Question about Garden
My husqvarna zero turn dies when i pull handles off their stationary position to move mower?
Everything runs fine on my Husqvarna zero turn mower till I pull the handles out of their seated spot off the swithches, then mower dies. could both handle switches be bad or could it be something else?
SOURCE: mower quits when engaging mower deck of husqvarna yth 2348
Try putting a jumper wire on the wire going from the engine to the seat. Take that plug and put a wire from one side to the other. Be careful not to cut your feet off when engaging deck.
Posted on Mar 31, 2009
  • 109 Answers
SOURCE: Husqvarna zero turn mower won't start
Usually if all you hear is a clicking noise, it is the solenoid itself that has gone bad...if you can jump the solenoid and the mower turns over, it is the solenoid.
Posted on May 03, 2009
  • 95 Answers
SOURCE: engine dies when clutch brake released on husqvarna gth2548
First check the seat switch,make sure it is plugged in tightly, these plugs have a safety tab built into them that will cut the engine off if you unhook it,sometimes the plug latch pulls out slightly and this will cut the engine, There are two other switches in the system one on the foot clutch and on on the mower clutch, if you follow the white wire from you ignition switch it will lead you to both of them,check those connections also.
Posted on Jul 31, 2009
  • 95 Answers
SOURCE: Husqvarna Mdl YTH2448 Riding Mower - Electric PTO Not Working
It sounds like your charge system is not working. If you jump the battery the engine will run with a weak battery but the pto clutch needs a strong battery to stay engaged.Try this to test it,after you jump it leav the jumper cables hooked up and try to engage the blade clutch,if it runs it is either a battery that wont take a charge or a charge system not working. If you put a volt meter on the battery while the engine is running and the voltage is 13 volts the charge system is working and the battery is bad.
  • 9 Answers
SOURCE: 2007 Husqvarna Riding mower blade will not engage
Sounds like you electric blade clutch is bad. I just had the same thing happen to my exmark mower. I was cutting grass and the engine just shut down. It would not crank over. Checked the fuses and replaced one blown fuse. The engine wanted to crank over but it was locked up. I looked the engine over and seen that the bearing in the electric clutch seized up causing the clutch to melt.
Posted on Apr 25, 2010
Testimonial: "Thank you! That doesn't sound like an inexpensive solution. We appreciate your help, though."
I had to take the front tire off my zero turn husqvarna lawn mower. Now it won't move forward or backward what did I do wrong.
Make sure the bypass control lever is in the "engaged" position (pulled up and pushed in)..Hope this helps
Sep 11, 2017 | Husqvarna Garden
Zero turn will not move forward reverse or turn
These units use Hydraulic pumps for motivation. If the unit stopped all at one time, I suspect a drive belt came off.
For both pumps to fail at the same time would be very odd. Check the v-belt driving the wheel pumps.
Apr 12, 2015 | Husqvarna Zero Turn Mower RZ4619
When parking brake is moved off position, the engine shuts off on my rz5426 zero turn mower.
One of the safety switches is bad or not making contact. Check the switches on the levers and the seat switch.
Jul 19, 2014 | Husqvarna Rz5426 54" Zero Turn Lawn Mower...
I have a husqvarna 4623 zero turn and when I would pull up the pto the mower would die. I replaced the fuel filter and now it won't even stay running
Most likely the battery isn't holding enough charge which is why the PTO won't engage.
Likely you have air in the fuel line/fuel filter which lets it run for awhile then it fuel starves.
Oct 30, 2012 | Husqvarna Garden
Husqvarna zero turn runs great but after about 30 mins the blades stop turning
when this happens you need to see if it you loose power to the clutch to see if the clutch is failing or the circuit feeding it power
Apr 27, 2012 | Husqvarna Zero Turn Mower Z5426
I just purchased the new Husqvarna MZ6128 Zero Turn. Was dropped at home on Sunday.. with the parking brake on and deck in the traveling mode and handle bars in neutral it will start..when returning the...
Read the manual. These so called "problems" are standard safety features that someone should have gone over with you. Sounds like poor salesmanship. When starting the mower the bars should be out and the park brake pulled. Then disengage the parkbrake and pull the arms in to drive the mower. Do exactly the opposite to get off the mower. I just bought one today every model I looked at was like this.
May 24, 2011 | Husqvarna Zero Turn Mower Z5426
How do I move a Husqvarna zero turn mower when it won't start? I thought that it had a "neutral" position to roll the machine, but I can't find it in the manual.
There is a lever on the back of the machine (yours may have two), down low on the back plate. Pulling the rods out will release the transmission so that the mower may be rolled.
Best regards, (and please rate this solution), --W/D--
Apr 02, 2011 | Husqvarna Zero Turn Mower Z5426
Garden Logo
816 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
