The machine does not revolve and does not work
    New Friend:
Hey there! I just experienced the same thing with my washer. What i did was i unplugged it and stepped away for about ten minutes. Once i came back it was working! Just let it relaz and restart for a bit. Hope this helps you out :)
Posted on Jul 22, 2013
  • alicia jan Jul 22, 2013
Ordered the PL800A (looks like it's identical to the UP-7116EA-81A-1) as I saw on a blog that it would work for all HP tablet PC's that have a digitizer. I have a HP Elitebook Revolve 810 G1 which HP says...
HP switch digitizers with the HP Revolve. Previous HP tc4xxx convertible tablets used a Wacom Digitizer, for the Revolve they are using a digitizer manufactured by Atmel. The change hasn't been well received as Atmel's performance has been horrible. If stylus performance is important to you, you would be better served with a different computer I'm sorry to say.
The only easily obtained stylus that is compatible with the Revolve is the HP Executive Pen but you have to be careful because the current HP Executive Pen featured on the HP website is for the G2 Revolve and it won't work with the G1.
The Part Number you need is H4E45AA I've included a link to CDW because their price was much lower than the price shown at Amazon
HP Executive Tablet Pen stylus H4E45AA Digitizer Accessories CDW com
Apr 07, 2014 | HP (PL800A) for tc4200
AWM5104/1 Front Load Washer: Whirlpool AWM 5104 - The machine turns on and the ...
May be the belt at the back of the machine is loosen or cut off kindly check it and replace the belt
May 06, 2010 | Whirlpool AWM5104/1 Front Load Washer
Toshiba 4511 error CEF0
CEF0 indicates Revolver motor abnormality.
Perform output check 03-450 whether the revolver motor is working. If not, then change the revolver motor. If working, then u probably need to change the DRV board or LGC aaboard.
*Make sure all the connectors are plugged
Mar 26, 2010 | Toshiba E-Studio 3511 Color Copier
New Filters have been fitted on the Sebo automatic XI
OK - I'm a Sebo expert, and we will get to the bottom of this! I need you to do one thing for me: lie the machine on one side, then switch it on and look to see if the brush roller is revolving - KEEP FINGERS and all loose items WELL CLEAR. Does the brush revolve? Then, with the machine switched off and unplugged, see if you can rotate the brush roll by hand. Does it revolve easily, or is there a lot of resistance? Then post a reply here saying what you observe. I'll get back to you when I've got your reply.
Feb 24, 2010 | Sebo Automatic X1 Bagged Upright Vacuum
Microwave sparked out now it does not work
You had something metal inside the microwave. Do you have a rack inside on a revolving tray? On my microwave, if the foot of the wire rack is not on the revolving tray, it will spark against the floor of the oven. Microwave will go around round pieces of metal - it will spark if it finds a flat surface. I dont think you did any damage to your machine but try to not do this again.
I hope this helps you.
Sep 08, 2009 | Microwave Ovens
Call for service CEA0
This means the revolver (holds the 3 color toners/developer units) never returned/moved to its "home" position.
It could mean a bad or dirty home position sensor or a faulty/bad logic board or possibly a bad motor (not rotating the revolver correctly) try cleaning or replacing this sensor first.
if you remove the covers from the left side of the copier you will see the revolver unit. the sensor is located at the rear of the revolver unit mounted on the frame of the copier.(easy to see) there is one screw holding it and a small wire connector.
These copiers are "famous" for having dirty sensor issues.
If the revolver/machine makes an odd noise when starting up, caused by the revolver then its starting to turn (run the copier with the side cover open so you can watch it) then it would point more to being a drive problem.
Mar 26, 2009 | Toshiba E-Studio 3511 Color Copier
Not printing on left side of page
The problem is that the revolving drum doesn't contact the OPC drum proberly. You have to open the left side off the machine and replace the little white gear on the shaft that drive revolving drum. The gear has "jumped"one step and the revolving drum isn't parallell to the OPC drum. I fixed my 2840 last night it takes some time but now it works perfect.
Feb 25, 2009 | HP LaserJet 2840 Printer
Zanussi zwf 1020w drum not revolving
The drum will not rotate until the draining process is satisfied, there is either something in the pump or pump is broken
Oct 20, 2008 | Zanussi FJD1666W Front Load Washer
AWM8163 Cylinder revolves with friction - sock?
its very long diffecult job to do that but i have had luck going to the bottom of tub removeing the drain hose from tub to pump work things out throw the 3 in hole in the bottom
Mar 01, 2008 | Whirlpool AWM8163 Front Load Washer
Indesit Washing Machine not proceedding with the cycle programme after filling with water.
Cant understand how the machine will revolve on the 'spin cycle' & yet you can hear the motor on the 'wash cycle' but yet it doesnt revolve!!
Nomally if the water fills, & the tub revolves without the programmer advancing, its because the heater is not working. ie faulty thermostat, heat element, or maybe a wire burned off in the 'heater circuit'. Check if you have 240 volts at both ends of the heat element, with a meter or 240 volt bulb
                         !! BE CAREFUL OF 240VOLTS!!
Oct 29, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
