on the TV can be a problem. Goodluck, Jon..
Jul 22, 2012 | Sony BRAVIA KDL-40S2010 40 in. LCD...
How do you turn off the FPA lock on the RCA TRUFLAT TV? I Can't access menu.
Hello
First of all, you must ahve its original remote control to unlock FPA lock. If you have it, go through the folloing steps.
* Hold down Menu button on the remote control, and the Volume Down button on the at the same time for at least 4 seconds. "The set won't say so, but the lock will be released".
** Hold down Zero button on the remote control, and the Volume Down button on the TV. The set won't say so, but the lock will be released.
*** Hold down Menu button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. The set won't say so, but the lock will be released.
Mar 11, 2012 | RCA TruFlat 27F520T 27" TV
Apart from the on-off button none of the panel or remote controls are working on my Toshiba 20wl56b t.v
I think problem is from the control board. The board works with the TV buttons and that's where the remote sensor is. If the board is defective or dead, the buttons won't work and the remote won't work as well.
I hope the above is clear.
Good luck.
Jan 05, 2012 | Toshiba 37WLC48 LCD Television
Hi I am unable to program my COMCAST remote to control my DAV-HDX275. I have tried all codes suggested by comcast in vain. Help please
These directions also work for Sony DAV-IS10
It seems like most (maybe all) Sony HTIB do not work with the Comcast Custom Remote. I've found a work around that fixes the volume control and power button though. Hope it helpsicon1.png you all. I have a DAVHDX275 but I think this will work for most Sony HTIB systems.
What you need to do is steal some codes from a like product and then hardcode in the changesicon1.png you need to the comcast remote. Set your AUX to 21232 (a sony code for TV/VCRs).
Then do the following:
1. While still on AUX, press and hold SETUP again until the remote blinks twice
2. Type 994
3. Press and release SETUP
4. Type 32975
5. Press and release VOL+
The remote should blink twice. That should reprogram the VOL+ to work with your Sony HT device. For each of the following function codes, follow the same steps and use the codes listed below:
Vol+ = 32975
Vol- = 31951
Powericon1.png = 32719
Good luck. Let me know if it works.
Aug 14, 2011 | Sony BRAVIA DAV-HDX267W Theater System...
My volume up on the Harmony 880 won't work. I've heard that one person did take it apart to clean the contacts, but that didn't solve the issue. Any suggestions? I don't even care if I...
If the buttons used to work then yeah it sounds like a hardware issue. You can go ahead and take the remote apart, but I don't think you will be able to fix it, unless you are good at soldering. Cleaning the contacts alone won't help. This same thing happened to the most used buttons on my Harmony One, and I just assigned the commands to the screen, so I could continue using the remote without those buttons.
If you want to try assigning the buttons to the screen, the steps in this article by Logitech will help:
http://logitech-en-amr.custhelp.com/app/answers/detail/a_id/9766/kw/buttons
I hope this helps.
Aug 14, 2011 | Logitech Harmony 880 LCD Remote Control
I got a Sony CMT-NEZ30 from a friend and I don't
Get the manual , which a simple search engine query for "sony CMT-NEZ30 remote" would have led immediately to...
http://esupport.sony.com/US/perl/model-documents.pl?mdl=CMTNEZ30
As far as remote failures go...
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Zoom in on the picture of the original remote provided on the site (or look at your own) and get the actual remote model number.
or check eBay: search for "(model of the device or the remote) remotes", check the 'include description' box. Usually cheaper than the vendors.
Jul 28, 2011 | Sony CMT-NEZ30 Shelf System
Where do I find codes for Protron DVD recorder PD-DVR 100 for a Dish Network remote control
I hope that you have found the codes by now, but if not, here are the codes we have, and also the steps to program that remote.
1. Hold down the clear AUX button until all lights light up at the top of the remote
2. Punch in a 3 digit code (provided below)
3. Press the # (POUND) button
4. Try powering the DVD on/off, and the volume. If one or more of these functions do not work, start over from step 1 with a different code
685 is the only code we have for this brand.
Becki Barned
DISH Network Customer Service
Sep 19, 2010 | Protron PD-DVR100 DVD Recorder
Sky remote volume button not workin tv volume.
please follow the steps below:
TV
RED + SELECT (flashes twice)
TV
0000
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Sep 09, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony rear projection tv kper43m31
All Sony projection TVs have the same remote key sequence to get into the service mode:
display - 5 - volume(+) - power
C-Dog
Feb 09, 2008 | Sony KP-61V90 61" Rear Projection...
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
