CANNOT LOAD BATTERIES. ALWAYS GET THE MESSAGE: REPLACE BATTERY. UNABLE TO GET STARTED WITH THE TIMER. NO MATTER THAT THE BATTERIES ARE BRAND NEW.
SOURCE: displays "low battery" always
I had exactly this problem and found the solution - I was using the wrong type of batteries.
You might be doing the same so what you need to do is check to see what mAh the batteries you're using. I was using Energizer rechargables with 1300mAh when the camera stopped working and switched to 2500mAh rechargables (on the advice of a friend) as a last desperate attempt to get it to work and it solved my problem. I got 2500mAh Energizer rechargables and would advise the same but you should go for batteries with at least 2100mAh.
I hope this helps some people :)
SOURCE: bike makes a clicking noise when i try to start it
Your starter isn't getting enough power. Try checking your water levels in the battery and charging it with a trickle charger. Good Luck!
SOURCE: battteries depleted messageon Pentax Espio E40, even though have tried brand new batteries.
HI. this seems to be a battery scanning fault in the programming. try to reset the board by pulling the battery and removing all power of 30 minutes. completely drain all power from this unit for 30 minutes. if this message continues after you have rest the programming, this will confirm a serious fault within the internal program. you will have to send this device back to a pentax repair terminal for reprogramming.
SOURCE: false low battery message -- batteries are brand
cudgegong said in another forum:
To resolve the annoying "change the batteries" problem. Goto menu, choose yellow menu, select
file No. reset to ON. Turn camera off and back on.
Voila fixed.
