Fragmentation occurs when the operating system cannot or will not
allocate enough contiguous space to store a complete file as a unit,
but instead puts parts of it in gaps between other files (usually those
gaps exist because they formerly held a file that the operating system
has subsequently deleted or because the operating system allocated
excess space for the file in the first place). Larger files and greater
numbers of files also contribute to fragmentation and consequent
performance loss. Defragmentation attempts to alleviate these problems.
Example
Consider the following scenario, as shown by the image on the right:
An otherwise blank disk has 5 files, A, B, C, D and E each using 10 blocks of space (for this section, a
block
is an allocation unit of that system, it could be 1K, 100K or 1
megabyte and is not any specific size). On a blank disk, all of these
files will be allocated one after the other. (Example (1) on the
image.) If file B is deleted, there are two options, leave the space
for B empty and use it again later, or compress all the files after B
so that the empty space follows it. This could be time consuming if
there were hundreds or thousands of files which needed to be moved, so
in general the empty space is simply left there, marked in a table as
available for later use, then used again as needed.
[1]
(Example (2) on the image.) Now, if a new file, F, is allocated 7
blocks of space, it can be placed into the first 7 blocks of the space
formerly holding the file B and the 3 blocks following it will remain
available. (Example (3) on the image.) If another new file, G is added,
and needs only three blocks, it could then occupy the space after F and
before C. (Example (4) on the image). Now, if subsequently F needs to
be expanded, since the space immediately following it is no longer
available, there are two options: (1) add a new block somewhere else
and indicate that F has a second
extent, or (2) move the file F
to someplace else where it can be created as one contiguous file of the
new, larger size. The latter operation may not be possible as the file
may be larger than any one contiguous space available, or the file
conceivably could be so large the operation would take an undesirably
long period of time, thus the usual practice is simply to create an
extent
somewhere else and chain the new extent onto the old one. (Example (5)
on the image.) Repeat this practice hundreds or thousands of times and
eventually the file system has many free segments in many places and
many files may be spread over many extents. If, as a result of free
space fragmentation, a newly created file (or a file which has been
extended) has to be placed in a large number of extents, access time
for that file (or for all files) may become excessively long.
The process of creating new files, and of deleting and expanding existing files, may sometimes be colloquially referred to as
churn, and can occur at both the level of the general root file system and in
subdirectories.
Fragmentation not only occurs at the level of individual files, but
also when different files in a directory (and maybe its
subdirectories), that are often read in a sequence, start to "drift
apart" as a result of "churn".
A defragmentation program must move files around within the free
space available to undo fragmentation. This is a memory intensive
operation and cannot be performed on a file system with no free space.
The reorganization involved in defragmentation does not change logical
location of the files (defined as their location within the
directory structure).
I lost 6 mths of my kids first year in football, all lost through a novice mishandling of the it.BOO HOO icould cry
