Question about Vistablet PenPad Graphics Tablet
My cursor won't work
Whenever I move my pen around the cursor doesn't move
Tablet pen's cursor skips around in 3 places?
The cursor skipping in three places is apparently caused by the connectors inside the tablet getting dirty or corroded.
Fortunately, you can easily fix this problem yourself! All you need to do is unscrew the back of your tablet, unplug the connectors and clean them with a q-tip dipped in alcohol.
There is a video on YouTube that shows you step-by-step how to do it(it's easy!).
It's called: Howto fix dead areas on any graphics tablet and it's posted by riodroid.
Here's a link to it: http://www.youtube.com/watch?v=ff7Vw-0kPsE
Hope this helps!
May 14, 2013 | Adesso CyberTablet 12000
No cursor on calibration screen?
how silly are you.
why dont you do what he tells you. TAP THE CENTER OF THE CROSS.
F......I....
Apr 19, 2017 | Wacom Bamboo Fun 5.8" x 3.7" USB Tablet...
MONOPRICE TABLET PEN NOT WORKING
update drivers from the official site.
May 08, 2012 | Computers & Internet
When i receive a message, my e73 doesn't make any noise. i've taken out the battery several times, turned it off and on, let the battery die, but it's not working. the only thing that indicates...
for it to ring delete all your messages from your inbox and outbox then reboot your phone (turn it off then back off) hope it works for you it did for me:)
Jun 21, 2011 | Nokia E73 Mode Cell Phone
Pen won't write though plenty of ink
There are a couple reasons a pen refill won't start writing right away. The first thing to check is the tip--often there is a bit of glue or plastic over it in order to prevent leaking.
If that doesn't work, then try one (or both) of the following two methods:
1) Place the refill (but not the tip) in some warm water. Heat will allow the liquid in the gel pen to become thinner and flow more naturally.
2) Hook a rubber band around the middle of the pen, using tape to ensure safety, and wind the pen while holding the rubber band on either side of the pen. Make sure the cap is on the pen. When the rubber band is tight, when you pull straight out on the rubber band from both sides of the pen, it should spin very quickly. The centripetal force will cause the liquid in the pen (at least half of it) to move toward the tip.
Make sure you fasten the rubber band to the pen with tape or something similar; otherwise the pen may go flying off at someone nearby. Also, again, make sure the cap is on to prevent any ink spraying out--this is unlikely in a gel pen, but it could happen.
Jun 13, 2011 | Sanford UniBall Gel Impact Rt Retractable...
Graphire4 Pen Problem
throw it in the trash and get a proper tablet
Oct 15, 2007 | Wacom Graphire4 Digital Pen
Vistablet PenPad Graphics Tablet Logo
Top Vistablet Computers & Internet Experts
David Payne
David Payne
Are you a Vistablet Computer and Internet Expert? Answer questions, earn points and help others
