Aquos LCD TV LC-32G1X
Tv wont stay on for long sometimes picks up input from amp but then turns itself off again?
  • 5 Answers
SOURCE: Sharp Aquos turns itself off
How many times per second does the POWER led blink? (dont worry about the OPC).
1x per second (constant, steady blink) = bad inverter/lamps
2x per second = bad power supply
3x per second = bad main board
You can buy the parts online and fix if yourself!!
Posted on Aug 16, 2008
SOURCE: No sound on Sharp Aquos 37' LC-37D4U
I had the same problem on my 37" Aquos. Sound went out about 8 months ago after 4 years. Technician said it was the Sound Power Supply. Total cost to fix was $440. $250 for the power supply and $170 for labor. Has worked fine ever since. When I asked for the old power supply he said he had to give it back as a trade in. I don't believe that so I don't really know if the power supply was the real cause.
Now I've lost sound on 4 channels on my 20" Aquos. Great picture, but wouldn't buy another Sharp product.
Posted on Dec 24, 2008
SOURCE: Sharp Aquos pictures problem LCD TV-LC-GA8E
I called Sharp and told them about our problem. At first they denied even knowing about this kind of problem but after some back and forth, they finally gave me a case number and told me to call back on Monday (this was on a Saturday). I did that and at first they didn't want to admit anything there either but again, after some back and forth, they agreed to have the set fixed by a local company (under contract with them I suppose). When the people called to tell us when they were coming we told them that they had told us that they would be there a few days later and the service people said 'yeah, but we got the part in sooner'. So what does that tell you? They do KNOW about this problem - it's just getting them to admit it. The service guy brought some new boards out but they didn't fit so they had to take the set in while they ordered new boards. That took almost 2 weeks but we've got it back now and haven't had any more problems with it. Our set was over 2 years old but I didn't know it at the time - I thought it was just over 1 year old. But we did give them the model and serial number and am happy with the way things turned out. We live in Texas so I don't know how anybody else's problems were handled.
Posted on Feb 17, 2009
  • 19396 Answers
SOURCE: LC-37AF3X Sharp Aquos KCD TV
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
  • 10865 Answers
SOURCE: I can't find the owner's/TV manual for Sharp AQUOS
Posted on Jun 04, 2009
I have a Sharp Aquos # LC-45GD4U. It now suddenly turns off by itself and stays off until I turn it back on. This happens while watching live TV or playing back a recorded show. Ideas?
Check the ventilation fins on the back. Sometimes they get obstructed with dust and then heat builds up. The TV then shuts down to protect itself from overheating. You can use a blow dryer to blow it out.
Feb 01, 2013 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
Do you see the backlight ever coming to the screen?
You will want to open the cover, disconnect the backlight inverter and try again to see if it will stay on even without an image.
If it does it's the inverter.
if it still shuts it's most likely (not guaranteed) either the power board itself or the main board.
A good tech should be able to test the power board independantly fairly quickly.
Jun 30, 2011 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
My sharp tv wont stay on, it flashes green
Hi i have seen this before sharp hdtv's are known for having the internal power supply go faulty
Feb 01, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Plasma TV turns off by itself-won't sty on for
when i turn my 32 inch VIVIO plasma tv on it turns pff by itself. i want to know why this is happening
Dec 07, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
i find that my aquos lc37gd8e has no signal between 5pm and 6.30pm but my other tv is fine it also switches itself of somedays at 9.30pm have trided retuning this has not helped can you help?
Nov 26, 2009 | Sharp Aquos LC-37GD1E 37 in. HDTV-Ready...
When plugging in a new PS3 to hdmi input 4 or 5 on the Sharp Aquos LC-42D62U, it is not picking up the connection and I can't select it on the input menu
Does the HDMI output on the PS3 have to be turned on first in its settings? Make sure the settings on the PS3 are at a minimum of 720p as if it is set to 480i the TV probably wont notice anything connected to HDMI.
Nov 06, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Problem connecting my PS3 to my Sharp Aquos LC-C3237U LCD TV
Your PS3 set itself above the max resolution your LC-C3237U. Most likely the PS3 is doing 1080P, but the highest the Sharp can do is 1080i. So do this:
1. Connect PS3 to TV (you can use the current cable or analog cable)
2. Turn on TV and set input to port PS3 is on.
3. Make sure PS3 is connected via correct cable.
4. Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
Sep 15, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Call Sharp. They are fixing my 18 month old LC40C32U for free.
Jun 10, 2008 | Sharp Aquos LC-32D40U Television
Aquos Turns off by itself
no. It goes black, then about 5-10 seconds, it turns itself back on.
Jan 01, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Televison & Video Logo
87 people viewed this question
Top Televison & Video Experts
